Old 02-04-2015, 10:50 AM   #2185
Timmy_Jones
Spun
Drives: 23' Supra
Originally Posted by Mad1723 View Post
Yes. There was a picture of each concavity with each width, but don't have time to find it right now.
Thank you, I searched as well, to no avail.
Timmy_Jones is offline   Reply With Quote
Old 02-04-2015, 10:51 AM   #2186
Timmy_Jones
Spun
Drives: 23' Supra
Here is a comparison of a different design: [ame="https://www.youtube.com/watch?v=WAwHp00Q7z4"]XXR 530 Concavity - YouTube[/ame]
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Mad1723 (02-04-2015)
Old 02-27-2015, 03:48 AM   #2187
tracerit
Drives: '13 SSM BRZ Limited 6MT
http://www.ebay.com/itm/SUBARU-ALLOY...item3aa348d33f
would those melt right off? they look just like regular stickers rather than the "bubble" type emblems.
tracerit is offline   Reply With Quote
Old 02-27-2015, 05:47 PM   #2188
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Anyone got the new XXR 550 series 18x8.75 +35 on their rides? Any pictures with the rims on their rides?
Thanks
FT_86_SM_GP is offline   Reply With Quote
Old 02-27-2015, 06:07 PM   #2189
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Thanks
http://www.ft86club.com/forums/showthread.php?p=2144288
The Following 2 Users Say Thank You to ZOMFGAARON For This Useful Post:
Bimble Bamble (03-28-2015), FT_86_SM_GP (02-27-2015)
Old 02-27-2015, 06:49 PM   #2190
FT_86_SM_GP
Drives: Lawn moweR
Originally Posted by ZOMFGAARON View Post
Thanks! Also found out that its similar design to the following:
Enkei RS055RR
http://www.ft86club.com/forums/showt...hlight=RS055RR
Old 02-27-2015, 10:47 PM   #2191
tazz786
Drives: 2015 scion FR-S
Just ordered 527's in Flat Black for my Firestorm FRS. I went with 225/40/18 tires and ordered some Eibach prokit lowering springs. Has anyone had any kind of problems at all with this set up yet? i read something about the rim catching during drive thru car washes? :/
tazz786 is offline   Reply With Quote
Old 02-27-2015, 11:03 PM   #2192
swarb
What size did you get? You should be ok if you did not get 9.75 and/or +20 offset. 8.75 +3X should be good to go. Don't go to drive thru car washes if you care about your paint. Side mirror and wipers always get torn up.
Old 03-01-2015, 01:23 PM   #2193
tazz786
I got 18x8.75 +35 all the way around with 225/40/18's. What exactly do I need to do to make the rear flush with the front on this set up? lowered on Eibach Pro Kit
1. I know i will need a spacer but which one? 5mm or 10mm?
2. would it be cheaper to get camber bolts or spacers?
the spacers seems expensive especially the 10mm ones. does anyone know where i can find them for cheap?
3. With spacers will i need the extended bolts? sorry guys im a newbie :/
Old 03-02-2015, 10:54 AM   #2194
tazz786
anyone?
Old 03-02-2015, 11:19 AM   #2195
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I have the same setup except hotchkis springs and 235/40/18 tires meaning my tires are wider than yours.
1. I have room to accommodate a 5mm spacer to help with oversteer at autocross. You should be plenty fine with a 10mm.
2. Camber bolts are not going to make your wheels "flush" if that's what you are looking for. Negative camber helps people with tires that are to big tuck them under the fenders. Sounds like you want spacers. You gotta pay to play brother. Don't go cheap. The twins are to new for that.
3. Yes extended studs are required.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-02-2015, 01:52 PM   #2196
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
@parko061's rockin' the new 550's, trying to set up a shoot soon.
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
The Following 2 Users Say Thank You to jedichimp For This Useful Post:
BlueDubbinTDI (03-07-2015), trigger happy (03-31-2016)
Old 03-02-2015, 02:16 PM   #2197
Takumi788
JHerbert Racing
Takumi788's Avatar
PSA:
Buy hub centric rings with these wheels! I had small vibrations and figured for $7 bucks I would give them a try. They work great and they are stupid cheap.
http://www.ebay.com/itm/like/1514214...lpid=82&chn=ps
Old 03-02-2015, 04:18 PM   #2198
dtrop
Drives: Wrb 2014 limited brZ
Originally Posted by Takumi788 View Post
PSA:
PSA:
Spend a little more and buy aluminum, don't buy plastic.
dtrop is offline   Reply With Quote
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
