Old 02-10-2015, 04:12 PM   #1
Zinger
Drives: 2014 Scion FR-S
Oil Change - Seattle Area Dealerships That Use 0W20
Howdy all!
I am due for my first oil change on my 2014 FR-S and wanted to see if anyone can confirm if any dealerships in the Seattle area are using the factory recommended 0W20 oil? If so, is it something you specifically asked for or did they just know? Imagine they don't see that many of our cars coming through and may just auto-pilot on 5W30.
Thanks in advance!
Zinger is offline   Reply With Quote
Old 02-10-2015, 11:13 PM   #2
Chanpion
Drives: 13 FRS Satin
All Scion dealerships. They know. Guaranteed. If they mess up, they'll pay for it anyways. Remind them when you get in if you're really paranoid.
Chanpion is offline   Reply With Quote
The Following User Says Thank You to Chanpion For This Useful Post:
humfrz (02-11-2015)
Old 02-11-2015, 01:46 AM   #3
The dealership in Puyallup uses 0-20, but you may wish to confirm with any dealership what oil they use ....
Old 02-12-2015, 07:06 PM   #4
jfg5067
Do it yourself? Then you are sure to use the right oil? This was one of the easiest cars I have ever done an oil change on quite honestly...
jfg5067 is offline   Reply With Quote
Old 02-12-2015, 07:23 PM   #5
bababooey
Drives: BRZ SWP Limited -6MT
or you can confirm their understanding of the weigh needed when you drop it off. i recently got a change and the twins werent even in their system but they had the weight.
i suspect because many owners likely got theirs from dealerships that may have included the first (if not couple) change/s free. i was not afforded that offer having bought 2nd owner.
bababooey is offline   Reply With Quote
Old 02-13-2015, 01:34 AM   #6
Koa
1. free from dealership for your warranty boost period
2. documented from dealership saying everything was done right
3. did I mention free?
4. Nobody is doubting your wrenching skills.. oil changes are so hard usually
Old 02-16-2015, 10:47 PM   #7
Zinger
Howdy again!
Confirming Scion of Kirkland does use 0W-20 oil. It appears they overfilled by about 1/4" on the dipstick. Going to verify with them tomorrow if that is acceptable or if they need to remove some.
Old 02-16-2015, 11:55 PM   #8
Koa
Originally Posted by Zinger View Post
Howdy again!
Zinger it's common, and believed good insurance, to 'overfill' subaru boxers a smidge. Starvation at high lateral G's (probably won't see it on the street) were a problem on the EJ motors and some people would put 6 qts in at each oil change, when the factory fill was I believe 4.8-5?
I assume they're following the logic here. 1/4" the OTHER way, low, would be a definite problem. Take this with a grain of salt because I do not know if the oil passages and pump system are sensitive to overfilling, but my previous experience with all sorts of EJ engines indicates it's good practice to be full or a little over at all times.
Seattle area - need some assistance jfg5067 Northwest 7 06-03-2014 08:45 PM
Seattle Area Body Shops vwong Northwest 4 02-19-2014 12:08 PM
Seattle-area autocross? Stu L Tissimus Northwest 1 02-07-2014 09:24 PM
Seattle Area Wraps ~ Guardline Drift-Office Northwest 12 01-29-2013 04:03 PM
Anyone had a clear bra applied in the Seattle area? seven Northwest 1 09-28-2012 06:59 PM
