Drives: Firestorm FR-S
Might be saying goodbye to the Frs :(
Well guys i think it might be time to give up my beauty. She has been fun, but has also gave me bad luck and headaches. I had a set of wheels stolen, they were stock but i did not have wheel locks on. I learned my lesson When i first got the car my ecu went bad, luckily that was replaced. Went through almost 3 sets of taillights due to condensation. i just dont feel its worth making the monthly payments anymore when this is my dd and its size has caused inconvience while also having some crappy luck along the way. The winters are also crappy, but maybe thats cause i havent bought snow tires yet. But anyways i was wondering how much do you think i can get for the car at a dealership or some place like carmax which i hear gives you a bit more money. The car is a '13, automatic, 34k miles, and does have an accident. I hit a railing and it damaged my fender along with needing to replace the axle. The wheels have curb radh and the exterior is about a 7 out of 10. The interior is about the same. I was thinking of buying a 2000-2003 maxima because it is quick rommy, and looks nice. I know i will be suffering with thr handling aspect. But it will be practical. Thanks for your advice guys
#2 |
Buying winter tires would certainly alleviate those headaches during this time of the year..
Going with a 2000 model is a huge downgrade from you're current vehicle, so unless you're really strapped for cash, I would at least aim for a much newer vehicle
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
| The Following 2 Users Say Thank You to FRSNewb For This Useful Post: | Choco (02-25-2015), dad&sonFRS (02-25-2015) |
#3 |
Drives: BRZ DGM Limited
Good luck. Coming from I30 and Maxima they are great all around cars. The early 3.5 L (starting I believe 2001) had some engine issues and oil burning. The 2000 is 3L and great ...easy to get 300K miles out of them. Common issues were bad ignition coils, leaking power steering hose, O2 sensors going bad. Otherwise great ride! Never read about engine rod knock that you read about on here almost daily!
#4 | |
#5 | |
Drives: 2013 Firestorm
| The Following User Says Thank You to Jrryjms07 For This Useful Post: | Tcoat (02-25-2015) |
#6 | |
#7 | |
Drives: FRS-RS1, Triumph Speed Triple, Lola
| The Following 7 Users Say Thank You to Caspeed For This Useful Post: | Choco (02-25-2015), Kaotic Lazagna (02-25-2015), Loetke (02-25-2015), NWFRS (02-25-2015), Sarlacc (02-25-2015), Tcoat (02-25-2015), UtahSleeper (02-25-2015) |
#8 |
I totally agr.... hey wait a second, my car is lowered and I haven't beat it up!
| The Following User Says Thank You to Tcoat For This Useful Post: | Choco (02-25-2015) |
#9 |
Time Traveller
Look at the financial aspects. Do some calculations, and then make your call. Talk of luck only clouds things. Superstition has no place in a logical decision. Understand that the chance things that have happened are not tied to the car or your life in some metaphysical or supernatural way. That will help you make the most well reasoned choice.
#10 |
Drives: GR Corolla
I've never been a fan of used vehicles, let alone one that has been modified (unless I knew the owner personally). My friends bought used cars, and each has had some type of issue, be it minor to major.
One thing to think about is warranty. Your FR-S still has its powertrain warranty. What are you going to do if you buy that older Maxima, and the next day the engine gives out? If anything, I would spend a little more and find a V6 Camry. |
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | DAEMANO (02-25-2015) |
#11 |
#12 |
I do it gently!
#13 |
MJLONIR Program Member
Drives: 2014 Scion FR-S
Since I saw snow listed in the OP, I would check the following when looking at buying a used car, (@Tcoat could elaborate if he wishes, I speak for Pennsylvania's winters):
-underneath the vehicle; salt wreaks havoc on pipes and any metal, especially if it's a long winter -suspension springs/wheels; corrosion from the salt can effect the efficiency of these -under the hood; check for stripped wires, excessive corrosion on metal, battery connectors, belt tightness, the basics (fluids) Personally, these are a few things mostly overlooked when purchasing a used vehicle, especially in areas involving snow for long amounts of time.
ドラゴンに乗る
Instagram: Komodo_Actual My car build: http://www.ft86club.com/forums/showthread.php?t=81094 |
#14 |
hey guys thanks for the input. I forgot to mention that i know the owner. The owner of the 5 speed maxima is my uncle. So i know how the car has been treated.
| Goodbye FR-S | Gost | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 07-09-2014 11:39 AM |
| Sad goodbye | sieglapj | AFRICA | 12 | 04-26-2013 05:44 AM |
| Hello FRS! Goodbye GTi. | LXXXVI | CANADA | 0 | 06-21-2012 08:16 PM |
| Goodbye BRZ, Hello FRS! | kidgogeta | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-05-2012 01:41 PM |
