#99 | |
Drives: FRS-Raven-MT
#100 | |
DTCs associated with this have been turned off so you don't throw a CEL. Here's the MAF scale excel file and instructions to alter your own tune via RomRaider Grimmspeed Intake + OFH MAF Scale - 91 OCT - v1.03 http://www52.zippyshare.com/v/Vt4grbCP/file.html Here's my v2.06 D00C tune with cold start disabled, MAF scale already implemented. D00C GSI + OFH SCALED - 91 OCT - V1.03 http://www52.zippyshare.com/v/r9S0TIIb/file.html Last edited by Koa; 02-17-2015 at 11:24 AM. |
#101 |
This tune is for 93oct I am assuming right? I'm realizing the MAF scale on 93 and E85 are a tad different.
#102 |
#103 |
#104 | |
Please do a log after driving around for a bit @ 60F IATs (if possible) so we can compare. I can also help if you never re-scaled your MAF before. @vgi 's program is sooo nice.
#105 | |
OFT Tune for GrimmSpeed Intake
I was fooling around with the MAF scale program yesterday and it's super simple. What I am a little unsure about is the close loop and open loop scaling process. Should I take a couple logs of closed loop driving rescale and flash ecu then repeat process with logs open loop driving? |
#106 | |
Drives: 2013 FRS
#107 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#108 | |
For each load/mafv/throttle position/rpm instance, we're trying to scale the tune to provide an AFR as close to the target as possible. The MAF scale affects more than just metering air, including load & timing (someone chime in on this), implying it is beneficial for the system of a whole to scale the MAF appropriately for one's setup and climate. Therefore, we need to supply the program with enough data instances of these variables, including fuel trims, which is what the ECU is doing to fuel to compensate for differences between reported AFRs and the target AFR for each instance. -- SO, the methodology is to take logs that capture both closed loop and open loop data that is indicative of every-day driving, filter the data to arrive at a true picture of what's happening in the system, and then apply the formulas to the data & current MAF scale to arrive at a new MAF scale. There's differing trains of thought on this, but an understanding of what each variable (MAFV, throttle%, rpm, load, IATs, etc) does to the inputs to the system (engine) is very helpful. That's beyond the scope of this post, but refer to Steve99's MAF scaling threads where some very smart minds discuss these things. The process 1. Get your car up to operating temperature, around 15-20 minutes of driving for the tranny to come up to temp. Drive towards a place where you can put constant throttle and loads in varying positions- mountain trails and interstates on off-hours are what I find best. 2. Note the ambient and Intake air temperatures before you start. This is important because you'll only want to take logs and scale data that floats around the same temperatures. There is a MAF temp correction variable that will skew your results.. try to take logs around 20-25C, or zero out your MAF temp correction table in romraider if varying temps are an issue. 3. Start logging and drive as SMOOTH as possible, avoiding deceleration/idle and working your way up the gears and rpm/powerband very slowly but deliberately. Vary your throttle and loads, remember, we're collecting data of the engine doing work. This is perhaps where the 'art' comes into play. Most tuners have their own perceptions of what is the acceptable length and variation/runs in the log. What I do is take a 20-30 minute log of mostly 1/3-2/3 throttle/varying load closed loop driving... and near the end of the log, do 5 or so 3rd & 4th gear WOT runs, from 2k RPM to redline. I'm still trying to refine my techniques and methods of taking logs so this is an area where Kode, vgi, steve and other heavy loggers can chime in and give perspectives on. 4. Since VGI's tool makes it very easy to filter data, one could then scale open and closed loop in one go. - You use the same log.. Load your POL fueling, current MAF scale, and log into the Open Loop section and run the program - Copy/paste the new generated MAF scale from that section into the "current MAF scale" in closed loop section - Load the POL fueling, and log into the Closed Loop section and run the program. The methodology is that you take your entire log, filter out the closed loop data, and are left with open loop data. You then refine and filter it further (to get rid of tip-in wildcard and outlier distortive data) until you're left with solid open loop data that the program can then use to calculate accurate corrections to your current maf scale. Then, repeat the process for closed loop by removing the open loop data and refining it for useful info and accurate rescale material. Awesome post by Kode that explains his VGI program settings Here's Steve99's MAF Scaling via trims thread
#109 |
Don't forget that rescale of the maf changes the calculated load and this the timing values at any given airflow and rpm point that is affected by the maf scale.
~Namaste~ |
#110 | |
Not very eloquently of course and with a call to others for clarification.
#111 |
@steve99 mentions in his that that OFT uses fuel trims to compensate for the variations of %E so it is not recommend to rescale MAF. What does he mean by this?
@Koa Thanks a bunch for all the help and info. My LTFT are still a bit high, but much better after the rescale. One thing Iv'e noticed is my AFR's on my OFT when I run E85 never reflect actual AFR's. It looks as though I am running petrol, and I know E85 runs much richer. Any idea why this is so? Edit: NVM found my answer in @steve99's thread.
#112 | |
Drives: FT86
when your on e85 the e% varies with season and with different brands. We are lucky in oz as we have a pump e85 that is e85 guaranteed so it just as easy to scale maf on that e85 as petrol. with your varing e85 you would need to scale maf on an average e% that you get maybe E70 or whatever in the middle of the range and effectively end up with a compromise maf scale then rely on fuel trims to sort out the variation. You would need to get an ethanol percentage test kit and test your fuel. |
| DIY - GrimmSpeed Intake Installation Guide | GrimmSpeed | DIY (Do-It-Yourself) Guides | 60 | 09-08-2017 10:12 AM |
| ** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** | GrimmSpeed | Engine, Exhaust, Bolt-Ons | 1902 | 08-29-2017 07:47 PM |
| GrimmSpeed Intake Before and After OFT Tune + Review | F1fletch | Engine, Exhaust, Transmission | 76 | 06-30-2016 02:40 PM |
| For Sale: GrimmSpeed Intake *newish* | xDanger_208x | Engine, Exhaust, Bolt-Ons | 13 | 11-30-2014 10:16 AM |
| WTB GrimmSpeed intake | VakaGT | Want-To-Buy Requests | 0 | 11-18-2014 12:19 PM |
