Old 02-19-2014, 11:09 AM   #29
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Haven't installed them yet. Still winter in Fargo, so car is put away in the garage.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 02-19-2015, 09:40 PM   #30
dkx64
Drives: 2014 Frs
Hey just about to install JL c5-653 3 way's. could you go a bit more indepth on your install? Any cutting? Did the new tweeter fit with the new dash speaker on both sides?
thanks!
dkx64 is offline   Reply With Quote
Old 02-20-2015, 09:31 AM   #31
Gopherboy6956
thanks!
Oooo, I have to think back a bit on that one.
I don't remember having to do any other custom mounting other than the melting the tweeter to the plastic housing. I MAY had had to put the mid in there a little sideways? geeze... i'd have to look again to be honest.
I WILL Say - the best thing I did though was take the extra time and work to run the crossovers into the trunk. I've messed with the settings a few times since install, and it's really nice not to have to crack open the door panels or roll around under the dash to work with them.
I don't have any great pictures of the trunk after I did that, but it's pretty straight forward.
Old 02-20-2015, 06:51 PM   #32
dkx64
Drives: 2014 Frs
Reason I ask, is because I've been reading around and notice that some people are putting the tweeter in a DIY pillar housing. Dont get me wrong, looks pretty badass, but that would be completely irreversible. Id most likely take the JL's out of the car when I decide to sell it.
Either way, you had to make speaker mounts for all speakers correct?
Did you just run longer speaker cables from the crossovers? That does sound like a much better idea. hows that new headunit?
Old 02-21-2015, 07:00 PM   #33
Gopherboy6956
I just build the front door speaker mounts. I left the rear speakers stock and hooked them up to the amp as well.
I ran much longer cables all around, correct.
Love the headunit. I had tried a lower pioneer model but the interface was PAINFULLY slow.
Old 02-22-2015, 03:32 AM   #34
Starzard
Starzard's Avatar
I went from a 2004 RSX to a BRZ too
World Rally Blue Crew
Starzard is offline   Reply With Quote
Old 02-22-2015, 11:48 AM   #35
Gopherboy6956
Haha. It was such an eye opener to slide into the BRZ and then go back to the RSX - the seats in there felt like bench seats in comparison to the BRZ.
But the high school kid in me sure misses Vtec.
Old 02-22-2015, 01:05 PM   #36
Lonewolf
Lonewolf's Avatar
Drives: Moped
I just went through your thread from beginning to end...thanks for the car pron
Old 02-22-2015, 02:25 PM   #37
Gopherboy6956
Thanks for checking it out. I can't wait to take it out of the winter hibernation and get my smaller pulley / pro tune in April.
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
Lonewolf (02-22-2015)
Old 03-09-2015, 10:56 AM   #38
Gopherboy6956
Just ordered my 17x9 rpf1 with 255/40 ZII star specs. Should be interesting to see if it fits.
DustinS (03-09-2015)
Old 03-09-2015, 11:57 AM   #39
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Car looks really good!
What offset are the RPF1s? 17x9 et35 with 255 should fit without any issues as long as you have coilovers(which you do).
Old 03-09-2015, 12:00 PM   #40
Gopherboy6956
the 17x9 rpf1's are 45mm offset. After checking the fitment guide on here, it looks as if I might have 'predicted issues'. If i do, it seems a 3mm spacer in the front will fix that, as 42mm offset fits just fine.
Old 03-09-2015, 03:34 PM   #41
TWMPerformance
Drives: Manual Transmission, All the Way!
Car looks serious dude! (y)
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 03-22-2015, 01:28 AM   #42
Gopherboy6956
3/14/15 - Wheels & Tires and Driveshaft came in:
Enkei RPF1 17x9 45mm Offset with Dunlop ZII Star Specs
Meaty!
Driveshaft Shop Aluminum Driveshaf
Pixel67's Daily Driver Build - Journal pixel67 Member's Car Journals 44 06-16-2016 10:48 PM
Hyper-BRZ Build Journal hypermax Member's Car Journals 62 06-10-2016 11:39 PM
Build Journal for Koigataki (6MT Argento FR-S) Koigataki Member's Car Journals 25 10-10-2013 02:09 AM
Jdmitr BRZ Limited journal/build thread jdmitr Member's Car Journals 18 10-01-2012 12:50 AM
Longo Scion Demo Build Journal - Car arrives next week xravexboix Member's Car Journals 12 06-15-2012 12:00 AM
