Old 03-06-2015, 09:33 AM   #1
Alq
Drives: 2014 BRZ Limited
Need help deciding
I need help deciding on a lowering kit. I have it narrowed down to ST, Tein, and HKS. Does anyone have any preference over one or the other? HKS is the most expensive, but if I can get the same results with ST, Tein, I'm all for it.
Planning on: Gramlight 57DR 17.9 with perrin spacers 30mm front and 25mm back (or is it the other way around?)
These are the ones I am considering.
ST: model # 90888
Tein Street flex: model # GSQ54-51SS1
HKS Hipermax IV GT: model # 80230-AT001
Goals: I want pretty flush, maybe an 1" drop, but not have to worry about rubbing, and I want the full tire showing, not inside the wheel well.
Thanks for the help,
Alq
Alq is offline   Reply With Quote
Old 03-06-2015, 11:35 AM   #2
shellslinger
Drives: Whiteout FRS
I'm not an suspension expert but you should list the models from each brand you're planning to get so it can narrow down the choices so other knowledgeable people can help you out
shellslinger is offline   Reply With Quote
Old 03-06-2015, 11:43 AM   #3
Alq
Done, thanks!
Old 03-06-2015, 12:51 PM   #4
Racecomp Engineering
Bilstein B8's are a fixed perch strut, not a lowering kit. You are probably thinking of Bilstein B14 coilovers.
You should also post your goals for the car and any other suspension mods you may have. Also what type of tire and what size you'll be running.
- Andy
Koa (03-06-2015)
Old 03-06-2015, 01:34 PM   #5
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Is there a reason you want spacers with 17x9.0? Are you going rocket bunny or over fenders?
Kami Speed is offline   Reply With Quote
Old 03-06-2015, 03:21 PM   #6
Alq
- Andy
Posted.
No I hadn't thought that far.. I guess I'm a noob and don't know anything about tires, what does the 17x9.0 mean exactly..?
Old 03-06-2015, 03:39 PM   #7
CSG David
CSG David's Avatar
Based on the intro post, you may want to continue reading and hold off on any sort of mods.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
Captain Snooze (03-06-2015), finch1750 (03-06-2015), Koa (03-06-2015), Tcoat (03-06-2015)
Old 03-06-2015, 03:45 PM   #8
Alq
I don't want to be a pro at knowing all the lingo, I just want my ride to look good. Is that not possible?
Old 03-06-2015, 03:57 PM   #9
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
You can just go 17x9.0 +38 5x100 57DR without spacers. If you wanted to run stock wheels and spacers than the Perrin spacers will work.
But if you are getting wheels there is no need for spacers unless you are going Rockey Bunny kit.
The Following User Says Thank You to Kami Speed For This Useful Post:
Alq (03-06-2015)
Old 03-06-2015, 03:58 PM   #10
Originally Posted by Alq View Post
Posted.
Not knowing the "lingo" and not having a basic grasp of what you want or need are not the same thing.
I think a little more research on your part is a very good recommendation.
Old 03-06-2015, 04:01 PM   #11
CSG David
CSG David's Avatar
Not knowing the lingo is fine. The community can certainly help you out, but you may want to educate yourself a little bit more before you pull any sort of trigger and end up being one unhappy camper.
The Following User Says Thank You to CSG David For This Useful Post:
Koa (03-06-2015)
Old 03-06-2015, 04:03 PM   #12
Alq
Agreed. And I've already learned a lot! I have a picture in my mind, but don't know the "lingo" to translate that here, trial and error I guess..
Old 03-06-2015, 04:03 PM   #13
Alq
i do know what I want, but can't translate that here. I have a picture in my mind lol :/
The Following User Says Thank You to Alq For This Useful Post:
Tcoat (03-06-2015)
Old 03-06-2015, 04:06 PM   #14
CSG David
CSG David's Avatar
Yes. 17x9 = 17" diameter by 9" wide.
Alq (03-06-2015)
Need help deciding what to mod next OnionTou Scion FR-S / Toyota 86 GT86 General Forum 15 10-18-2014 01:27 PM
Deciding on LCA's. natesparxxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 08-17-2014 01:33 PM
deciding on BBK Reaper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 72 08-09-2014 07:26 PM
Need help deciding on Exhaust DannyFRS Engine, Exhaust, Transmission 1 02-23-2014 05:10 PM
What other car did you consider before deciding on the BRZ? txeng86 BRZ First-Gen (2012+) — General Topics 132 10-30-2013 03:49 AM
