Old 02-23-2015, 07:39 AM   #225
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Not sure about @GeeTee86's log, I've only checked my own today. Will check his soon but, also running pump fuel at the moment.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 02-23-2015, 10:14 AM   #226
bandit0289
bandit0289's Avatar
Drives: 2015 blue series blue
Originally Posted by JB86'd View Post
You're getting minor knock at somewhat high load, nothing too bad. If you want to completely eliminate it, you could try using the 91 octane tune, or finding different gas that might be better. What fuel are you using?
Parkers 93 octane
You also have similar high LT fuel trims at light throttle/low rpm like I do with the stage 2 uel tune, how many miles have you driven on the tune so far before doing that log?
About 1500 miles
Thinking about running e85..... gotta find a station close
bandit0289 is offline   Reply With Quote
Old 02-24-2015, 06:29 AM   #227
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
I believe @GeeTee86 was running E50 in that log ??
but other logs I looked at from someone in SA cannot remember who did have Iam about 0.5 on petrol.
It unlikely to blow up as ecu is managing knock and still has more ability to correct knock but will nobble power somewhat , I have seen stock cars in Austrlaia with similar IAM on 98 ron and they are still running.
Even if the IAM was 0.1 it could still pull another 5 degrees FLKC i believe.
Was not me, have never used it. The first log posted was delicious's. I know there was no E in.
GeeTee86 is offline   Reply With Quote
Old 02-24-2015, 06:42 AM   #228
steve99
Drives: FT86
I look at so many logs i get confused
Phantobe (02-24-2015)
Old 02-24-2015, 06:48 AM   #229
GeeTee86
86 Nut
GeeTee86's Avatar
I can imagine. I recon when you close your eyes you just see parameters
The Following User Says Thank You to GeeTee86 For This Useful Post:
steve99 (02-24-2015)
Old 02-24-2015, 06:49 AM   #230
sav
sav's Avatar
You mean like the Matrix?
95RON SAV Tuned
The Following User Says Thank You to sav For This Useful Post:
Old 02-24-2015, 08:01 AM   #231
GeeTee86
86 Nut
GeeTee86's Avatar
The Following 2 Users Say Thank You to GeeTee86 For This Useful Post:
Phantobe (02-24-2015), sav (02-24-2015)
Old 02-27-2015, 10:28 PM   #232
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Is it just me or does the ECU take about a week to fully learn?
I was recently getting some FLKC pulled (~1deg or so) & my IAM was dropping to about .70 so I flashed a custom tune where I pulled some timing in the region where I was getting knock.
Now I have about ~50 miles on the new tune & so I did a pull.
http://datazap.me/u/phantobe/91-chev...ata=1-7-8-9-14
Looks awesome right everything looks fine and dandy! However I'm willing to bet in like four days I'll slowly begin to see my IAM drop. Does it just really take this long for the ECU to learn? Any explanation
@steve99 <3
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 02-27-2015, 11:17 PM   #233
steve99
Drives: FT86
@steve99 <3
keep an eye on your fuel trims as well
Temperature can also effect knock so IAT as well
as can different fuel
Old 03-04-2015, 02:55 AM   #234
GeeTee86
86 Nut
GeeTee86's Avatar
Short acceleration subset
http://www.datazap.me/u/deefluce/v3-...-31-33&solo=15
Cruising
http://www.datazap.me/u/deefluce/v3-...4?log=0&data=7
@Dammod
@steve99
Old 03-04-2015, 03:45 AM   #235
Thatguyjeremy
Drives: 13' Asphalt FRS
http://www.datazap.me/u/thatguyjerem...3?log=0&data=1
can someone tell me if this looks alright..im a newb
IG: __thatguyjeremy
Thatguyjeremy is offline   Reply With Quote
Old 03-04-2015, 04:11 AM   #236
steve99
Drives: FT86
looks ok except IAM is 0.9 should be 1
gather your on 91 octane fuel, probably a bit of low rpm knock 2000-3000 causing the iam to drop, cannot rearly tell as not much of the lower rpm stuff in that log
upper rpm us ok
maybe try some different brands of gas/petrol
Thatguyjeremy (03-04-2015)
Old 03-04-2015, 04:17 AM   #237
Thatguyjeremy
upper rpm us ok
Yeah on 91. it's usually 1.0.... But idk what happened. I disconnected battery to run fog light wires.. And now it's like that. Actually got lower to.63.. I Think I'm gonna reflash when I get home.
IG: __thatguyjeremy
Old 03-04-2015, 06:07 AM   #238
steve99
Drives: FT86
refflash wont help better fuel will
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Koa (03-11-2015), Thatguyjeremy (03-04-2015)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
