Old 02-19-2015, 08:53 PM   #267
M23
Drives: 86
I’ve emailed the following, in regards to finding a watanabe/panasport/minilite/superlite type style of wheel available in 5x100 (preferably 16”)
Panasport
Minilite
Superlite
Compomotive
Spruell Motorsports
AJPS, an Aussie shop
Acme Speedshop
allwheels.com.au
I’ll update if I get any replies with a yes.
M23 is offline   Reply With Quote
Old 02-19-2015, 08:56 PM   #268
M23
Drives: 86
So far, I got a reply from Panasport:
"Dear ...,
15x7 with high offset only available for 5x100 bolt pattern.
Wheels: Panasport High offset, 5x100 bolt pattern
Offset: +40
Finish: Painted Silver with shiny outer flange
Your price: $480 for a set of 4 wheels + UPS shipping charge
Best Regards,
Panasport Racing."
Sounds promising.. Idk if 15" would be too small though.
Isn't this one really 15" (of course, way cooler since it's wide and has ultra low offset dish/lip)
Old 02-20-2015, 05:11 AM   #269
MacOverSteer
MacOverSteer's Avatar
Drives: 2013 GT86
TRD teased these 15's couple of years ago..... Looks the business to me
MacOverSteer is offline   Reply With Quote
Old 02-20-2015, 01:42 PM   #270
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
"Dear ...,
Offset: +40
Best Regards,
Panasport Racing."
Wow, $480 for a set of Panasports?
I believe the one in that picture is Watanabe and cost around $600 per wheel.
http://www.rs-watanabe.co.jp/index2.htm
GuerillaRacing is offline   Reply With Quote
Old 02-20-2015, 01:47 PM   #271
alanhung85
Drives: 2014 Subaru BRZ Sport-tech Pkg
That appears to be a 4 bolt conversion?
alanhung85 is offline   Reply With Quote
Old 02-20-2015, 02:10 PM   #272
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Yeah those are Watanabe RS wheels. Custom 5x100 to 4x114 wheel adapters.
Old 02-20-2015, 02:13 PM   #273
M23
Drives: 86
Anybody know where to get those kinda adapters???
Even then, those adapters would be pretty thick, and push out the wheel even more; so, you'll most likely not even be able to run mild offset wheels under stock fenders.
Old 02-20-2015, 02:14 PM   #274
M23
Drives: 86
Can you convert the FT86 to 4x114.3?
If, yes, are there any 4x114.3 hubs (that can bolt up and has same spline) and rotors (that have the same size as the stock FT86 rotors) that fit; for minimal parts changes, ease of install and ability to re-use the stock FT86 calipers?
This would be great for much much more wheel options. Especially if wanting to get old-school or classic wheels and/or if wanting to go 16”. There’s literally hundreds of different, super awesome, classic wheels that AE86 people (and other classic Datsuns, etc.) have been using forever.
Old 02-20-2015, 02:19 PM   #275
TylerLieberman
Drives: '24 GR86
I imagine you could contact a company that produces wheel spacers/adapters and have them custom done at a price.
Not entirely sure who specifically can do it.
Not sure but I wouldn't even care to try. That's a decent amount of work just to run a single wheel. I'd rather just get adapters so that way I could always change down the road to something else if I wanted to.
Old 02-20-2015, 02:31 PM   #276
M23
Drives: 86
Yes..but adapters would most likely be 15-30mm thick.
Say if you wanted to run a nice classic wheel in 16x7 with et0 for example ..it's never gonna happen (or at least, not without fenders or if you're going for that super cambered "stance" look (which I'm not into)). It would be et-15 to et-30...waaay too much poke.
Old 02-20-2015, 02:32 PM   #277
TylerLieberman
Drives: '24 GR86
Then find different wheels or a different car.
Old 02-20-2015, 02:35 PM   #278
M23
Drives: 86
If you had 4x114.3 hubs..you can have soo many nice classic 16" wheel options. You can have diff sets and/or collect nice ones. Most are second hand and can be found inexpensively. Much more options than 5x100 and 5x114.3.
Old 02-20-2015, 06:30 PM   #279
Kostamojen
Ya don't run adapters... Not a good idea.
You might be able to find someone who can make custom hubs, but it would wind up costing thousands of dollars for that kind of work.
Plus 4-lug wheels are not a good idea for a car this heavy.
The Following User Says Thank You to Kostamojen For This Useful Post:
M23 (02-20-2015)
Old 02-20-2015, 07:20 PM   #280
M23
Drives: 86
This car is heavy? Lol
Datsun Z's are about the same weight and uses 4x114.3.
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 05:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 07:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-28-2012 12:20 AM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 09:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 12:17 PM
