Old 02-19-2015, 04:36 PM   #15
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
I do have the exhaust leak fixed as of today and the car is running without CEL. I am noticing 2 things I've not noticed before and the 1st is a light rattle / grinding noise when I am making a left turn and engaging first gear (like turning into a plaza) I triple checked all bolts and nuts and everything is still on and solid, so I don't know what it is. I am *very* fortunate to have Nelsmar's help with this. He's really made a significant difference in the way it feels and runs.
The second is a smell I can't identify. Since I am now using a used stock header to replace my stock header, I suppose there could have been oil in it or something depending on how nice previous owner / user was to the damn thing. --- *** RESOLVED *** smell is gone, so what ever it was burnt up in the exhaust
I am about to reflash to tune version 1.13.5 and we will go from there (so basically version 1.18 of this tune.) I need a replacement snorkle though.
EDIT::: http://datazap.me/u/celadrielas/cel-...5?log=0&data=1 FLKC pings when I shift into 3rd for a second
For those interested - @JB86'd , @steve99, @nelsmar
Old 02-19-2015, 09:16 PM   #16
steve99
Drives: FT86
That is very minor knock -0.65 , it could also be due to the exhaust rattle you have causing knock sensor th think its knock. Check overpipe heat shields not the cause
Celadrielas (02-20-2015)
Old 02-20-2015, 12:26 AM   #17
Celadrielas
I don't have the stock over pipe or any heat shielding on the over pipe, but I didn't check the heat shielding on the replacement header. If that's be loosened that could be the ever so minor grind I was hearing. I'm not hearing anything anymore though
New TSB for RPM Drop connorlug Issues | Warranty | Recalls / TSB 24 04-25-2014 06:01 PM
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 03:53 AM
86 Drop top v3rgil AFRICA 0 03-08-2013 07:12 AM
looking to drop my car bjun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 03-01-2013 02:15 PM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 06:45 PM
