Old 02-25-2015, 11:09 AM   #2269
vroom4
Tap the video widget in analyze, choose select sync frame or realtime sync....?
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
qoncept (02-25-2015)
Old 02-25-2015, 11:18 AM   #2270
qoncept
qoncept's Avatar
I don't even have it installed right now (it's 4 degrees out!) but I'll play with it again in the spring. Thanks!
qoncept is offline   Reply With Quote
Old 02-25-2015, 11:28 AM   #2271
vroom4
That's why you move south like us smarties
Old 02-25-2015, 01:09 PM   #2272
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by qoncept View Post
@DaWorstPlaya,
I'll try some of those things out, and I'll talk to Petrel about the GPS. It's been 2 years so I better cross my fingers.
As for #5 though, I've calibrated the video delay over and over and over again, and when emailing the developer asked repeatedly for a per-video calibration method because they are out of sync by a different amount every time. I've more or less given up.
I noticed their recommended gps to be very sensitive to placement. I think the internal receiver is weaker than most modern BT gps units I used in the past.
Once I was able to mount the gps on the exterior roof, I got much clearer signal and no data drift.
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
Old 02-25-2015, 03:46 PM   #2273
qoncept
qoncept's Avatar
Like a true dumbass I never actually considered where I had the GPS receiver. It was always tossed in the center console or glove compartment. Looks like I have something better to try next time.
Old 02-25-2015, 03:51 PM   #2274
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you def want it as out in the open and centered as possible, esp if you're relying on gps-drived parameters. (a gps device mounted on the right side will give you different readings when turning same-radii turns going left or right, if ever so slightly different
Old 02-25-2015, 04:02 PM   #2275
qoncept
qoncept's Avatar
Yeah. I have an incredibly one-tracked mind. If I'm thinking about driving that's pretty much all I'm thinking about. I do a lot of scrambling at the last minute to get my helmet on and seat positioned.
Old 02-25-2015, 06:02 PM   #2276
DaWorstPlaya
Drives: 2016 FR-S
Wow! R U serious?!? No wonder it didn't work. So the entire time this was user error. LOL!
DaWorstPlaya is offline   Reply With Quote
Old 02-25-2015, 06:13 PM   #2277
simpleisbest
Senior Citizen
Drives: Scion FR-S
I got tired of using blue tape every event to mount it to my roof and found this:
http://www.shapeways.com/product/SXW...FRSDfgodTJEAmg
It works great! You need to get your own suction cups, though. Found them on amazon.
qoncept (02-26-2015)
Old 02-26-2015, 11:40 AM   #2278
qoncept
qoncept's Avatar
Well, it's usually in the center console which shouldn't be terrible. And at the moment the GPS issues are the least of my worries. We'll see how it goes at the first event this year.
Old 02-27-2015, 09:36 AM   #2279
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Quick feeler for the Blytheville Pro - anyone interested in sharing their CS car with me? I kind of want to go, but don't want to make the drive with my car (yet another oil leak has developed).
Autocross nut
AustinTX is offline   Reply With Quote
Old 02-27-2015, 12:37 PM   #2280
chucky12012
Drives: 2013 Asphalt Scion FR-S
Someone give John a codrive!
chucky12012 is offline   Reply With Quote
Old 02-27-2015, 01:50 PM   #2281
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
What is or has leaked in the past?
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 02-27-2015, 02:03 PM   #2282
AustinTX
AustinTX's Avatar
Cam chain cover leak both times. Hoping the engine doesn't have to come out this time, but it seems inevitable due to the design.
Autocross nut
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
