Old 02-25-2015, 04:13 PM   #1
Djratrap
Drives: BRZ CSB Limited
p000b
Car back in the shop AGAIN... with a P000b code. Luckily still under powertrain. 52k miles on the car now. Getting pretty sketchy, this will be the 5th time the car has been in for "cam" issues. Wonder if they will just replace my engine already.
Djratrap is offline   Reply With Quote
Old 02-26-2015, 12:28 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
5 times is more than enough for a lemon law. I think the minimum was three tries.
N1rve
Old 02-26-2015, 08:01 PM   #3
Djratrap
Depends on the state and the mileage when things happen. I believe WA state if it's after 25k, no dice. All my issues started happening around 30k.
Old 08-04-2015, 02:21 PM   #4
ildylan
rolling over my sidewall
ildylan's Avatar
Drives: 15 FRS
Just got this today... hope I'm not in for the same headache
6500 miles only - '15 FRS
ildylan is offline   Reply With Quote
Old 06-07-2016, 11:14 PM   #5
ildylan
ildylan's Avatar
Drives: 15 FRS
Just around 17k in miles and I just got this code again. Sweet.
Old 06-10-2016, 10:03 PM   #6
PitViper
PitViper's Avatar
Drives: 2013 Scion FRS Limited Edition
Im at 30k miles and i keep getting it. Im trying to see if I can tune it out the the cam learning because it looks like its just "learning" to the point where it gets worse. If I reflash the ECU, she runs like a dream for days then it will start to learn in traffic and retard the timing till the timing is off. :/
Sent from my LG-D950 using Tapatalk
PitViper is offline   Reply With Quote
Old 06-15-2016, 02:17 PM   #7
Djratrap
It took 3 different dealers before they flew an engineer out to fix it. Last time i had it was i think around 50ish-K Miles. I'm at 86k now with no issues (knock on wood). Also something to think about if you buy a used engine from a first year twin.
Make sure you keep a record of every visit, always ask for a print out and save it(scan) to email for easy reference. Also look up your state lemon laws to see how many visits it takes before they buy the car back.
The Following User Says Thank You to Djratrap For This Useful Post:
Tcoat (06-15-2016)
Old 06-15-2016, 03:23 PM   #8
Large
IG: large2
You should still contact an arbitration lawyer, he might can help you
Large is offline   Reply With Quote
Old 08-29-2016, 03:33 PM   #9
TatharPallan
Drives: 2015 Subaru Blue Series - Pearl
I've been to the dealer a few times because of this.. Issue originally was in bank 2.. they replaced OCV and cam sprocket.. drove the car for 2 days.. same code came on but for the other bank... sigh FML... Trying to get this fixed before i go boost in 3 weeks. :-P
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
TatharPallan is offline   Reply With Quote
