Old 10-16-2014, 06:17 PM   #29
hattrickey
Drives: Scion FR-S
Originally Posted by ka-t_240 View Post
17x9 +42 Rota Titan Hyperblack
-Center Caps do not fit due to hub-centric rings.
245/40/17 BFG Rivals
Stock Suspension/Stock Alignment
No Rubbing/Issues/Ect
Welp, I think you just convinced me to get these for my Asphalt 86. Looks great!
hattrickey is offline   Reply With Quote
Old 10-16-2014, 11:49 PM   #30
Whats that smell?
Whats that smell?'s Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by MidnightRunner View Post
If you get Titans in with a 17x9 +45 offset, you will have a problem like this guy:
http://www.ft86club.com/forums/showthread.php?t=48453
If you do like he did you could do a 3mm spacer to get the offset down to 42. Then again, the titans come in 42 offset already so you'll be fine with the 42 and some 1" lowered springs.
Thanks man i appreciate it.
Whats that smell? is offline   Reply With Quote
Old 10-17-2014, 12:04 AM   #31
eera
Are these the Titans? Thanks
eera is offline   Reply With Quote
Old 10-17-2014, 12:12 AM   #32
MidnightRunner
MidnightRunner's Avatar
Probably xxr527
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 10-17-2014, 07:56 AM   #33
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Yep XXR Titans don't have multiple lug nut holes.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 03-02-2015, 04:06 PM   #34
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by yomny View Post
Titan 17x9 +42 with Nitto 555 255/40R17 squared, i wish i would have gone with 245 but i got a good offer to pass on the nittos.
PLEASE re-post these pics! I am thinking about selling my xxr 527 and getting these and this is the tire size I want.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-02-2015, 04:15 PM   #35
yomny
yomny's Avatar
Just know.. that at my height they rub inside a tiny bit when turning full lock left. Then again these nitto's seem to have a fatter sidewall than most tires.
http://www.ft86club.com/forums/showthread.php?t=82188
For now, as I cant access photobucket from work to repost. I'll fix later.
Old 03-02-2015, 04:20 PM   #36
yomny
yomny's Avatar
The Following 4 Users Say Thank You to yomny For This Useful Post:
Easy (05-25-2015), hmong337 (12-27-2015), MidnightRunner (03-03-2015), slow15frs (12-04-2016)
Old 03-03-2015, 12:41 AM   #37
Argento_86
Drives: fr-s
lovin your setup yomny
Argento_86 is offline   Reply With Quote
The Following User Says Thank You to Argento_86 For This Useful Post:
yomny (03-03-2015)
Old 03-03-2015, 06:24 AM   #38
yomny
yomny's Avatar
I was debating if I should go with black rpf1's or silver. I rather like the black in white scheme.
Old 03-03-2015, 01:00 PM   #39
MidnightRunner
@yomny
Amazing looking setup. Btw was that the FAU parking garage?
The Following User Says Thank You to MidnightRunner For This Useful Post:
yomny (03-03-2015)
Old 03-03-2015, 03:21 PM   #40
yomny
yomny's Avatar
@yomny
Thanks, appreciate it. No, I'm outta school already.. I'm usually down by the kendall/dadeland area.
Old 05-01-2015, 10:00 AM   #41
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
Has anybody seen these in Hyperblack on a silver car? I can't seem to find pics of this setup in any of my searches. TIA!
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
Old 05-20-2015, 08:15 PM   #42
toast
Drives: 14 BSP Edelbrock BRZ
17.8 lbs keeps floating around on the forum for the weight of these. Where did that come from? I just got a set in 17x9e42 and they weigh 18.8 lbs according to my postage scale. With my 245/40R17 Hankook Ventus V12 they weigh 42.2 per corner.
toast is offline   Reply With Quote
Wheel Directory: Rota MXR 18x9.5 +38 jonbatz01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-19-2020 02:57 AM
Wheel Directory: Rota Grid 18x8.5 +44 Cjymiller Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 09-05-2016 10:42 PM
Wheel Directory: Rota RKR 18x8.5 +38 / 18x9.5 +38 jsc1234 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 05-30-2014 10:06 PM
Wheel Directory: Rota RT5 17x9.0 +30 b-25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 02:21 PM
Wheel Directory: Rota GR-A 18x7.5 +48 pro_djke Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 02:06 PM
