Old 02-22-2015, 07:37 AM   #57
Speedhead
Drives: BRZ DIT;VX220 T;'85 Silvia S12 FJ20
I guess your referring to the engine bay etc?
Here I ask you for patience, as before we have the kit "online" by means of available, I won´t post details of the installation.
Car exterior/interior is completely std. by now.
Speedhead is offline   Reply With Quote
Old 02-22-2015, 07:43 AM   #58
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Yes, I was referring to the engine bay.
Old 02-22-2015, 07:50 AM   #59
Speedhead
Sorry! A bit more patience pls
Old 02-22-2015, 08:50 AM   #60
ripper
ripper's Avatar
i really applaud this effort and wish that the production deals between toyota and subaru would have allowed an sti model brz with this motor in it. i would have been the first one in line at the dealership to buy one.
i wonder if there are any power advantages of a turbo variant of the 4U-GSE with the d4-s injection system over the fa-20 dit? from everything i've read it seems to be just an emissions advantage.
ripper is offline   Reply With Quote
Old 02-22-2015, 04:51 PM   #61
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Originally Posted by Reaper View Post
So the starter doesn't fit like I said. The turbo doesn't fit like I said and the intercooler doesn't fit like I said. So you end up buying another engine and fabricating most of a turbo kit to swap this in. Then as fullblown and several other shops have already seen the fa20dit cannot make the same amount of power as the fa20 with a turbo. Fa20dit tops out under 400whp. The di injectors simply won't flow anymore than that. This seems like a complete waste.
well you'd have a more reliable forged engine under the hood though.
SuperDave is offline   Reply With Quote
Old 02-22-2015, 04:59 PM   #62
Poodles
Drives: 2015 Series.Blue
Nope. The engine isn't going to be stronger, simply built for boost (i.e. low compression pistons and the inlet/outlets for oil and water to the turbo, and MAYBE some other small changes)
Old 02-22-2015, 05:02 PM   #63
Speedhead
just that those which may start reading the thread from somewhere about here also know.
many of the statements by reaper as per above reg. turbo, starter etc. are not/or not entirely correct.
Old 02-22-2015, 05:33 PM   #64
Speedhead
DIT is producing twice the torque from factory than the FA20D.
Do the maths re block strength, crankshaft,...
Why is it not being stronger according to your opinion?
The Following User Says Thank You to Speedhead For This Useful Post:
SuperDave (02-22-2015)
Old 02-22-2015, 10:33 PM   #65
akahenry
akahenry's Avatar
Drives: '18 STi
Man this thread looks exciting but I won't believe anything until solid data and videos are shown.
akahenry is offline   Reply With Quote
Old 02-22-2015, 10:49 PM   #66
Poodles
Because the blocks are the same...
But go on and keep thinking it's stronger.
Old 02-23-2015, 04:34 AM   #67
Speedhead
You have obviously never had them side by side did you? (FA20D and DIT)
Old 02-23-2015, 04:41 AM   #68
Speedhead
didn´t plan to post them here, as this sre just some very quickly done vids.
We will do some proper ones quite soon.
as per pictures, if you look closely on the pictures I ahve already posted, you will notice that theres a FA20DIT inside, which can be seen by the intake manifold.
re data, if you don´t believe the gps plot well, then you´d have to come here for a test drive I guess
dyno results will come in the next weeks.
Old 02-23-2015, 04:43 AM   #69
Speedhead
[ame="https://www.youtube.com/watch?v=7TAEwDh5fHI"]vid2[/ame]
[ame="https://www.youtube.com/watch?v=w0uWrpc7KUk"]vid3[/ame]
Old 02-23-2015, 04:44 AM   #70
Speedhead
[ame="https://www.youtube.com/watch?v=wumAOXFbb78"]vid1[/ame]
The Following 3 Users Say Thank You to Speedhead For This Useful Post:
fx35s (02-26-2015), hmong337 (02-24-2015), tahdizzle (02-23-2015)
FA20DIT vs FA20 D4-s? hmong337 Forced Induction 31 07-26-2020 02:11 AM
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 02:15 PM
Convert NA FA20 to FA20DIT in the WRX SunkenFRS Forced Induction 21 03-15-2015 08:59 PM
FA20DIT parts glorydays Forced Induction 8 03-14-2014 05:03 PM
FA20DIT vs EJ25 - 2015 WRX and STI get dyno tested kbye Other Vehicles & General Automotive Discussions 7 02-27-2014 09:40 AM
