#2297 |
Drives: 2013 Firestorm FR-S
Well, it's still too cold for autocross here in Illinois. Some of us still managed to get our racing fix though!
Getting a little oppo in the middle of a frozen lake with @G_Ride! ![]() (Photo Credit: Roberto Perez http://rpphotography11.blogspot.com/) More pics from the event here: http://oppositelock.jalopnik.com/ral...ump-1689055517 Also picked up these for the upcoming season. Thanks again, @TRev! ![]() Space is starting to become an issue though. :P
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#2298 | |
Drives: Toyobaru FRZ
What do you guys use for 'Employer Identification Number' when filling out the W9? |
#2299 |
Drives: JAWS
If you don't have an EIN usually I believe your Social Security number is what you'd put.
#2300 |
Drives: 4 wheels
#2301 | |
Drives: Some kind of Subaru
![]() It was also good to meet @TRev in person. |
#2302 |
Drives: 2013 FRS
Likewise I ran the Primacy's at my second event with the car in 35 degree temps and took second in class to a two driver (helped to heat tires up) M3 on RS3s. My only other mod was camber bolts. Pretty much the entire class of 11 cars was on "better" tires. In my opinion the Primacy's are better tires than most people give them credit for.
#2303 |
The Stig's German cousin
My big gripe with the Primacy was the upper end of its heat range was far too low for my climate. By 2nd run they would be greasy. By 3rd run the car was so loose I thought I broke something and abandoned the run - to date the only time I've been scared in this car. Begged for a water sprayer before my 4th run and it got better but still required a lot of wheel work to keep pointed the right way.
You do learn a lot about the car on that tire, and it's probably a good tire for conditions where you won't exceed its heat range. In 40 degree weather, I'd still prefer a "real" tire plus some tire covers between runs, and then I'd use my first couple of runs strategically to work on tire temps. |
#2304 |
#2305 |
I know this has been discussed a lot, but I'm still back and forth on it.
235/45 vs. 245/40 ZII*, is the extra 1/2" of tread width worth it? I know 245/40 is a lot of tire for a 7" wheel, but these are going to be used almost exclusively for autocross events and to drive to/from the events. They MIGHT see some other road use for club cruises this year, but I'm not 100% on that yet. This is my first time buying a good set of performance tires for any sort of racing, so all input is appreciated. I'm trying to be fairly competitive this season, locally, and run at least one national event.
#2306 | |
i'm sorry, what?
Drives: Canada
it's not really the weight issue you should be worried about, but the response. against all conventional logic the 245 seem to deliver the most absolute grip at the expense of response, this means to truly utilize their potential you're gonna have to be very trusting of the car and your inputs, because you're not gonna get quite the same feedback and generally feel like the car is being unresponsive
#2307 | |
I actually made some edits to my post. I'm looking at 235/45 vs 245/40 and realized that the weight is the same, at least according to tirerack.
#2308 |
Senior Citizen
Drives: Scion FR-S
45 profile on Dunlop was reported to be "floppy" in the past Z2s. Hopefully the SS are stiffer. I have run the 245/40 and they work fine. 235/40 would feel the best, imo...but just can understand why they cost so much!!!
#2309 |
Yeah, I was thinking about those but that $100 price jump is pretty ridiculous. Granted, I've never driven on really nice tires so anything is going to feel a lot better to me coming from Primacy HPs. haha
#2310 |
For me, the biggest consideration of 245/40 and 235/40 is the change in gearing. 235 is shorter and will accelerate better but will have lower top speed than the 245/40. On a tighter course where you don't hit the rev limiter the 235 will be better. On faster courses a 245 may save you from a shift or riding the rev limiter as long.
Between the two, I would lean 235/40. Both the 235 and 245 will be pinched, so effective contact patch probably isn't all that different. With the 235s you get the benefit of shorter gears accelerating out of every corner while the 245s taller gearing only becomes a factor at the very top end. As noted earlier, the better response of a 235/40 is a nice plus too. And this is coming from someone who just got 245/40 RS3s. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
