Old 03-03-2015, 08:30 PM   #15
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Looks interesting, but the overall layout and design makes it pretty obvious where it was derived from. I'm not saying that's a good or a bad thing. I like the Tial Wastegate and BOV, but do not like the non-recirc dump tube.
What type of thermal coating is on the charge pipe? It looks like wrinkle black paint.
Any specs on the turbo?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 03-03-2015, 09:09 PM   #16
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Drift-Office View Post
Not sure about that since it's up to us as the installer to look out for that sort of thing. We've done 2 kits, this one the 6MT doesn't show any signs of "a bad time" while the other, a 6AT drove from Seattle to LA to MI and it doesn't have any issues with the harness that you speak of.
Bob @ Drift-Office, LLC
http://www.driftoffice.com
Fair enough, as I mentioned, the pipe i had experience with was catted and that put it an inch closer to the harness and hotter than a cat-less pipe would be.
As you said, If people want thermal insulation they can have thermal insulation
BTW, looks like a vary nice kit, glad they took your feedback and revised the offering.
The Following User Says Thank You to mad_sb For This Useful Post:
Drift-Office (03-03-2015)
Old 03-04-2015, 02:56 AM   #17
extreme-86
Drives: 86, Nissan 200SX, Honda Civic
@Drift-Office, what are the specifications of the turbo used ? Is this the billet wheel TD05 20G ?
extreme-86 is offline   Reply With Quote
Old 03-04-2015, 06:12 AM   #18
Knickstape
Knickstape's Avatar
Drives: '13 FR-S (Asphalt)
Originally Posted by Jmonty View Post
what would this kit, install and a tune run?
I'd like to know as well
Opti-Guard, 35% Tint, Perrin 2" Antenna, Helix Side Markers, Valenti Tails, Carsmo Armrest, LED DRL Strip // UniChip, Perrin CAI & Inlet Tube, Perrin Cat-Back Exhaust, Grimmspeed Super-Loop Header.
Knickstape is offline   Reply With Quote
The Following User Says Thank You to Knickstape For This Useful Post:
Jmonty (03-04-2015)
Old 03-04-2015, 08:09 AM   #19
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Whoa you can run this kit catted?
Alltezza is offline   Reply With Quote
Old 03-04-2015, 10:49 AM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
[*]Reducing boost creep common in current offerings by running the wastegate pipe directly into the header. More commonly, other kits are internally gated.
This is my favorite line. Makes it sound like an open dump tube is a huge innovation.
Old 03-04-2015, 03:12 PM   #21
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
It's not, but then again, it's also not offered on the other kits.
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
DriftinFRS (05-11-2015)
Old 03-04-2015, 03:33 PM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Define other kits? My favorite one uses an external wastegate and has an open or recirculated dump option. Which kits are you seeing boost creep on?
Old 03-04-2015, 03:48 PM   #23
Drift-Office
Originally Posted by protpibe View Post
I like the Tial Wastegate and BOV, but do not like the non-recirc dump tube. Any specs on the turbo?
A Non-Recirc option is available, I just didn't go that route.
It's a TD05 compressor housing with an 11 blade billet wheel with a custom 12 blade wheel... this is from Hexon in regards to specifics :
  • Compressor Size 56/49mm
  • Trim 55
  • Turbine Size 68/50.5mm
  • CFM 590
  • A/R 60
Purportedly, it uses "a BN Bison nitrite thermal coating and mixed with zirconium oxide, titanium dioxide and surface finished with wrinkling paint."
^^^I don't know what all that shit means to anyone else, but to me - it certainly helps with keeping the IATs cooler!
Why not? Just not at very high boost! (<10PSI)
Regards,
Old 03-04-2015, 03:50 PM   #24
Drift-Office
Greddy and the like, we are talking about that family of 4 commonly produced kits in this case. I've even seen them on other top mounted setups not within that specific 4.
Old 03-06-2015, 09:17 PM   #25
Drift-Office
[ame]http://youtu.be/SO1OF10x1qY[/ame]
This from my recent remote tuning session...
JohnJuan (03-09-2015)
Old 03-25-2015, 10:44 PM   #26
TKShu22
Drives: 2013 WRB BRZ
Any new info or updates?
TKShu22 is offline   Reply With Quote
Old 03-25-2015, 11:26 PM   #27
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
What fuel was used for the dyno run above?
Lawnik is offline   Reply With Quote
Old 03-27-2015, 04:25 AM   #28
Drift-Office
A few short weeks later, we had installed our first HEXON RR350 kit and these were the results on a 6MT 92 Octane setup...
Hope that answers your question.
Lawnik (03-27-2015)
HEXON RR350 TURBO KIT || Racing for Research hexonracing Forced Induction 22 01-04-2015 12:40 PM
Hexon RR350 turbo kit FRS-HHH Forced Induction 37 04-20-2014 05:22 PM
Drift-Office : AVO Turbo Stage 1.5 @ 8 PSI & Tomei 3 Inch Exhaust... Drift-Office Forced Induction 32 11-14-2013 02:40 PM
Drift-Office : Introducing "86 Nights!" Drift-Office Northwest 84 09-19-2013 11:26 PM
Drift-Office : AVO Turbo Kit Stage 1 ~ 91 Octane Calibration Drift-Office Forced Induction 30 04-18-2013 03:25 PM
