Old 02-17-2015, 06:29 AM   #3011
Raven604
Those bastards
Raven604 is offline   Reply With Quote
Old 02-17-2015, 08:47 AM   #3012
captain_jack
captain_jack's Avatar
Originally Posted by Andreas83 View Post
I checked the silicon hose that goes from the charger to the intercooler hotside pipe.
Its the correct hose for the c30 kit.
Well now you know you'll need that too at least and not get the 38 and not be able to use it due to this.
Old 02-17-2015, 03:32 PM   #3013
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
I am in contact with the vendor, the problem will be fixed without me spending anything but time.
I am in no rush, the car is parked for the winter and the motor is in pieces.
Andreas83 is offline   Reply With Quote
Old 02-17-2015, 05:07 PM   #3014
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Damn winter. I have my kit ready to install but we have almost 5 feet of snow on the ground and sub 0 temperatures. Nothing left to do but .
industrial is offline   Reply With Quote
Old 02-17-2015, 05:13 PM   #3015
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
I hear ya, so much snow here. I have gone through the entire kit countless times. Should have my tune from @moto-east anytime now then I'm ready to rock
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 02-17-2015, 05:16 PM   #3016
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Are you rebuilding your motor?
Alltezza is offline   Reply With Quote
Old 02-17-2015, 05:22 PM   #3017
shortcut
Drives: Frs 2013
Ok, so I bought the kit for Xmas and now I am buying the remaining stock that I need.
My questions for you guys:
1. How do you monitor? (gauge, OBD2 wifi with tablet, ...)
2. What do you monitor: Boost, air/fuel ration, Coolant temp, oil temp, ...?
3. Do you need an engine oil cooler? Since it is not using the oil from the engine like a turbo, I think the oil temp should not become way more hot than N/A.
Thanks
shortcut is offline   Reply With Quote
Old 02-17-2015, 05:37 PM   #3018
Andreas83
Andreas83's Avatar
Yes, spun a rod bearing.
New crank, bearings and a set of brian crower rods.
Old 02-17-2015, 07:10 PM   #3019
Scracho
Drives: 2018 Subaru BRZ
Engine stock when you spun the bearing? How many KM's?
I've come across too many "spun bearing" posts recently.
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 02-17-2015, 07:26 PM   #3020
Andreas83
Andreas83's Avatar
21000km NA with boltons&tune.
I posted some pictures in this thread a while ago.
I think i found the reason. A cover that seals up the oilports leading to the oil filter was loose.
Old 02-17-2015, 09:03 PM   #3021
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Thanks
Different people will monitor different things, My friend is running oil pressure and temp with Defi gauges along with AFR and Boost with a AEM failsafe gauge. I run just the AEM Failsafe with the lcd screen showing AFR and the led bars showing pressure. I use my Ecutek when i want to know temps.. For me here in Vegas my DD oil temps didnt change.. on a track im sure it would. but my style of driving i have no issues with temp. I do plan on running the Skunk2 ultra radiator that also has a oil cooler built in. but based on the heat of summer last year, it didnt change.. BUT a lot of people claim the oil temp gets high stock under brisk driving so it would not hurt to get one
86SPEED is offline   Reply With Quote
Old 02-17-2015, 11:36 PM   #3022
Barbas
Drives: 2013 whiteout Frs
Belt
When im in 1st at a stop i hear the belt make a noise. Once rolling it goes away it doest sound normal at every other time i dont hear it. I believe my belts to loose. I tried tightinging it with the 21mm thumb rule but the pulley does move anywere when adjusting. Am i missing something. C38 by the way other than that love the kit so far. Im just moving the bolt and the nut on the plate is there something else.
Barbas is offline   Reply With Quote
Old 02-18-2015, 11:09 AM   #3023
Derka
Drives: 2015 frs
I'm on a c30 but I can tell you their 21mm rule isn't accurate.
You first have to loosen the 14mm nut on the idler pulley. Then the 13mm jam nut on the adjuster bolt. Then use the 12mm bolt to adjust tension
Derka is offline   Reply With Quote
Old 02-18-2015, 04:38 PM   #3024
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
You have to loosen the pulley bolt for the plate to slide freely.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
