#897 | |
aeiou
Drives: WRB BRZ
How do I get in on this list? I've been following since this thread started! I had no idea there finally was a module.
I would like stock behavior
#898 | |
Go Big Red!!
Drives: 2013 SSM BRZ Limited
http://www.diodedynamics.com/store/c.../category/814/ |
| The Following User Says Thank You to Husker BRZ For This Useful Post: | unsurety (03-06-2015) |
#899 | ||
aeiou
Drives: WRB BRZ
| The Following User Says Thank You to unsurety For This Useful Post: | Husker BRZ (03-06-2015) |
#900 | |
Drives: TIE interceptor; BRZ13
Order online - I ordered on 2/17 just got email of shipment today 3/7 .- est. delivery 3/12 http://www.diodedynamics.com/store/c.../category/814/ Sent from my iPhone using Tapatalk
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
| The Following User Says Thank You to TIE Pilot For This Useful Post: | unsurety (03-06-2015) |
#901 | |
#902 |
Drives: Subaru BRZ Limited
Ordered!
#903 |
Drives: Brz WRB - Europe LHD
Service message for Diode Dynamics and for all users of "Always ON":
I INFORM YOU THAT IS POSSIBLE TO INSTALL brown relay OPENING THE FUSE BOX BY THE ENGINE SIDE. You can see a little side and slide panel (red square in pic) along height of fuse box. Open it (from bottom to upper side) and you can avoid to stretch the little black wire onto cover of fuse box. Install relay and insert black wire inside the fuse box. Nick, Paul !!!!! installed and all is gone very well on EDM BRZ!.
| The Following 3 Users Say Thank You to Trap63 For This Useful Post: |
#904 |
Thanks for everyone's continued patience. We shipped a bunch last week, and we expect to be caught up and stocked for immediate shipment by the end of this coming week. Finally!
Glad to see that most of you are getting perfect functionality right out of the box. If you think you do have a problem, please double-check that your stock DRL is activated (without the module) and then contact us if you're still seeing issues. Thanks!
#905 | |
Drives: '14 WRB BRZ LTD Turbo
I started my rma on 2/26 but it's since just been put to preorder status... Order # 11222124. So by the end of this week then(3/13)? |
#906 |
| The Following 8 Users Say Thank You to Trap63 For This Useful Post: | 00NissanNinja (03-11-2015), Choco (03-13-2015), Elkton86er (03-08-2015), FLYFISHR (03-08-2015), qoncept (03-09-2015), TIE Pilot (03-09-2015), tracerit (03-10-2015), unsurety (05-15-2015) |
#907 |
Drives: 2014 Subaru BRZ Limited WRB AT
Installed mine today. Worked great right out of the box. I saw @Trap63's note about the black relay wire after I was done. Went back and took a look and I think in my case the way I've got things tied up I need the black wire to be a few cm longer for it to work better via the engine side. When you slide the side panel back on it will tend to pull on the wire. I decided to put it back the way I had it - I used a little piece of electrical tape to both protect the wire and lodge it into a groove to keep the wire in place as the fuse box lid is replaced.
Thanks @DiodeDynamics for a great product!
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips |
| The Following 2 Users Say Thank You to Elkton86er For This Useful Post: | Diode Dynamics (03-09-2015), Guillaume (03-17-2015) |
#908 |
As advertised. Thanks @DiodeDynamics and @Trap63 for the "better solution"
| The Following 2 Users Say Thank You to TIE Pilot For This Useful Post: | Diode Dynamics (03-10-2015), Trap63 (03-09-2015) |
#909 | |
Drives: 03' NSX & 13' BRZ 6spd Ltd white
I appear to be having the same problem. (ordered on 2/17, and arrived today) I performed the simple install, and neither the DRL or boomerang come on unless I switch on the lights.
As you recommended, I removed the brown relay and replaced the stock one back, and now it works just like normal OEM. While testing I had the car running in neutral with parking brake off(brick behind wheels). Forgot to add that the DRL's did come on now with the lights turned on. Quote:
#910 |
Drives: MT WRB BRZ Limited, 2007 911s
| [Closed] Gauging Interest thread | pansontw | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 08-27-2014 03:14 PM |
| So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? | gt8613 | BRZ First-Gen (2012+) — General Topics | 18 | 04-27-2014 02:09 AM |
| Gauging Interest | ISC Suspension | Announcements, Contests, Giveaways | 17 | 04-03-2014 09:44 AM |
| Jdm headlights - gauging interest | Hawk77FT | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-31-2014 09:38 AM |
| FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 10:53 AM |
