Old 03-09-2015, 02:45 PM   #29
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Originally Posted by afohlin View Post
I'll be installing my Tomei UEL headers in a few weeks hopefully. What are people's opinions about the Tomei gaskets? I wasn't sure if I should pick up a set of Grimmspeed gaskets just to be safe or if the Tomei supplied gaskets don't have any issues.
i'm curious about this as well.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 03-09-2015, 03:59 PM   #30
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
Tomei gaskets work great, mines holding up well. The only pain in the whole process was getting the bolt on the collector side tightened.
fantah is offline   Reply With Quote
The Following 2 Users Say Thank You to fantah For This Useful Post:
afohlin (03-10-2015), RobertPaulson (03-09-2015)
Old 03-09-2015, 04:01 PM   #31
fantah
fantah's Avatar
Originally Posted by winsometang View Post
how did you guys remove the o2 sensor? did it require a sensor remover or can i just use a wrench?
Unplugged the sensor from the car then when I head the stock headers off the car I took it off the header with a wrench. Think it was like a 17mm or 18mm.
Old 03-09-2015, 04:02 PM   #32
fantah
fantah's Avatar
Originally Posted by mikalem View Post
Sorry to bring this back to life, but for those than installed it did you loosen the spacers at all before bolting it up, or did it come pre-spaced and matched? Going to install this hopefully over the weekend, just wondering what other's have found.
Loosen the spacer, put on to test fit, take off header with adjusted space, tighten spacer, reinstall.
Old 03-09-2015, 05:25 PM   #33
Cop
Cop's Avatar
Drives: 2013 FRS
They are fine.
Cop is offline   Reply With Quote
The Following User Says Thank You to Cop For This Useful Post:
Old 03-10-2015, 11:37 PM   #34
Raven_FR-S
Raven_FR-S's Avatar
Drives: 13 Scion FRS
Originally Posted by aznatama View Post
FIRST THING is to PB Blast the bolts connecting the header to the overpipe. More than one person has snapped a bolt taking it off as the nut may be seized
+1 On that one! I broke mine as well. Took a LONG LONG time to get it off.
Add me on IG @CNastySon
Mishimoto..."Do Yo Temps Stay Low, With the Throttle To Da Flo!!!
Raven_FR-S is offline   Reply With Quote
Old 03-26-2015, 01:50 PM   #35
P_say86
Drives: '13 asphalt frs
Van anyone tell me how to tighten The nuts? I can tightin two of them but the single last one is hard to get too. Wrench and socket won't work.
P_say86 is offline   Reply With Quote
Old 03-26-2015, 02:01 PM   #36
Cop
Cop's Avatar
Drives: 2013 FRS
If you can find a smaller socket and extender it should work. That last nut was a huge PITA to tighten, I ended up going to my local garage so they could tighten it a bit more the next day.
Old 03-26-2015, 02:48 PM   #37
ramiram1984
Drives: 2016 STi DGM
GET A U-JOINT AND AN EXTENSION
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 03-26-2015, 06:35 PM   #38
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Crows foot from Harbor Freight. See post#20
BirdTRD is offline   Reply With Quote
Old 05-19-2015, 09:02 AM   #39
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
I cant believe no one has posted anywhere in the entire forum all the torque specs in one place.. I still have not been able to find the torque specs for the header to overpipe. Heres what I have so far:
header to engine studs 22lbs
Overpipe to Front pipe - 31.3 FT LB
Front pipe to Exhaust Pipe - 14.3 FT LB
Im just going to wing it and torque it to 30 ft lb
eurominican e u r o m i n i c a n
eurominican is offline   Reply With Quote
The Following 2 Users Say Thank You to eurominican For This Useful Post:
DriveDriftDogfight86 (10-01-2019), number1Tango (01-21-2016)
Old 05-19-2015, 09:38 AM   #40
DarkSunrise
DarkSunrise's Avatar
Just a heads-up that if you're using a crows foot, make sure to adjust torque specs accordingly.
2022 BRZ Build
2013 FR-S Build
Old 05-19-2015, 09:41 AM   #41
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I wish I saw this a few days ago, I just tightened them down as tight as I could get them. Good luck trying to get a torque wrench in there, much less getting an accurate torque.
As for the over pipe to header, again, no room for a torque wrench. I tightened them up and turned on the car whilst having my dad cover up the exhaust tips (leak check). As it turned out, the to head to manifold joint was fine, but the manifold to over pipe was leaking, so I had to really tighten those bolts in order to get it not to leak.
Hope that helps someone.
Bobblehead is offline   Reply With Quote
The Following User Says Thank You to Bobblehead For This Useful Post:
eurominican (05-19-2015)
Old 05-20-2015, 12:54 AM   #42
eurominican
I though I had to widen/space out the header because was not going in the studs (The lower o2 sensor was getting cought up in the plastic side cover..) so I did losen up the spacers but couldnt get the header to space out at all (thankfully).
It should always be propperly spaced out since it comes with a metal bar with a nut on each side bolted to the header. If I had to guess I'd say the purpose of this is to make sure the header doesnt shift during shipping etc.
And here's a pic of the manual with torque specs but just like you stated, most of these have to be hand-tighten because its virtually impossible to do with a torque wrench, specially if doing the install in jack stands.
Evasive Tomei Header Group Buy Evasive Motorsports Groupbuys 424 08-05-2018 01:55 PM
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 02:45 PM
Quick tips for Remote Start installation trueno86power DIY (Do-It-Yourself) Guides 12 12-07-2014 04:47 PM
Tomei Exhaust with Tomei Straight Pipe leech Engine, Exhaust, Transmission 10 01-07-2014 11:42 AM
FS: Tomei UEL Header (WRX) [deleted] Miscellaneous 0 03-19-2013 10:58 PM
