Old 03-04-2015, 12:29 PM   #2311
Kostamojen
I could have sworn at the time I purchased the smallest rear swaybar I could... Must have made a mistake when I bought it :/
Ill track down another bar and try that.
Old 03-04-2015, 01:17 PM   #2312
was385
Drives: MT WRB BRZ Limited, 2007 911s
Have you tried that setup with the stock bar? I would suggest that before spending more on another aftermarket bar. Also, I was reading through and am I correct that your goal is to make a competitive C-street car for autox? If so, aftermarket springs are a no-no.
was385 is offline   Reply With Quote
Old 03-04-2015, 05:28 PM   #2313
Kostamojen
You mean putting the stock 14mm bar back on?
Yes I have. I'm looking for a 16mm bar to try now.
And no I'm in STX
The Following User Says Thank You to Kostamojen For This Useful Post:
was385 (03-04-2015)
Old 03-06-2015, 09:36 AM   #2314
Racecomp Engineering
Originally Posted by PandaBRZ View Post
Hey, guys.
I recently switched from stock wheels and tires to 17x8 wheels and 225/45/17 MPSS. What I noticed is that the traction control light is coming on a lot more on the same canyon roads I used to drive. The weird thing is that I don't feel the car being loose at all. There's no tire squeal and no opposite lock needed to correct when the traction control light flashes.
I got an updated alignment when I got the wheels and tires mounted too. Could the new alignment settings be to blame? Here's the alignment sheet:
That is odd. Your alignment looks good.
Keep us posted.
- Andy
PandaBRZ (03-06-2015)
Old 03-06-2015, 09:38 AM   #2315
I will be in Japan for the next 2 weeks and will not be able to check the messageboard. Myles and/or Larry will be on PMs.
Just giving a heads up...and bragging.
- Andy
Old 03-06-2015, 11:20 AM   #2316
Alq
Drives: 2014 BRZ Limited
What springs would you recommend for ST coilovers? I'm new to all this, I don't know what more information you need.
Alq is offline   Reply With Quote
Old 03-06-2015, 11:21 AM   #2317
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I think they could with springs.. lol ? Do you mean you want to change out the springs for something stiffer, if so then maybe the valving on them wouldn't be ideal as I personally think they're slightly under damped(not sure if spelled right) for their oe springs.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 03-06-2015, 07:54 PM   #2318
troek
troek's Avatar
Drives: 2012 Toyota 86
- Andy
what you got goin on over here?
troek is offline   Reply With Quote
Old 03-06-2015, 09:18 PM   #2319
Mostly vacation, maybe a little "research". Tokyo, Kyoto, Kanazawa, Nagano, Tokyo. March 8 to 18. I'll be solo.
- Andy
CSG Mike (03-07-2015)
Old 03-07-2015, 02:30 AM   #2320
troek
troek's Avatar
- Andy
well have fun, let me know if theres anything you need while your here.
The Following User Says Thank You to troek For This Useful Post:
Racecomp Engineering (03-07-2015)
Old 03-07-2015, 08:51 AM   #2321
What city are you in?
- Andy
Old 03-07-2015, 09:23 AM   #2322
troek
troek's Avatar
- Andy
yamato, its close to yokohama. the tokyo area is small geographically.
Old 03-07-2015, 09:49 AM   #2323
Cool. I may have one free day in Tokyo at the end of my trip.
- Andy
troek (03-07-2015)
Old 03-07-2015, 05:59 PM   #2324
Kostamojen
Ok, got a hold of a 16mm WRX bar. It certainly helped, but the car still just feels a little to lethargic and still not quite balanced.
I'm contemplating two ideas currently:
1. Strano FSB, 16mm WRX RSB (current setup), Bilstein B8 shocks, Group-N front strut top mounts, RCE yellow front springs, RCE tarmac rear springs (I could "test" the spring combos seeing as I have yellows now, just get a set of tarmacs for testing)
2. Perrin 19mm adjustable FSB, Perrin 16mm adjustable RSB, Cusco Touring-A shocks, Group-N front strut top mounts, RCE Yellow front springs, RCE tarmac rear springs
Option #1 is basically zero adjustability minus swapping springs and swaybars. Option two gives a LOT of adjustability for fine tuning the cars balance.
Option #1 has more reliable shocks, the Cuscos in option 2 are an unknown quantity.
Option #2 costs about $500 more due to swaybars and more expensive shocks.
But for right now I'm probably OK for what I'm doing just not perfectly setup for what I'm looking to do.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
