Old 02-27-2015, 08:25 PM   #99
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Amaya View Post
It can clear basic settings in the ecu that can make the engine run very poorly, to the point that putting it in gear sometimes stalls it, making it hard to relearn the settings. If you have the proper diagnostic tools you can restore the settings to a better point. For a lot of shops its not worth the money those tools cost when they only work on a few of those cars.
I just said on all Mercedes Benz ecus thats not the case....but then again its different for each ecu in each car as different conditions come into play.....
Old 02-28-2015, 11:59 AM   #100
aagun
Drives: 86
Originally Posted by N1rve View Post
I got an update this morning.
They are replacing all of the valves, rocker arm, lifters, and Toyota wants them to perform a valve adjustment. They can't do that without the lifters.
ETA on parts is Monday or Tuesday. Looking at getting the car next Friday.
Direct Injectors were never pulled.
i had same issue >>
can you post here the parts number
aagun is offline   Reply With Quote
Old 02-28-2015, 02:37 PM   #101
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by aagun View Post
i had same issue >>
I pulled this from owners.scion.com
REPAIR PARTS NUMBER QUANTITY
ROCKER CP-VALVE SU00300278 8
PIVOT-ROCKER ARM SU00304520 8
GSKT&SEAL SET-ENG SU00300094 1
GT SUPER LLC BLUE 00272GTBC1 2
SHIM-VALVE SU00300214 1
SHIM-VALVE SU00300213 3
ELEMENT, OIL FILTER 90915YZZS1 1
0W20-SINGLE QUART (W 002790WQTE01 7
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
aagun (02-28-2015)
Old 03-06-2015, 02:04 PM   #102
cycleboy
Drives: 2013 Scion FR-S - Argento
I'm going off by sound. So previously before this my car kinda sounded like it would break up around 4-5k... now it doesn't anymore. Throttle response is the same along.. mainly sound is more consistent.
Hmmm, this is making me nervous.
Mine definitely changes tone at 4-5K. In threads about the OFT it was stated to be due to rapidly changing VVT (I think, I can't quite recall) and therefore normal.
I've also noticed a little sound that seems odd/irregular, doesn't happen all the time, is audible from inside, and is coming from the passenger side of the engine bay. It could be a very minor version of the same sound in the video.
cycleboy is offline   Reply With Quote
Old 03-06-2015, 02:07 PM   #103
Don't sweat it! If it doesn't happen all the time it is not likely the same thing as that would not come and go.
These engines make noises that would have me pulled to the side of the road in a second with and old V8 but are just the norm for the boxer!!!
Old 03-06-2015, 09:33 PM   #104
cycleboy
Yeah, I definitely find this to be a noisier off and on car than I've had previously. It still drives strong and feels normal through the rev range, so I have to guess I'm just being paranoid!
[ame="https://www.youtube.com/watch?v=j9gUJq46VXI"]Paranoid live with Randy Rhoads. - YouTube[/ame]
The Following User Says Thank You to cycleboy For This Useful Post:
Tcoat (03-06-2015)
Old 03-06-2015, 10:13 PM   #105
Well there are worse Sabbath songs you could be!
Old 03-06-2015, 11:35 PM   #106
RedEdTed
RedEdTed's Avatar
Drives: Scion FRS, Rocket bunny kit
Mine too!! :o
Hmm.. mine is making some noises too. Only when the car is warmed up about 20 minutes.
Been going on for over 3 months not getting worse so i took it to Toyota to check it out, (no scion dealers near us).
Report from Toyota:
Cause: ticking noise from high pressure fuel pump
Correction: replaced fuel pump as per tsb 3863
Shortly after driving around warming up the engine i hear the noise again.
Back to the dealer next week probably, this time with the car warmed up and hopefully the noise going. I may bring them some of the information on this forum for them to think about :P
Here is a youtube of the noise:
[ame="https://www.youtube.com/watch?v=qIlHnd39iHU"]Scion FRS, Subaru BRZ, Toyota GT86 engine rattle noise after warmed up. - YouTube[/ame]
RedEdTed is offline   Reply With Quote
The Following 2 Users Say Thank You to RedEdTed For This Useful Post:
aagun (03-07-2015), Zzzquil (04-14-2015)
Old 03-07-2015, 02:43 AM   #107
Report from Toyota:
Would like to offer some words of encouragement but that does not sound promising!
If you have a Subaru dealer nearby you may be better off taking it there then a Toyota one that does not deal with the FRS all the time. The Toyota techs may never have had to deal with the boxer engine before and have no clue what they are looking for.
Old 03-07-2015, 03:27 AM   #108
aagun
Drives: 86
Report from Toyota:
this is rocker arm and lifter issues
The Following User Says Thank You to aagun For This Useful Post:
civicdrivr (03-07-2015)
Old 03-07-2015, 06:34 AM   #109
Itzed
Drives: 2014 BRZ Limited
Add me to the list, as of yesterday I started hearing the same noise. 8,500 miles. ��
Itzed is offline   Reply With Quote
Old 03-08-2015, 12:11 AM   #110
N1rve
N1rve's Avatar
Report from Toyota:
Definately sounds like my issue.
My noise only happens when it's warm too and NOT when it's cold.
N1rve
aagun (03-08-2015)
Old 03-08-2015, 09:03 AM   #111
aagun
Drives: 86
yes yes after ride my 86 from highways
Old 03-08-2015, 12:32 PM   #112
Itzed
This is exactly what happened to me the other day. Drove home from Delaware and then at stoplights the noise was terrible. No performance issues at all. Not really wanting to do anything with this yet. The fact that it only happens hot, and happened to me after prolonged high speed driving makes me wonder if it's a VVT issue.
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 09:58 PM
2013 scion frs engine scion123 Engine, Exhaust, Bolt-Ons 16 10-13-2014 09:03 PM
Engine knocking after flash Tenchi Software Tuning 10 09-25-2014 11:50 PM
tapping sound coming from engine forgotten93 Issues | Warranty | Recalls / TSB 11 12-23-2013 09:54 PM
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts ptuning Engine, Exhaust, Bolt-Ons 0 02-04-2013 10:24 AM
