#15 | |
Drives: 1966 Mustang, 2013 FR-S
#16 |
Drives: WRB BRZ
Got my parts in and installed the mirror last night.
H501SAJ010 is indeed the correct harness. H501SAG040 was not the correct harness cover. The mirror and headliner connections are correct, but it is too long. I had to make it about 3/4" shorter to fit. Not a big deal, but there must be another part number that doesn't require modification. |
#17 | |
#18 |
Drives: 2013 BRZ Limited
Subscribed. Selling my HomeLink mirror from my BRZ on ebay.
#19 |
Drives: FRawSome Hot Lava
H501SAJ010 is correct harness if harness in mirror has 12 pins.
I got Gentex 453 mirror from Prius and it has 10 pins , so for me that Subaru harness did not work.Now I am looking for 10 pin connector (with 3 wires coming in)
#20 | |
On the Subaru harness, looking at the back of the black connector where the wires go in, the first wire on the left is ignition, then the 2nd is reverse, skip one & the other wire is the ground wire. For the wiring on the 14 pin white connector, in this picture: http://i.imgur.com/oTwxgzG.jpg?1 , the wires from left to right are (pins 1-7): Ignition (yes, the black wire is the ignition wire!!) / Ground / Reverse / Outside dimming mirror + / Outside dimming mirror - / camera video - / camera video +. For the bottom row of wires, in this picture: http://www.tacomaworld.com/forum/att...217_161557.jpg, from left to right (pins 14-8): Camera power (6 volts), camera ground, digital temperature sensor input (if your mirror even has temperature display...the 12-13's did, but I don't think the 11's had it), purple wire - unknown, yellow wire = constant hot (homelink power). |
#21 | |
Drives: 13 FRS
| Homelink mirror mount | [deleted] | Issues | Warranty | Recalls / TSB | 4 | 04-29-2015 12:06 PM |
| WTT: BRZ Homelink Mirror for Frameless Mirror | cmspooner | Interior Parts (Incl. Lighting) | 6 | 01-23-2014 12:32 AM |
| SOLD: Homelink Mirror | TommyFive | Interior Parts (Incl. Lighting) | 9 | 06-10-2013 02:03 PM |
| WTT: my dimming/compass mirror for your HomeLink mirror | Apecks | Interior Parts (Incl. Lighting) | 0 | 04-07-2013 01:24 AM |
| How to install Homelink mirror? | Grimlock | Electronics | Audio | NAV | Infotainment | 10 | 06-10-2012 07:07 PM |
