Old 02-18-2015, 06:46 AM   #351
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by Koa View Post
streaming music via bluetooth is godly. I listen to a lot of soundcloud and that app does not stream through the usb port.
Mine does, but I'll have to try over BT
0351USMC is offline   Reply With Quote
Old 02-18-2015, 07:01 AM   #352
chubky
chubky's Avatar
Drives: 2014 Scion FR-S Monogram
You can actually stream through the usb. The trick is to get the radio to start playing music normally with it plugged in then switch to the app you want to play through the speakers. You might lose some functionality with the buttons on the stereo and end up having to control through the phone.
Probably better to just use bluetooth with the phone plugged in to charge but thought I'd at least throw that out there.
chubky is offline   Reply With Quote
The Following User Says Thank You to chubky For This Useful Post:
Strife26 (02-19-2015)
Old 02-21-2015, 12:11 AM   #353
PatSciFRS
Drives: Scion FRS 10 Series
Are you using an Android phone? Because the manual says that Android phones stream through Bluetooth while iPhones stream via the USB. I use an Android phone and I can play all the MP3 music stored on my phone through the USB controlled by the car's radio, but I can only stream music through Bluetooth. If you don't mind please tell us exactly how you get streaming Android Pandora or similar app to go through the USB port.
PatSciFRS is offline   Reply With Quote
Old 02-21-2015, 02:31 AM   #354
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by Hot Lava View Post
if you hold the right pedal all the way down for more than 10 seconds red and blue party lights will illuminate the interior.
Because the car just hit 60mph?
Sorry, couldn't resist.
Uplink is offline   Reply With Quote
The Following 4 Users Say Thank You to Uplink For This Useful Post:
fatalelement (02-21-2015), Hot Lava (02-21-2015), meWant (02-28-2015), PBlack09 (02-27-2015)
Old 02-21-2015, 04:09 AM   #355
0351USMC
0351USMC's Avatar
You can stream on iPhone over BT BUUUUUT it's not as loud and not all the signal comes thru (I.e. No bass).
Old 02-21-2015, 06:23 AM   #356
chubky
chubky's Avatar
I'm using an iphone, but try turning your bluetooth off. Plug into USB get music playing through USB, then just launch Pandora and get that to start playing. That's what I had to do on another HU to get pandora to load. But again, I've got an iphone
Old 02-21-2015, 06:39 AM   #357
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Not every android phone has capabilities to do audio though USB.
What phone do you have?
Old 02-22-2015, 09:06 PM   #358
Uplink
Uplink's Avatar
Originally Posted by Ammunition View Post
Drove me crazy the other day seeing the worker at the gas station do this to my car instead of putting it in the hanger.
It's illegal to pump your own gas here - biggest BS law ever, my mom had a $62 bill from Toyota once for her 4Runner because she had to get the engine checked when the maintenance light went on because the idiot at the gas station didn't tighten the cap enough.
We have a different location for the gas cap over here. It's between the frame and trigger on the gas nozzle since most of the self service stations disable the auto-fill lock to prevent dumb people from spilling gas.
Old 02-27-2015, 08:14 PM   #359
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
Torsen Exhaust
The stock exhaust comes with Torsen variable thrust exhaust nozzles. When turning into corners the VCM adjusts exit velocity between the two exhaust nozzles. As you turn into a corner the inside exhaust is closed using a Wankle shutter valve adjusting the exhaust thrust to the outside corner providing cornering assist. The system uses inertial, engine output, gear selection and wheel position sensors to fine tune the thrust vectoring.
Rumor has it that Perrin is working on an aftermarket Torsen variable thrust exhaust system. Until they or some other vendor releases an alternative I'd highly recommend staying with the stock exhaust.
Hot Lava is offline   Reply With Quote
The Following 8 Users Say Thank You to Hot Lava For This Useful Post:
driftguy (02-28-2015), Loetke (02-27-2015), meWant (02-28-2015), MJones_RB (07-13-2015), pfaffendorn (05-08-2016), pushrod (02-27-2015), Teseo (02-28-2015), Ultramaroon (03-09-2015)
Old 02-27-2015, 10:42 PM   #360
Lischynski
Weendog
Lischynski's Avatar
But isn't it more restrictive? The gain from that method the stock exhaust uses probably doesn't match the help you get from an aftermarket exhaust, especially if you go with a full 3" system.
Old 02-27-2015, 10:48 PM   #361
Andrew025
Andrew025's Avatar
Oh boy... Not sure if serious...
Old 02-27-2015, 10:58 PM   #362
Lischynski
Weendog
Lischynski's Avatar
What am i missing here? No need to be a ****.
Old 02-27-2015, 11:02 PM   #363
Andrew025
Andrew025's Avatar
He made all that shit up.
I wasn't being a 4 star general either.
Old 02-27-2015, 11:07 PM   #364
Lischynski
Weendog
Lischynski's Avatar
No he isn't. I found a chip inside of the OEM donut gasket, I'm pretty sure that relays the data he is mentioning from the ECU.
The Following 3 Users Say Thank You to Lischynski For This Useful Post:
driftguy (02-28-2015), Hot Lava (02-28-2015), Ultramaroon (03-09-2015)
scion brz hidden features
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 02:14 PM
Bespoke A/V Hidden Option UbSaMrC Electronics | Audio | NAV | Infotainment 58 12-14-2015 12:14 AM
FS: Custom Stainless Lightweight Hidden Hitch that_guy Canada Classifieds 3 06-11-2014 08:13 PM
Hidden Rusting issue FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 06:02 PM
DIY: access hidden menus on BRZ head unit robot DIY (Do-It-Yourself) Guides 0 10-23-2013 12:59 AM
