Old 02-14-2015, 12:13 PM   #1
Derka
Drives: 2015 frs
Target afr
Good morning guys. I've searched and found some info. But some if it is conflicting. I know there are a ton of variables, but if you could pick a number. What would your target afr be on a supercharged frs on about 10lbs at wot.
I know it's a noob question, I'm not tuning my car, just trying to keep a safe eye on the wideband. Thanks!
Derka is offline   Reply With Quote
Old 02-14-2015, 09:03 PM   #2
steve99
Drives: FT86
probably best to post this in the forced induction thread,
best to ask your tuner what afr they are targeting or look in your tunes ol fuel table
or talk to @King Tut think he has one of those aem wideband guages
Old 02-14-2015, 09:40 PM   #3
aagun
Drives: 86
11 - 12 at boost
aagun is offline   Reply With Quote
Old 02-15-2015, 10:57 PM   #4
burdickjp
Drives: 2013 ultramarine Scion FR-S
0.85 lambda (12.5 AFR) is usually the bottom end of MBT, aka maximum brake torque.
I aim for 0.9 lambda (13.25 AFR), which tends to be dead center of MBT.
Top end of MBT is usually 0.95 lambda (14.0 AFR).
burdickjp is offline   Reply With Quote
Old 02-16-2015, 04:59 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Even on this engine? AND supercharged???
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-16-2015, 06:55 AM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.afrplus.com/AFRplus-unit-functionality.asp
Old 02-16-2015, 08:58 AM   #7
burdickjp
It is more a matter of chemistry and thermodynamics than mechanics.
Most of the reason people go richer is to compensate for knock and then try to edge out more power. The power you make in that manner is fragile at best, and catastrophic at worst. Cars tuned this way are temperamental and unpredictable.
In this case conservative tuning isn't running richer, it's running MBT and the appropriate ignition timing to suit.
Old 02-16-2015, 10:50 AM   #8
jester04
Drives: Subaru impreza STI, subaru BRZ
This is not always the case there are afr ratios that will produce the best power theoretically but on a boosted engine the cylinder needs to be cooled somehow. And timing and fuel determine how hot the cylinder will run and how high pressures will be so don't misinform people about afr's without looking at the specific setup the car is running.
Best advice here ask your tuner.
jester04 is offline   Reply With Quote
Old 02-16-2015, 10:59 AM   #9
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I think based on what my tuner set me to 11.1-11.7, i'm at 8psi. I'm sure there are variables and other things i'm not getting into because i simply dont know but to answer the OP's question.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-16-2015, 12:19 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
Really? You must be one of the only sources I've heard to tune like that. Purely tuning to 12.5:1 or leaner just to produce best AFR produced torque.
I'll also note here that finding MBT is actually done by changing ignition timing and not the AFR, not that AFR doesn't have an impact.
Why do you think that running slightly richer but with more timing makes it more fragile or temperamental? You could argue that running some of the AFR range you specified at high RPM would cause too much heat that could damage components and almost certainly would kill cats. Surely the answer is you want the ideal middle ground, not sticking to an AFR as not all engines or setups are that theoretically perfect
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-16-2015, 08:07 PM   #11
burdickjp
There's a torque plateau for ignition timing and air/fuel mixture. So there's a similar process for finding best AFR as there is for best timing. The plateau is broader and flatter for AFR.
You'll note I didn't set hard bounds for MBT. it's something you find empirically.
The Following User Says Thank You to burdickjp For This Useful Post:
Shiv@Openflash (02-17-2015)
Old 02-17-2015, 11:08 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
He is right about finding the best AFR and MBT, but tuners generally run richer not to make more power, but to provide more protection. Most tuners will target from 11:1 to 12.5:1 for a forced induction application.
Old 02-17-2015, 02:02 PM   #13
burdickjp
It's the same thing. They're trying to run more advance by adding fuel. Less fuel and less advance is healthier.
Old 02-17-2015, 04:55 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
No it's not. Running richer keeps things cooler, which has it's own purpose. I'm not sure how you equate running hotter is healthier?? Less fuel AND less ignition advance = hot EGTs, which over a length of time isn't likely to be good for valves or exhaust components.
It might be worth noting that the OEM tunes this car richer than you suggest, would you consider that unhealthy?
.: Stealth 86 :.
Kodename 47 DJ:
50$ at target don't know what to get 1GiantTurtle Off-Topic Lounge [WARNING: NO POLITICS] 47 01-11-2015 01:42 AM
Idle Speed Target A-F acj47 Software Tuning 0 12-09-2014 12:52 PM
FRS rc car @target $20 mush Scion FR-S / Toyota 86 GT86 General Forum 41 08-22-2014 02:38 PM
Free credit monitoring from Target torqdork Off-Topic Lounge [WARNING: NO POLITICS] 0 01-14-2014 03:11 PM
Edmunds target launch 1660 Scion FR-S / Toyota 86 GT86 General Forum 49 08-18-2011 05:56 PM
