Old 03-02-2015, 01:05 PM   #15
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
Originally Posted by lsxiong View Post
Ask Walter White to make you a batch.
Originally Posted by DaJo View Post
Please back away from the 86... Better do your research before destroying the poor car.
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
The Following User Says Thank You to fatalelement For This Useful Post:
sato (03-03-2015)
Old 03-02-2015, 03:45 PM   #16
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Ya, if you want to blow up.
V_86 is offline   Reply With Quote
Old 03-02-2015, 03:57 PM   #17
fika84
fika84's Avatar
Do they let you google this in China? Or you just want other people to do your research for you? You could probably find a company in China that makes something...
fika84 is offline   Reply With Quote
Old 03-02-2015, 04:04 PM   #18
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by luckykevin View Post
Hi everybody, I knew E85 fuel will more powerfull and less pollutions, but I can't buy E85 anywhere in China.
Can I making E85 through a mixture of gasoline and alcohol by myself ?
Mix one 55 gallon drum of pure Ethanol with 10 gallons of race gas and there you go.
And then you can run it in your car with nothing but a tune. (you trust the words of some unkonwn person on the internet dont you?)
Luckily you are not in the US.
If you mentioned that you were blending your own gas here, the police would shut you down.
There are laws against making your own fuel in the US.
Old 03-02-2015, 04:17 PM   #19
HunterGreene
Hail Magnet
HunterGreene's Avatar
I am pretty sure that Google in China isn't quite the same as Google in the US...
It has priests in it?
Old 03-02-2015, 04:36 PM   #20
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
The direct answer to your question is yes, you could make your own E85 although it is far more than mixing gasoline with alcohol. It is very likely you could not afford the required equipment to do it and it may not be legal in China.
As many others have noted, the corrosive nature of E85 makes a flex fuel kit a necessity.
ntron1 is offline   Reply With Quote
Old 03-02-2015, 04:51 PM   #21
AznBRZer
Drives: 16 CBS WRX Limited
I'm guessing this kid's parents have the money, but this kid has none of the sense to make it (not) happen.
AznBRZer is offline   Reply With Quote
Old 03-02-2015, 05:00 PM   #22
stugray
Not according to many on this forum that have been doing it for over a year with no flex fuel kit at all.
http://www.ft86club.com/forums/showt...=flex+fuel+OFT
Old 03-02-2015, 05:05 PM   #23
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
actually there is no google in china.........it's blocked.
They have their own version of it thou........with good stuff all FILTERED. Call weibo or somthing...
Old 03-02-2015, 05:18 PM   #24
kch
Senior Misanthrope
kch's Avatar
As far as I know, the flex fuel kits don't change out any major parts of the fuel system; they only add in an ethanol content analyzer. So the flex fuel kit doesn't address the corrosive nature of E85 at all (if it even needs to be addressed--time will tell.)
Old 03-03-2015, 09:26 AM   #25
fika84
fika84's Avatar
... hence the question...
Old 03-03-2015, 09:58 AM   #26
HunterGreene
Hail Magnet
You're thinking of their version of Twitter. I have no idea who their primary search provider is.
Old 03-03-2015, 10:35 AM   #27
luckykevin
luckykevin's Avatar
Drives: 2013 Subaru BRZ Automatic
Google is blocked in China. We must use VPN to access google.
luckykevin is offline   Reply With Quote
The Following User Says Thank You to luckykevin For This Useful Post:
Sportsguy83 (03-03-2015)
Old 03-03-2015, 10:44 AM   #28
fika84
fika84's Avatar
Gotcha! Ain't that some *&^(. That explains the asking of the question! As others have stated, yes you can do it.. is it simple? Not from what I've seen. I would work without it if I was you. Can you do a meth injection as a work around?
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
Making the switch to Ethanol, Flex Fuel Video Inside.... spdbydesign Forced Induction 0 05-23-2014 11:07 PM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
