#15 |
Drives: 2014 BRZ SWP LTD
#16 |
Drives: FT 86
Toyota said they could not fault it...
The Power steering icon came on with the exclamation mark next to it when this happen. it wasn't totally locked but was extremely hard to turn like when you turn off the car and try to turn the steering.Just try that and see how hard it feel for you.
It was a hot day and I did have the aircond on at the time. Toyota wanted to send the car back to me because they cannot fault it and I am so scare to drive it again. What do you guy think I should do? |
#17 |
Drives: FT 86
Yes it is hard to turn...
#18 |
/dev/null
Drives: Uphill
Hey, is your car a Toyota 86 GT or a GTS? Your profile says "FT 86" which is a bit strange.
Also, would you please post a photo? If that warning light has been on it should turn up when Toyota scanned for error codes. Did they say they did not find any error codes, or that they could not reproduce the error? If it happens again: Pull over and stop the car. Engage emergency lights. Call for help. |
#19 | |
The aircon is separate and actually would have helped by keeping the cabin temp low. If it were me, I would continue driving with a little extra vigilance while looking to see if a pattern emerges. Maybe the thermal overload circuit is faulty and is triggering too early, or intermittently. That's how I would design it - as a failsafe instead of allowing a cascade failure. Like when circuit breakers eventually fail, they don't stick on. They flop open.
#20 |
Drives: 2014 Monogram Hot Lava
A) More push ups OR B) Sell it to me for a dollar. |
#21 |
/dev/null
Drives: Uphill
#22 | |
#23 | |
/dev/null
Drives: Uphill
U1201 - Invalid or Missing Data for Seat Motion / Control B14A1 - Open in Solar Sensor Circuit for AC unit So I would expect something as serious as a power steering problem to be logged, too. |
#24 |
Drives: 2005 Toyota Camry
#25 |
Drives: 2015 Series.Blue
#26 |
I should clarify: if your power steering fails at any speed and you can't control the car, you're either 1) driving too fast, or 2) need to know how a manual rack feels like to compensate accordingly.
Steering lock is a serious safety issue. Power steering loss is not a serious safety issue. -alex |
#27 |
Next question is........what were you doing just prior to the steering becoming hard?
Do some searches for posts from Element Tuning. Phil has an FRS that is a pure track car and he has run into this problem several times while on track. If memory serves me, the power steering is an electro assist and the unit is on the lower part of the steering column under the dash (I believe). There may even be some info in the owners manual about it. |
#28 | |
Drives: FT 86
if I still alive next time it happen then I will stop for help. |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| power steering | ender2664 | Engine, Exhaust, Transmission | 32 | 03-21-2015 04:16 PM |
| Electronic Power Steering Failure | tjdiz92 | Issues | Warranty | Recalls / TSB | 17 | 06-18-2014 01:34 AM |
| Electronic power steering | Mathewgzlz | Issues | Warranty | Recalls / TSB | 9 | 01-22-2014 01:50 AM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
