#2354 | |
Drives: 2013 WRB Subaru BRZ Sport-tech
#2355 | |
Drives: FT86
1.P0193 is fuel rail pressure problem nothing to do with oil or cam position actuators or sensors http://www.datsc.com/tabid/122/OBD-E...u/Default.aspx Either you or dealer have got code wrong. 2. If you oil level was that low to be causing the cam position problem then you have other serious issues like why was oil that low that oil pressure was dropping. You either burning or leaking oil. If oil pressure and level was that low for any apreciable period its likely caused other damage. Hopefully the dealer is full of BS and the actual problem is a fuel pressure issue. |
#2356 |
Drives: JAWS
Does this also apply to gaskets that are composed of only multiple layers of thin metal?
#2357 |
Drives: FT86
#2358 | |
I told them how I asked around and googled what could cause the P0193 and they didn't even look at the fuel pump. They were so set that it was my oil level. Lol. |
#2359 |
Quick question, do the included Stage 2 tunes have the reduced idle rpm fix?
#2360 |
Drives: FT86
#2361 |
#2362 | |
Drives: Neptune GR86
It's pretty simple though.
#2363 | |
Drives: FT86
but you can also adjust the post start ignition timing from -15 to -4 but on usa rom you will also need to disable P050B cold start ignition performance. see Tune Tweaks link below. |
#2364 |
Good info, thanks for the quick reply
#2365 |
Drives: Scion F-RS 2013 Asphalt MT
Noob here. I just flashed stage 2 uel 91 on my frs. Running Ofh, nameless fo/op and zeta catback with injen intake. I was wondering what kind of range I should be seeing for short term and long term trims if it is running properly? Sorry if this has been answered, but I'm kinda lost and would greatly appreciate knowing how to read the diagnostics
#2366 | |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
