Old 02-27-2015, 08:40 PM   #1
muffinz
Drives: 2013 DGM BRZ Ltd
Need a brake diagnosis
So I have a trackday on 3/28 at thunderbolt in nj. I am still on stock pads and rotors and I'm not sure if i need new pads to play it safe.
I took some pictures of my driver side front brake.
Pad thickness is 5.5mm throughout. The front and rear of the pad look like they are at a 45 degree angle.
The rotor has 2 marks where it looks like maybe I smashed the brakes after they were over heated and it deposited extra brake material?
I searched google, this forum, nasoic, etc and couldn't find a spec for the stock brake pad thickness so I have no idea how worn out these really are.
Advice is greatly appreciated
p.s. added a shot of my ghetto diy emergency light. I soldered a bunch of white 12vdc led tape strips and put them on a chunk of wood and wired them to a cig lighter power adapter with a switch so if I ever need to change my tire in the dark I have plenty of light.
muffinz is offline   Reply With Quote
Old 02-27-2015, 08:50 PM   #2
jvincent
jvincent's Avatar
If you really want to play it safe, get new pads and high temp brake fluid. If it's your first time at the track you may not need them, but better safe than sorry.
If you have previous track experience, then definitely upgrade.
The Following User Says Thank You to jvincent For This Useful Post:
muffinz (02-27-2015)
Old 02-27-2015, 08:55 PM   #3
muffinz
I should have mentioned those pads have ~32k miles, 3 autox's, and 2 30 minutes track sessions in which I felt significant fade on round 2.
Old 02-27-2015, 09:42 PM   #4
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Stock pads aren't great and will fade even after spirited driving. Ever wonder why everyone's putting big brake kits on stock cars? I seriously doubt it's necessary, but the stock brakes definitely leave a lot to be desired, and that's to do with the pads and the fluid.
I recommend some better pads (hp+ maybe, i'm not sure what the pad de jour on the forum is), stainless lines and good fluid, either ATE Super Blue Racing, Amsoil Dot 4 or Motul RBF600. I know it can't be blue anymore so whatever equivalent ATE is putting out is fine.
Whatabouteggs is offline   Reply With Quote
The Following User Says Thank You to Whatabouteggs For This Useful Post:
Old 02-27-2015, 10:11 PM   #5
CSG Mike
CSG Mike's Avatar
I'd recommend some good fluid and pads. It's always to have too much than not enough when it comes to brakes; you can always swap your stock pads back on after the track day.
Old 02-27-2015, 10:30 PM   #6
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
I did one track day on stock pads and they've never felt the same. Saving up for some project mu. No people I know have ever toasted pads especially on an FRS (though I admit the sample size is 4) the first time out on the track, but once you get faster and can pass, etc., they don't last long from everything I have read (especially from CSG Mike)
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
The Following User Says Thank You to fatalelement For This Useful Post:
CSG Mike (02-27-2015)
Old 02-27-2015, 10:30 PM   #7
muffinz
can anyone comment on the thickness? what is 5.5mm compared to stock?
Old 02-27-2015, 10:49 PM   #8
CSG Mike
CSG Mike's Avatar
10mm (pad material only) is a new stock pad. At 2mm, you really should be replacing them, but you can use them to the backing plate (unsafe practice)
Old 02-27-2015, 11:16 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You've already answered your own question.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
muffinz (03-01-2015), Whatabouteggs (02-28-2015)
Old 02-28-2015, 12:56 AM   #10
Whatabouteggs
[Citation Needed]
I think people who track their cars stock tend to freak out because the pads weren't designed for track use, and start saving up for crazy big brake kits. Try to find E36 M3 people at tracks with big brake kits. 80% of the time they're running stock calipers and part store blank rotors.
80/20 principle suggests pads/fluid/lines will do it for the vast majority of people.
muffinz (02-28-2015)
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Subaru TSB: 02-136-12R - Oil Seepage Diagnosis and Repair Procedures. ATL BRZ Issues | Warranty | Recalls / TSB 10 10-17-2014 03:34 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
