Old 02-18-2015, 12:44 PM   #1289
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Would you sell just a 3" high flow cat? My 3" TBE is rather noisy, and I was hoping a high flow cat installed would help some.
kmbkk is offline   Reply With Quote
Old 02-18-2015, 02:08 PM   #1290
ja1217
Drives: 2004 Toyota RAV-4 5M
Finally got my JDL EL Header, OP, and FP installed, tuned, and dyno'd! Here are the results:
RunFile_012 - JDL EL Header (no cat), JDL OP, JDL catted/resonated FP, Stock Catback, GrimmSpeed Intake, Delicious Stage 2 Tune, Cusco RS LSD (don't think it makes a difference though)
RunFile_007 - 100% Stock Exhaust, K&N Drop in Filter, Delicious Stage 1 Tune
And here is a previous dyno with stock tune and stock exhaust:
Runfile_005 - 100% Stock Exhaust + Tune, K&N Drop in Filter
Runfile_006+7 - Delicious Stage 1 Tune
All dynos also have the following mods and were performed with 93oct and run in 4th gear:
ACT Prolite Clutch/Flywheel
DSS CF Driveshaft
Perrin Engine Mounts
Crawford Performance AOS
Big thanks to @JDLAutoDesign, @DeliciousTuning, and @Pure Automotive for the parts install and dyno!
ja1217 is offline   Reply With Quote
The Following 8 Users Say Thank You to ja1217 For This Useful Post:
BAMF86 (02-18-2015), DeliciousTuning (02-24-2015), DocWalt (02-18-2015), freerunner (05-31-2016), JDLAutoDesign (02-18-2015), M23 (02-18-2015), Mad_Mike (04-23-2015), Teseo (02-18-2015)
Old 02-18-2015, 04:36 PM   #1291
jonkim2
Drives: Raven FR-S
Originally Posted by yomny View Post
For peace of mind i never reuse the gaskets, i used the grimmspeed thick header gasket. Now do keep in mind most if not ALL headers RASP!! sounds like shit when you get on the gas, not sure if you're running catless EL, or UEL but they rasp. It could also be a leak as it sounds the same. Does it do it when you give it gas only, what about lightly applying throttle. Its not only with stock overpipe at least not in my case. I uploaded a couple of videos when i installed my ptuning header, look up "yomny" on youtube, can't link them here as im at work.
PS- if it does it at idle and after being fully warmed up, then its most likely a leak.
I recognize what rasp sounds like and I'm fairly convinced that the sound I am hearing isnt it. This particular sound overpowers the sexy boxer rumble and is distinctly clicky/flappy. Additionally, I don't think I would have bought JDL if I was under the perception that all aftermarket headers sound like shit when you step on it. Please keep in mind this sound occurs only when I apply gas. Idle = sexy JDL rumble, as advertised.
I'm at work on my phone but will YouTube you when I have a chance later. I appreciate your suggestions.
Moreover, I spoke to JDL and will be testing for leaks with sea foam next weekend. If no leaks, I guess I'll have to buy the op/fp combo, which I was planning on buying anyway
More recommendations/suggestions are welcomed.
Thanks guy
jonkim2 is offline   Reply With Quote
Old 02-18-2015, 04:38 PM   #1292
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Thanks guy
You know this type of response from a comment intended to help is what keeps most of us from replying to those asking for help with clickity, flappy, cracky sound questions. . Sounds like you got it covered.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-18-2015, 07:59 PM   #1293
jonkim2
Drives: Raven FR-S
What "type" of response does my comment fall under? If Ure offended I apologize, I had no intent of shooting down your suggestions. I'm actually grateful that you did comment because it opens up another possibility as to why I'm experiencing this specific issue. Any comments, good or bad, are welcomed. I'll be the first one to say that I know nothing about cars and this is my first header install that im doing all on my own. So please, comment away
Old 02-18-2015, 08:07 PM   #1294
jonkim2
Drives: Raven FR-S
@yomny by the way I just saw your videos. If your car has rasp, it's very minimal (sounds amazing). My car definitely sounds different, even at idle. You have a tomei op yet my car is louder due to the clicking/flapping on revs. Thanks for videos and again, no hard feelings mans
Old 02-18-2015, 08:12 PM   #1295
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'd struggle to say most headers make rasp.... On a Honda, sure, but that's because of the insane overlap they run. My JDL UEL has zero rasp, and the Supersprint on my GTI has zero rasp.
If it's raspy you either have a leak or something else in the exhaust is causing the rasp. I put a Nameless OP/FP combo pipe on my car with the old style Helmholtz resonator and it rasped like a mofo, just as an example of what I mean.
On a side note, my Ti coated overpipe & catted/resonated frontpipe arrived at home today. Now I'm really looking forward to this weekend
Old 02-18-2015, 08:56 PM   #1296
OkieSnuffBox
Drives: '23 BRZ Limited
No dog in this fight, most rasp comes about from cat/no cat.
Old 02-20-2015, 11:34 AM   #1297
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Sorry it took me so lomg to get this video up but here it is!
JDL Full Exhaust clip both in car and outside on the bumper. Skip to 5:20 if you want to hear the in car sound
[ame]http://youtu.be/EydtpW3D-5A[/ame]
JDLAutoDesign is offline   Reply With Quote
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
akahenry (02-20-2015), DocWalt (02-20-2015), Teseo (02-20-2015)
Old 02-20-2015, 12:51 PM   #1298
Teseo
Drives: frs
Description say its catted, right? Still throw a cel after installation?
Old 02-20-2015, 09:41 PM   #1299
akahenry
akahenry's Avatar
Drives: '18 STi
I don't know if this was already mentioned or not but how is the 2.5" JDL Ultra-quiet front pipe quieter than the stock front pipe?
akahenry is offline   Reply With Quote
Old 02-20-2015, 09:46 PM   #1300
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'll be installing the ultra-quiet pipe tomorrow, I'll let you know. I'm not expecting it to be quieter than the stock pipe, and I'll be a bit disappointed if it is, lol.
The Following User Says Thank You to DocWalt For This Useful Post:
Old 02-21-2015, 01:18 AM   #1301
Zaneman
Drives: 2013 BRZ limited
I installed the JDL EL catted header last night and I could only get it 2-3mm from the fan shroud. I drove it to work and noticed it had begun to melt the plasic of the shroud. What is the best way for me to adjust the header so that I can move it farther away?
Zaneman is offline   Reply With Quote
Old 02-21-2015, 02:21 PM   #1302
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I installed my JDL overpipe and catted/resonated front pipe and drove it around a bit. Fitment of the overpipe is freaking fantastic! The frontpipe took a little bit of work, I really had to shove it towards the passenger side to not hit the tranny mount and the donut gasket that was included really put a LOT of excess tension on the frontpipe-midpipe bolts because of the way the gasket is made versus stock.
Sounds fantastic! No wooshy noise, and it's a tiny bit louder than my previous setup (ISIS overpipe and stock frontpipe) but there's no rasp and no strange tingy noise like I got with the Nameless combo pipe.
I can't wait for tomorrow so I can go out and rip around a bit with the windows down and not worry about snow in my face, hehe.
akahenry (03-07-2015)
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
