Old 02-11-2015, 10:33 AM   #2269
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by John Rambo View Post
Hey guys. So recently I noticed that after I let the car sit and idle for a while, maybe like 8-10 minutes blue smoke comes out of the exhaust slowly and if I rev it I get a few puffs of smoke. Doesn't happen any other time as far as I know. This is only when I've noticed it. Here's a crappy video I took just now
Anyway, I think this has to do with when I was emptying the catch can. I didn't realize how full it was and tipped it around a bit and at one point it was almost upside down when I was trying to get the bottom bolt off to drain it. I think some oil fell into the hose but I don't know if it would cause this problem. If it was this how should I go about fixing it? Any advice on what else it could be if not that? Thanks
I doubt it has anything to do with your catch can setup, but post up some pics of exactly how you have it installed. Any oil that may have gotten in that hose should have burned up after a few drives. It is more likely that the oil is getting past your turbo seals which either means they are blown or you have an issue with your oil drain line and it is backing up and letting oil past the turbo seals.
Old 02-14-2015, 04:18 AM   #2270
Frsprince
Drives: Sema 2013 Frs Project car
Sup LJ! The Pink car is running 91 octane... Its going to be using E85 soon
Frsprince is offline   Reply With Quote
Old 02-17-2015, 12:06 PM   #2271
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Sorry for the late reply, been pretty busy recently...
Anyway I thought about what you said and realized I had only really driven it once or twice since I saw the smoke, I drove it around a couple more times and I let it idle the other day for over 20 minutes and there wasn't even a hint of smoke, so I guess everything is good!
Thanks for the help!
John Rambo is offline   Reply With Quote
Old 02-17-2015, 10:46 PM   #2272
mashal
DADA
mashal's Avatar
Drives: 2013
@FullBlown please check your pm
Sent from my A0001 using Tapatalk
mashal is offline   Reply With Quote
Old 02-21-2015, 03:10 PM   #2273
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Need some help guys/gals!
Still working with HRI on tuning my setup and we cannot seem to tune the top-end of the car because we keep getting fuel cut or something in the 6-7k rpm range. Pretty sure it is being cause by turbulance in the upper rpms causing an incorrect MAF reading. Only think I could think of would be the charge pipes past the IC are not happy. I've checked them and they all seem to be good. The only think I can think of is the long silicone coupler that passes behind the BRZ's passenger side headlight. Since there is a very slight distortion due to the sharp bend into the intake pipe's connection. Happens wether on 15 or 7psi. Boost gauge is reading rock solid up until the cut.
Any thoughts?
Old 02-21-2015, 03:49 PM   #2274
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
Any thoughts?
Fuel delivery? below is a quote from the Cssworth super charger installation instructions in reference to the fuel pump.
♠♠♠88
Ernie L is offline   Reply With Quote
Old 02-21-2015, 08:22 PM   #2275
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I'm not on stock fuel pump/injectors. All fuel related mods were installed prior to FI to ensure they worked beforehand. thanks though.
Old 02-23-2015, 09:48 AM   #2276
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Any thoughts?
Hard to say without seeing the datalogs. Are you saying that you hit 6000 RPM and suddenly the MAF reading stops increasing and decreases suddenly? If you are having MAF issues, James should be able to switch you over to a hybrid MAF/Speed Density tune.
Old 02-23-2015, 02:44 PM   #2277
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Any thoughts?
Contact Bill or Zach at Delicious Tuning.
Infamous Performance is offline   Reply With Quote
Old 02-23-2015, 02:53 PM   #2278
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I had a similar issue that was related to the fuel pump not holding pressure in the higher RPM range. The solution was more O rings. What setup did you use when you installed the fuel pump?
Old 02-23-2015, 07:15 PM   #2279
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I beleive I'm doubled up IIRC. I Know LJ just reccomended just going with the stock O ring but after reading some banter in the thread where FA20/tony had a video on taking them apart I decided to add an extra one.
James specifically told me it was MAF signal causing it. Never considered Speed Density as the problem was likely caused by me and seems fixed for the moment.
I was able to take apart the intake and clean a the maf which has seemed to fix this issue. I had quite a bit of oil in my charge pipes, I assume from when my turbo drain was kinked a while back. I guess I will have to keep periodically cleaning them and the MAF until I get all of the oil out of the pipes... for good. :/
Old 02-25-2015, 07:12 PM   #2280
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
My car [ame]http://youtu.be/mcUsV7fE4Bs[/ame]
Build details:
Built FA20 9.5:1 Compression
Fullblown Stage 2 head package and cams.
Fullblown Premium turbo kit with Ported PT5858 turbo (upgraded 750hp intercooler)
Full 3" turbo back exhaust
Fullblown upgraded rads, fans and shrouds
Fullblown oil cooler
Fullblown Stage 1 fuel system
Fullblown Flex fuel kit
3.73 Rear diff conversion
Attached dyno graphs of my 91 pump gas tune, 20 psi e-68 tune and 25 psi e-68 tune.
Size:  234.6 KBName:  ImageUploadedByTapatalk1424909579.114739.jpg
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 02-25-2015, 08:07 PM   #2281
Dipstik-sportech
Dipstik-sportech's Avatar
So much wheelspin
Old 02-25-2015, 08:10 PM   #2282
Brody602
Drift King
Brody602's Avatar
Originally Posted by Dipstik-sportech View Post
So much wheelspin
Not bad for 4th gear ;D
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
