Old 12-29-2014, 04:21 AM   #141
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
is there any where i can send my cluster to have this done?
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 12-29-2014, 10:51 AM   #142
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Originally Posted by ztan View Post
Those of you who have a spare cluster sitting around - is anyone able to scan the faceplate as well as the white backing face at 300dpi so we have accurate measurements on the dials?
Also, can anyone tell me what the size of the Speedo LED cutout (in the white backing mould) is? Wondering about using that to put an AFR or boost display into.
Seconded. I'd love to have a very accurate Scan or to buy a spare from someone.
robot is offline   Reply With Quote
Old 01-02-2015, 01:53 PM   #143
nickw14
Drives: Built FA20
Surface mount LED's are a bitch...
nickw14 is offline   Reply With Quote
The Following 2 Users Say Thank You to nickw14 For This Useful Post:
Pwolf (01-02-2015), SirBrass (01-07-2015)
Old 01-02-2015, 02:48 PM   #144
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
lol.
Helps to put a bit solder on one of the pads first, place the led on it so when you heat up the solder again the led will fall into place and then stay there so you can add a small amount to the other side.
I use my fingernail to hold the LED in place when tacking that first pad.
Pwolf is offline   Reply With Quote
Old 02-25-2015, 12:34 PM   #145
Top-Secret
Drives: FRS monogram
Originally Posted by JHSurf View Post
Sorry took me longer to get the pics than I thought.
To disassemble the Nav HU just release the 10 clips around the front bezel.
Then disconnect the ribbon cable from the front panel. (Circled in red)
Then disconnect the small ribbon cable connecting the control board from the other board. (Circled in blue)
The big board in the front panel has 1 single LED on it. While the small control board has all the LED's for the volume knob and the push buttons.
To remove the large board, remove the 4 screws and disconnect the 2 ribbon cables shown here.
To remove the the control board, remove the volume knob by pulling straight out from the bezel front. Then remove the 7 screws.
this would have been very helpful when i pulled mine apart. tried just going at it with no knowhow and boy did i ever fuck it up. managed to put it back together and dealer replaced it which was nice. probably not going to try it again tho. ill just swap my JVC in which has blue lights already. other then that my car is all done ill try and post pictures later when im home if i remember
i know when i was doing it some people recomended using white lights and tint to get the colors i want.
which i did have to use for certain parts but the color just doesnt seem right coming through a piece of film. no where near as nice as just a color'd LED
@Sportsguy83
as it was stated previously. lighthouse does not make the LEDs in house. some places do but they are usually the cheap ebay brand ones that do die
so for LEDs you are pretty safe to buy from almost anywhere it just comes down to the best price. i was looking for a couple weeks and i found prices as high as $0.83 per which is just crazy. sub $0.30 is about as good as you can get.
i did blue in my monogram
and he has green in his FRS
Top-Secret is offline   Reply With Quote
The Following User Says Thank You to Top-Secret For This Useful Post:
Sportsguy83 (02-25-2015)
Old 03-05-2015, 12:32 AM   #146
Top-Secret
Size:  172.4 KBName:  uploadfromtaptalk1425533559958.jpg
Size:  158.9 KBName:  uploadfromtaptalk1425533569302.jpg
The Following 2 Users Say Thank You to Top-Secret For This Useful Post:
sato (03-07-2015), texasbound972 (12-12-2015)
Old 03-05-2015, 05:20 AM   #147
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by Top-Secret View Post
Very nicely done!!!!! I'm pleased with this.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-05-2015, 09:31 AM   #148
Pwolf
Pwolf's Avatar
Looks great!
Old 03-07-2015, 07:09 PM   #149
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Anyone notice the turn signals indicators on the dash do not seem to be LEDs. Is it possible to upgrade these to green LEDs?
Chad86 is offline   Reply With Quote
The Following User Says Thank You to Chad86 For This Useful Post:
Old 03-07-2015, 10:14 PM   #150
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
@Chad86 they are LEDs, as evidenced by the picture from the OP (I added the red circles around the turn signals):
Sent from my XT1095
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Chad86 (03-07-2015)
Old 03-07-2015, 10:24 PM   #151
Chad86
Chad86's Avatar
Drives: Toyota GT86
Lightbulb
Attachment 104045
Sent from my XT1095
My bad, thanks! I thought they must be incandescent as they blink slow and sort of fade on instead of instant, but that would be due to timing to the actual indicator lights flashing, I assume.
Old 03-07-2015, 10:59 PM   #152
stevesnj
stevesnj's Avatar
is there a breakdown of how many are needed and the HVAC quantity and type for FR-S?
I went through every page and didn't see it. Thanks!
My 2016 Build thread
Old 03-07-2015, 11:04 PM   #153
Pwolf
Pwolf's Avatar
PLCC2 and just get like 20-30 that way you have extras if you want to do anything else (or screw up).
The Following User Says Thank You to Pwolf For This Useful Post:
stevesnj (03-07-2015)
Old 03-07-2015, 11:05 PM   #154
stevesnj
stevesnj's Avatar
thanks
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
