Old 02-27-2015, 09:23 PM   #1317
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by Lee@JDLAutoDesign View Post
The "lip" created by the mismatch in diameter acts as a forward facing step that the flow has to go up, over and around as it enters the overpipe. This causes a really messy flow field with significant regions of reversed flow. To combat the reversed flow the flow in the center of the pipe has to accelerate, so you end up stretching and distorting the flow field, which creates all sorts of nasty acoustic disturbances at a wide range of frequencies (think of the sound a compressor makes when it surges).
Here is a CFD model I made some time ago showing 2D velocity contours of flow from a plenum entering a runner with a 0.090" radius on the entrance. In this case the flow moves from left to right. You can see that the flow in the center of the runner is accelerated and large separation bubbles form on the sides of the runner. This case is a little bit different because the diameter ratio of a plenum/runner is much larger than a collector/overpipe, but hopefully this will make the effect a bit more ~tangible.
Will any aftermarket over pipe have the same diameter? Also can you comment on the heat issues people are having with the fan shroud? Is an uncoated header going to destroy that?
was385 is offline   Reply With Quote
Old 02-27-2015, 10:59 PM   #1318
CTB727
Drives: 2013 Subaru BRZ
Originally Posted by weederr33 View Post
As I purchased the EL headers, too. This is a bit concerning for me. I didn't realize it would come so close. Do you have any sort of thermal coating on the headers?
Yeah, I have the titanium coating.
Originally Posted by BatStig View Post
The driving isn't going to be an issue. It's the standing still with no airflow that will be the problem.
My shroud did get a little melted, nothing serious, but that was after a session on the track. Now I just make sure to open the hood after a session and everything is wonderful.
I'll keep that in mind between autox runs. So far my shroud seems to be in good shape.
p.s. Your car sounds amazing in those YouTube videos. It convinced me to get EL over UEL
CTB727 is offline   Reply With Quote
The Following User Says Thank You to CTB727 For This Useful Post:
BatStig (02-28-2015)
Old 02-27-2015, 11:21 PM   #1319
Lee@JDLAutoDesign
Lee@JDLAutoDesign's Avatar
Drives: Corrado
Any aftermarket X.XX" pipe should be the same, give or take the material thickness. At any rate, you wont see an issue like this unless you have a gross difference in size with the downstream pipe being the smaller of the two.
The EL headers i have seen in person didnt seem to have any clearance issues. Ill ask Ronnie and/or Jesse to comment on this since they have personally installed quite a few. Youre fighting radiant heat here so heat shields, reflective tape, etc can all be very effective
Lee@JDLAutoDesign is offline   Reply With Quote
Old 02-28-2015, 05:08 PM   #1320
was385
Alright sounds good. My concern at this point is if the guys with thermal coatings are having this issue, does that mean it is pretty much necessary to get a coating on top of the reflective tape, etc?
Old 03-02-2015, 09:56 AM   #1321
was385
I've been thinking more about this and are we going to see the same effect on any stock component or is it just the overpipe? Said another way, if we have the JDL header and then switch out to a 2.5" aftermarket overpipe, are we going to have the same issues with the overpipe to stock front pipe flanges?
Old 03-02-2015, 12:04 PM   #1322
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
It'll be with any stock component except for the midpipe because of the way the midpipe is made where it meets the frontpipe.
What I did to kill the fluttery/wooshy noise was use a 2.25" overpipe so the steps between pipes weren't as bad, then I ported the factory frontpipe flange and removed the silly gap you can see between the pipe and flange:
Once I went with 2.5" all the way to the midpipe the fluttery/wooshy noises went away and I'm left with just the sound of the exhaust rushing through the pipes.
Old 03-02-2015, 12:10 PM   #1323
was385
Alright thanks. The modification of any of the exhaust components is beyond me so going with a slightly smaller diameter OP may just be the best option as I'm not willing to spend the money to change out the front pipe. Didn't really want to do the OP but I guess I'll have to.
The Following User Says Thank You to was385 For This Useful Post:
jonkim2 (03-02-2015)
Old 03-02-2015, 04:17 PM   #1324
jonkim2
Drives: Raven FR-S
Pretty much in the same boat. Thanks everyone for your input
jonkim2 is offline   Reply With Quote
Old 03-02-2015, 05:22 PM   #1325
kch
Senior Misanthrope
kch's Avatar
So it looks like I should order an OP/FP to go with my UEL header (if it ever comes--the wait is killing me).
If I order an OP/FP now, will they take another 2-3 months, or do those move faster?
Old 03-04-2015, 06:58 AM   #1326
leoh007
leoh007's Avatar
Drives: 2014 Monogram
Originally Posted by 2016 Camaro SS View Post
Running the JDL UEL, JDL OP, and JDL catted FP, fitment was absolutely perfect. Even the custom flange to mate with the Perrin catback. Not a single leak, all Grimmspeed gaskets.
You wouldnt happen to have a video would you? This is a similar setup that Id like to use, except I have a Motiv Overpipe. Not sure about Motiv's Catted front pipe since they have the flange that seems to give people problems with the Perrin CBE from what ive read on this thread. Any insight to what Front pipe I should buy? I have an Automatic, not sure if that makes a difference
leoh007 is offline   Reply With Quote
Old 03-04-2015, 07:00 AM   #1327
leoh007
leoh007's Avatar
Just purchased my Uncatted UEL!!! Cant wait! Order Number #1472. Any idea when I would receive my item? Called and was given a 4 week lead time
Old 03-04-2015, 07:49 AM   #1328
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Might be even longer. I'm just setting your expectations properly. I would give it about 6 weeks. You will have to be patient, but it is worth the wait.
I do not have a video of my setup yet, but I will try to get one up. This is the setup I'm going to stick with for a long time.
2016 Camaro SS is offline   Reply With Quote
Old 03-04-2015, 02:09 PM   #1329
kch
Senior Misanthrope
kch's Avatar
I ordered on 12/22 and am still waiting. Their bender is apparently having issues and has really dropped the ball.
Old 03-04-2015, 05:21 PM   #1330
leoh007
leoh007's Avatar
I just received my invoice number #590. what number were you? I really hope it doesnt take 3+ months to receive this
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
