Old 02-23-2015, 11:32 PM   #701
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by oaroyale View Post
I got mine today in the mail. Installed it in five minutes. Something is not right, when I turn to DRL the headlights come on along with the boomerang and DRL. That's not how it looked in the video. I have a 2013 premium. @Diodedynamics Did I do anything wrong?
I don't want the headlights to come on when I turn to DRL. I only want the headlights when I turn the headlights switch all the way.
What do you mean by "turn to DRL" though? DRLs are on with the controls set to either OFF or AUTO. (I'm not trying to be a smartass btw, just confused)
Old 02-23-2015, 11:33 PM   #702
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
So you want it like this for your DRL?:
Name:  pictures from phone 030.jpg
To get the DRL strip on bottom off while headlights are on you need to remove the little red piece on the black module that is close to the little white hole on the bottom half. In their installation video it shows you at the 3:34 mark!
Husker BRZ is offline   Reply With Quote
Old 02-24-2015, 12:44 AM   #703
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Think by DRL he/she means parking lights. Turning the headlight switch from OFF to Parking Lights probably turns on the headlights also (as opposed to turning all the way to ON).
Don't have a solution, but that's my interpretation of the problem.
amaciose is offline   Reply With Quote
Old 02-24-2015, 01:02 AM   #704
PandaSPUR
PandaSPUR's Avatar
Attachment 103264
Damn thats a sexy picture, as simple as it is.
Cant wait to get this mod installed.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Husker BRZ (02-24-2015)
Old 02-24-2015, 02:50 AM   #705
btoast
I installed mine yesterday and everything went well. I was unable to completely hide the wire though. I could not figure out how to get it to go behind the hood latch. Everything is tucked behind the bumper and air box but for that small 6" section that goes around the hood latch area. I tried to shove it behind the latch but could only get it about 3/4 the way between the bumper foam before it would get stuck.
How else are you guys doing it?
btoast is offline   Reply With Quote
Old 02-24-2015, 08:10 AM   #706
oaroyale
Drives: Black BRZ
That! The headlight switch has 4 settings: off, DRL, parking light and headlight.
when I turn one knot to DRL, everything comes on including the headlights. (I don't want the headlights to come on)
when I turn another knot to parking light, only the boomerang and the DRL come on.
when I turn all the way, everything turns on again.
oaroyale is offline   Reply With Quote
Old 02-24-2015, 08:17 AM   #707
Foobar
SLO NO MO
Foobar's Avatar
I don't have a DRL setting on my BRZ Limited, I have the Auto setting instead, depending on lighting outside, it either turns on the DRL if it's bright out, or headlights if it's dark. With the mod, its all on at dark, just DRL and Boomerang if light.
Just researched a bit more, both BRZ models have auto headlights. Either you were testing during while it was dark out, or your light sensor is blocked or not working as suggested below.
Old 02-24-2015, 08:20 AM   #708
PandaSPUR
PandaSPUR's Avatar
Turning once gets you to the AUTO setting which will turn on your headlights depending on how light/dark the car thinks it is.
Did you block off the headlight sensor?
From the manual:
Old 02-24-2015, 08:38 AM   #709
oaroyale
Drives: Black BRZ
From the manual:
Ahhhhh. I installed it last night, that explains it. I am an idiot. carry on.
The Following 2 Users Say Thank You to oaroyale For This Useful Post:
amaciose (02-24-2015), Trap63 (02-25-2015)
Old 02-24-2015, 10:40 AM   #710
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by Annahra View Post
I tried to snap a few this morning but wind chill was like 10* and I'm working so had to edit on my phone. Hope you can kinda see. It's tucked completely up under the front edge behind the truck release and airbox--in the pics with my hand my fingers are touching the wire. I can try and get better pics when it's not so cold.
Where you use "electrical tape" as you mention before?
Thanks.
cslntuee is offline   Reply With Quote
Old 02-24-2015, 11:57 AM   #711
amaciose
amaciose's Avatar
I was able to completely hide mine between the foam and the hood latch as you mention. Depress the foam and it should give room to fit the connectors through. I removed my air box to give more room to work, I'll try to post pics tomorrow night.
The Following User Says Thank You to amaciose For This Useful Post:
Annahra (02-24-2015)
Old 02-24-2015, 12:27 PM   #712
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
Originally Posted by SCHN3LL View Post
I get that, what I don't get is the "Not sure if serious?" line. I don't have the patience for that kind of
I am going to try to troubleshoot it tonight.
Sorry, there are so many trolls on these forums I made a mistaken assumption! The windows frozen thing comes up every winter. Glad your situation was still a simple fix (not gonna lie--I've hit the window lock button by accident too).
It takes maneuvering and possibly smaller hands to get it behind the hood latch, but it fits. Definitely need to remove the airbox to get back there.
Also *she. Need to remember to change my avatar to duck face selfie with hair in my face to avoid further confusion.
Annahra is offline   Reply With Quote
The Following 2 Users Say Thank You to Annahra For This Useful Post:
Husker BRZ (02-24-2015), Porcupint (02-24-2015)
Old 02-24-2015, 12:54 PM   #713
PandaSPUR
PandaSPUR's Avatar
Haha that would explain it.
Old 02-24-2015, 03:12 PM   #714
Diode Dynamics
Diode Dynamics's Avatar
Good thing you aren't a doctor... I live in San Diego, it was a brisk 68 today.
I think I'll just wait to hear what Diode Dynamics has to say...
This module has absolutely nothing to do with your interior illumination or windows.
Just to be clear- the AUTO headlight setting has absolutely nothing to do with this module. It just switches your lights on or off for you.
And remember- DRL comes on only when vehicle is running, with ebrake down. Parking lights come on whenever your headlights are on- doesn't matter if it's the Auto setting or On setting.
After installing, if you think something's not working right, please uninstall the module and see if it's still the case. This module is not going to interfere with other functions in your vehicle.
Thanks,
Paul
John C.
Diode Dynamics
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
Annahra (02-24-2015), Trap63 (02-25-2015)
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 04:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 03:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 10:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 10:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
