Old 01-27-2015, 02:09 PM   #1
BlackMonarch
Drives: Red BRZ
Rocket Bunny owners: Enter
I'm curious - At the moment I'm running the 5:AD concept wheels @ 19.5 in the back - With the RocketBunny rear fender flares, what spacers, or what size spacers would I need to flush this out? I just want to make sure I don't end up with wheels that are set in so far that it looks goofy. Anyone with advice on this?
BlackMonarch is offline   Reply With Quote
Old 01-27-2015, 02:25 PM   #2
swarb
install kit. measure. order spacers.
there is a rocket bunny owners registry thread, you can ask there.
Old 01-28-2015, 01:26 AM   #3
Mikeez
Engineering Student
Drives: Scion FR-S 2015
People with rocket bunny go with 10inch in the back atleast.. many do 11. What do you mean by 19.5?
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 01-28-2015, 10:34 AM   #4
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
19.5psi
NWFRS is offline   Reply With Quote
Old 01-28-2015, 03:20 PM   #5
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
If you're going with an RB kit, why not use the correct offset wheels?
slicktop is offline   Reply With Quote
Old 02-25-2015, 07:24 AM   #6
Paul_GT86_dxb
Hachiroku
Paul_GT86_dxb's Avatar
Drives: 2013 Toyota GT86 Hot Lava
Phoenix Reborn
My Rocket Bunny V2 build
Work Wheels Japan VS XX
18x9.5 front
18.10.5 rear
Nitto Invos
Running on KW V3 Coils + Raceseng Caster Camber Top Hats
Paul GT86 RB V2 Wallpaper by anthroPAULogist, on Flickr
Paul GT86 RB V2 Shark by anthroPAULogist, on Flickr
Paul GT86 RB V2 Phoenix Reborn by anthroPAULogist, on Flickr
Paul GT86 RB V2 VS XX by anthroPAULogist, on Flickr
Paul_GT86_dxb is offline   Reply With Quote
Old 02-26-2015, 05:44 AM   #7
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Please don't install spacers on a rocket bunny kit, if anything please don't install a rocket bunny kit if you're not going to order or buy the correct wheels for a rocket bunny setup. There's a thread with rocket bunny owners posting pics of their cars, there are many other threads of people asking about the correct wheel specs for a rocket bunny setup. If you're going with your current wheels then I'll tell you this, your rear wheels will have to go to the fronts at least WITH a spacer and you'll have to buy new rear wheels. Spacers are never the solution to widening a car for a widebody kit, your tires are going to look thin because your wheel isn't wide and aggressive enough, we all had to sit and research and learn the hard way about rocket bunny kits so please do the same and make the right decision from the first time.
Yamajee is offline   Reply With Quote
Old 02-26-2015, 07:01 AM   #8
Burrcold
Drives: Subaru BRZ Limited
Sounds like 19.5 might hurt.
Old 02-26-2015, 05:58 PM   #9
guslucatero
guslucatero's Avatar
Drives: 2014 WhiteOut
Any someone please post u the link of the Rocket Bunny wheels set up...been trying to look for that link for a while
-thanks
guslucatero is offline   Reply With Quote
Old 02-26-2015, 06:15 PM   #10
Koa
-thanks
Hi Gus...
please check my signature for an effective way to search this forum using Google.
It's very trick and should help you on your quest to become the ultimate rocket bunny ninja warrior
Rocket bunny style DRL without the rocket bunny kit. ducky369 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-22-2014 06:38 PM
Vis rocket bunny kit FrsT86-671 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-27-2014 09:33 AM
Rocket Bunny kit (just lip) encity5 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-01-2013 10:01 PM
WTB Rocket Bunny kit Yamajee Exterior Parts (Aero, Lighting, Etc.) 5 05-21-2013 09:23 AM
