Old 02-24-2015, 08:28 PM   #561
M23
Drives: 86
ID is 60mm and I need to double check length (at home now).
- Andy
Thanks
I will talk to Myles about making 350 lbs/in springs the default.
- Andy
Wow. That would be fantastic!
M23 is offline   Reply With Quote
Old 02-24-2015, 08:30 PM   #562
M23
Drives: 86
Originally Posted by smbstyle View Post
For anyone else on the fence about the T2's...
Randy Pobst drove our BRZ at Road Atlanta this past weekend (RCE T2s, 400lb springs, 215 NT01s) and said it was "one of the best handling cars I've ever driven".
https://www.facebook.com/randy.pobst..._comment_reply
This is spectacular!
Old 02-24-2015, 09:20 PM   #563
alex345
FRS610
alex345's Avatar
Drives: Scion- Frs
Send a message via MSN to alex345
which tophats/ camber plates are you guys using with these? which ones could I use? any suggestions appreciated
FRS 10-series- OFT,OFH,PerrinOP, Tanabee Fp.Perrin MAF intake,Cusco strut bar,Grimspeed tool tray, invidia Q300, Full JL Audio sound system, YO speed plaque.
Instagram: FRS610
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous #maverick#
alex345 is offline   Reply With Quote
Old 02-24-2015, 09:25 PM   #564
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any that will work with the OEM dampers. You'll need "conical washers" to use these with an OEM style mounts but they're only about $8 at Subaru.
The Following 2 Users Say Thank You to Calum For This Useful Post:
alex345 (02-24-2015), Racecomp Engineering (02-24-2015)
Old 02-25-2015, 08:42 AM   #565
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Randy Pobst liked our BRZ with the T2's so much he wrote an article about it in SportsCar magazine; "Best Handling Car I've Ever Driven":
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following 6 Users Say Thank You to smbstyle For This Useful Post:
ATL BRZ (03-03-2015), drewbot (06-12-2015), M23 (02-25-2015), Porcupint (02-25-2015), Racecomp Engineering (02-25-2015), Scottemad123 (02-25-2015)
Old 02-25-2015, 12:58 PM   #566
M23
Drives: 86
High-res photos of the pages of the article please
Old 03-01-2015, 11:38 PM   #567
dabocx
dabocx's Avatar
Drives: Scion FRS
What is the size and length of the tarmac 0s springs? Thinking about getting some 350 pound swift springs.
dabocx is offline   Reply With Quote
Old 03-02-2015, 12:26 AM   #568
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That's some serious stuff if he wrote about it in an article; the man doesn't tell BS. He tells it like it is, straight-up (whether good or bad).
Check Racecomps Facebook page. That's where I read the article
M23 (03-02-2015)
Old 03-17-2015, 01:17 AM   #569
Porcupint
Drives: 13 GBS BRZ
Well, thanks to google I now know I probably need conical washers to get rid of my weird metal on metal noise at low speeds with my 0's. Ordering those in the morning.
Edit: Ordered. $4ish a pop. Not too bad.
Porcupint is offline   Reply With Quote
Old 06-03-2015, 11:31 PM   #570
SurfAndSand
8SiX
Drives: FRS 10series
Not sure if anybody else already posted the article itself, but here it is straight from SportsCar Mag.
http://www.sportscarmag-digital.com/...015?pg=22#pg22
SurfAndSand is offline   Reply With Quote
The Following 2 Users Say Thank You to SurfAndSand For This Useful Post:
Racecomp Engineering (06-04-2015), Sleepless (03-23-2016)
Old 06-12-2015, 03:29 PM   #571
Pat
Pat's Avatar
Drives: 2023 BRZ
The valving is substantially different. Our RCE T0's are much more at home on the track.
- Andy
Thanks, Andy. Are you able to quantify how much faster a T2 is on track versus a T0 with similar settings? That is, if the T2 were adjusted to ride similar to a T0, how much faster would a T2 be?
Of course, this is assuming everything else is equal (alignment, tires, pressures, etc.)
TIA
Old 06-12-2015, 04:01 PM   #572
TIA
Well it wouldn't be a fair comparison...the T2s use much firmer springs than the T0s. The T2s big advantage (other than the firmer springs) would be the 2 way damping adjustability. That's huge if you want to make some quick adjustments at the track to dial things in a little more, or on the street. Rain in the forecast? Soften things up a bit to slow down weight transfer. Want a little more front grip on corner exit? Go down a click on front rebound. Is the car not turning in as fast as you like? Add a little front compression.
The T0 are valved well out of the box and work really well with whatever you throw at them, but having that extra adjustability is a pretty big bonus.
Hope that helps!
- andy
Old 07-18-2015, 04:32 PM   #573
Calum
That Guy
I finally had the time to install my T0's today. As I don't have a particularly level drive way, and my car was already lowered, I tried using the measurements included with the instruction. I went with the max height as I've read a few times that the heights these can go is about -15mm. Will this work? Or do I need to adjust them to get them to my target height? Mainly I'm asking is because the front appears higher than it should.
Thanks guys, and thanks for the awesome product. I had it out for a short test drive and it feels really predictable mid corner, which was my biggest grip with my old setup.
Old 07-20-2015, 07:26 PM   #574
Calum
That Guy
Hope that helps!
- andy
I finally had the time to install my T0's today. As I don't have a particularly level drive way, and my car was already lowered, I tried using the measurements included with the instruction. I went with the max height as I've read a few times that the heights these can go is about -15mm. Will this work/is it safe? Or do I need to adjust them to get them to my target height? Mainly I'm asking is because the front appears higher than it should and I don't want to ruin my brand new parts.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
