Old 02-20-2015, 12:01 PM   #169
BRZFanatix
Drives: Soon to be BRZ
What up guys, finally joining the ST convo. Here's how she sits right now. Put the wheels and coils on during the Superbowl, and I'm loving the new look.
@bobsacamenoh... You wanted pics of how those wheels turned out. They look fresh to death man, thanks again.
Nice mang! 255 tires all around? How much of a drop did you do?? 35mm?
BRZFanatix is offline   Reply With Quote
Old 02-20-2015, 12:34 PM   #170
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
Thanks man! I'm rocking BBS CH-R 18x8 + 38. with PSS 225's all around. Didn't break out the tape as I am max low in the front and about 12mm higher in the back. Now that it's broken in a bit though I'm going to raise it by around 10mm because I'm getting a tiny bit of rubbing on the front tires if I hit a bump while cornering... I also think I'll put 10-20mm adapters in the rear because I love the small amount of front poke I have but the huge rear tuck drives my eyes crazy. haha
Special_K is offline   Reply With Quote
Old 02-20-2015, 12:38 PM   #171
BRZFanatix
Good shit! Can't wait to get my BRZ, whats the max drop on those coils since you said you were max low in the front?
Old 02-20-2015, 12:43 PM   #172
Special_K
Bannéd
Special_K's Avatar
I want to say 50mm or 2in. Somewhere right around that mark haha, feel free to correct me if I'm wrong... I was a little distracted by the Superbowl when I installed them.
Old 02-20-2015, 12:50 PM   #173
BRZFanatix
Looks about right! Good shit! If that's you installing that distracted you did a good shit son!
Old 02-20-2015, 12:54 PM   #174
BRZFanatix
For me, Im doing this when I get my ride:
18x9.5 Rota Grid (5x100/e38/73)
ST Suspension Coils
SPC Performance Adjustable LCA
And wheels:
255.35.18 All around
Thats all I would need, I thought I would need camber bolts in the front, but they are adjustable just like the KW's so Im getting the LCA for the rears. What do you think? Pretty sick huh
Old 02-20-2015, 12:55 PM   #175
Special_K
Bannéd
Special_K's Avatar
Thanks man, My roommate and I just worked through the commercials and halftime. Granted it took all day to do it that way, but we got it done... Driving it to the alignment shop the next day it was clunking something fierce in the rear, and I was sure I had messed something up. Turns out I just needed and extra turn or two on the top mount. So all in all no problems.
Old 02-20-2015, 12:57 PM   #176
BRZFanatix
What do you think about what I'm going to put on my ride? Its in the post above yours lol
Old 02-20-2015, 01:09 PM   #177
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
ST Suspension Coils
And wheels:
ST Coilovers do look good...
Here was my setup on ST Coils, dropped 1.25" on 18x9 +40 with 245/40/18.
Not quite the same as yours-but close, and it should look damn sick.
Also, I do NOT have adjustable rear arms (yet) and just from the drop I'm at -2.5 on the rear for camber...I've been like that for 15k, and have had very very little camber wear-its been pretty darn even. Im at 0 toe, btw.
Old 02-20-2015, 01:12 PM   #178
Special_K
Bannéd
Special_K's Avatar
ST Suspension Coils
And wheels:
The wheels will fit nicely with that +38 offset, mild poke in the front and tuck in the rear. I'm not sure what you mean by the fronts being adjustable, if you are planning on keeping the OEM top mounts then I would recommend putting a camber bolt up front. I have the SPC bolt in the front. If you are going to put in something like the Vorshlag top mounts then you wont need anything else. Do some checking around to see what kind of camber you will need to be running up front to fit that wheel/tire combo without rubbing or just head over the the will-it-fit thread because they have literally every combination already posted..
And for the rear depending on what you are going for, you might not even need the LCA. The natural camber from drop is pretty tame and a competent alignment shop can get you back in spec. That said, it wouldn't hurt and might make future modifications less of a hassle.
Old 02-20-2015, 01:15 PM   #179
BRZFanatix
How about these:
SPC Performance Cam bolts
Would that work for the front? Thats all I would need right?
Edit:
From what I heard, I can run that without needed any camber bolts in the front
Old 02-20-2015, 01:17 PM   #180
Special_K
Bannéd
Special_K's Avatar
^^What he said. Our cars are really easy to work on, and often times you can get away with adding a part at a time. So cars you'd have to rip out and replace everything all at once to get it all to fit right, i.e. brakes, susp, lca, mounts, bushings, rods, etc... But on ours you can start pretty much anywhere. LCA's are sick yea, but depending on what you're wanting out of your car you may be better off putting that $300-$1000 elsewhere to start.
Old 02-20-2015, 01:22 PM   #181
Special_K
Bannéd
Special_K's Avatar
How about these:
Edit:
I'm running that exact bolt in the lower strut hole. Maybe you can get away with not having it, I just threw them in and called it a day. Once I get my new top mounts I'll pull it back out.
Old 02-20-2015, 01:24 PM   #182
continuecrushing
With just using the adjustment slot on the ST coil for the fronts, I was able to get about -1.5...
but as @Special_K said, this car is great since you can add-on as you go.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
Pics of you!? Pics of your life?! seven Off-Topic Lounge [WARNING: NO POLITICS] 66 12-25-2012 04:49 AM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-11-2012 11:29 PM
