Old 03-02-2015, 04:27 PM   #2199
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Here is a link to aluminum rings I had no idea exist until ^^^^^
http://www.ebay.com/itm/4-Aluminum-H...eae6e1&vxp=mtr
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-02-2015, 04:29 PM   #2200
dtrop
Drives: Wrb 2014 limited brZ
Plastic expands and contracts, can be warped and melted.
dtrop is offline   Reply With Quote
Old 03-03-2015, 03:51 PM   #2201
tazz786
Drives: 2015 scion FR-S
Unhappy
Originally Posted by Killerbee View Post
Either of these will have almost factory dimensions (less than 1% change):
235/40/17 (0.9% off)
245/40/17 (0.4% off)
235/35/18 (0.6% off)
245/35/18 (0.5% off)
These work, but are more than 1% off, so may require adjusting your speedo (depends a bit on local law)
235/45/17 (2.9% off)
245/45/17 (4.3% off)
235/40/18 (3.2% off)
245/40/18 (4.5% off)
i ordered a set of 225/40/18's...how far would that throw the speedometer off?
tazz786 is offline   Reply With Quote
Old 03-04-2015, 05:14 AM   #2202
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Its not that bad, they are 1.9% off and will make a -2% on your speedo (so if you do 100 it will show 98 on your speedo.
But since the factory speedo is anyway not 100% accurate (it always shows a bit more more than you acutally drive) this should work out fine.
Killerbee is offline   Reply With Quote
Old 03-04-2015, 05:22 AM   #2203
tracerit
Drives: '13 SSM BRZ Limited 6MT
went with these: [ame]http://smile.amazon.com/gp/product/B00CH8MDNA/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1[/ame]
although they came in this beet red color
tracerit is offline   Reply With Quote
Old 03-04-2015, 04:56 PM   #2204
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
+1 for hubcentric rings. These are required ... without them the only thing centering the wheels on the hub is lug nuts. I was getting vibrations without them.
B-R-Z is offline   Reply With Quote
Old 03-04-2015, 08:14 PM   #2205
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Hi
I am trying to decide on the following set ups:
1) XXR 527 18x8.75 +35mm offset (225/40/18 Tyre)
-With BC BR Coilovers
Or
2) XXR 527 18x8.75 +20mm offset (225/40/18 Tyre)
-SPC LCA (For a -2 Degree Camber adjustment)
-Rolled fenders
Has anyone tried the second option? I have been looking far and wide, and could not find much on the XXR 527 18x8.75 +20mm
Everyone that went for the +20mm offset rim chose the 9.5J ....
Reason for that being ? Go Big or Go Home? Or is the 8.75J 20mm offset not appealing?
I am trying to figure out if it will be a little more practical than the 9.5J 20mm
(I think I need to learn more about wheel set up)
Your help is appreciated.
FT_86_SM_GP is offline   Reply With Quote
Old 03-05-2015, 11:21 PM   #2206
Codythatsme
Drives: GT 86
Hey guys! Im super noob with wheels and wanting some 527's! I wanted to know what specs I need for the best offset on stock fenders, with a bit of camber on the back! Thanks!
Codythatsme is offline   Reply With Quote
Old 03-05-2015, 11:34 PM   #2207
swarb
Originally Posted by FT_86_SM_GP View Post
Hi
Or
-Rolled fenders
I will poke about 20mm out front and around 15mm out back, you will need 3+ camber if don't want any poke. 8.75 +35 is considered the flush setup for these wheels.
18x8.75 +35mm
Old 03-07-2015, 08:21 AM   #2208
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Anybody wanna trade their flat black 18x8.75 et33 XXR 530's for my chromium black?
Old 03-08-2015, 03:30 PM   #2209
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
Installed mine!
XXR530 18x8.75 +33
Hankook Ventus V12 Evo2 K120 245/35/ZR18
golfyankee2121 is offline   Reply With Quote
The Following User Says Thank You to golfyankee2121 For This Useful Post:
ericmpena (03-08-2015)
Old 03-10-2015, 12:38 PM   #2210
balla_08
Drives: Satin Pearl BRZ
So my set up Im looking into is 18x8.75 +35 with 235/40 on eibach pro kits
Do I need spacers in the rear? Ive also heard to get some different center caps? Thanks for the help..
balla_08 is offline   Reply With Quote
Old 03-10-2015, 12:44 PM   #2211
Takumi788
JHerbert Racing
Takumi788's Avatar
You don't need new center caps but the ones included are awful looking. No spacers are needed for that size. I run the same size with similar springs. Check out my build thread in my signature for more info. If you were closer I would try to sell mine to you.
Old 03-10-2015, 02:33 PM   #2212
balla_08
That would be too convenient haha
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
