#29 |
OG <FR-S'less> Member
Drives: yes
Looks awesome. Any idea on cost?
#30 | |
Well hello there Mr Andrews. It's Adam.
#31 | |
Hot Dog
Drives: quicker than arghx7
+1, thanks on the information. I'd love to see some "after" pictures with your new ride height. The pricing sounds reasonable for a custom-spec setup. If you ever come across the damper curves I'd appreciate taking a look at them.Cheers, Ryan
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#32 | |
Site Moderator
Drives: ichi 86 Project
#33 |
Registered you sir
Drives: 99 impreza coupe
Wow, thanks for all the great updates. Congrats on the cool coils.
Some wise questions on here; the dyno plots (wouldnt put anything on my ride without them- another can of worms) alignment specs (were they originally confirmed at OE spec or were they off any? And what have they been changed too?) And what were the results and modifications to all the corner weights? |
#34 | |
Drives: Many types of cars in R&D.
It will be on sale starting next week!
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. |
#35 | |
As for me, I had my car corner- weighted at each end with me in the car, precisely to center the contact patch between left and right. I didn't worry too much about fore/aft adjustments, as that is more inherently dependent on what type of racing, venue, and tires/brakes and adhesion and it can vary greatly, so I just left the overall balance alone from stock, and accepted the change slightly, just to personalize the looks of the car (height fore/aft) as more a priority (Yes I like my fast cars, looking good too, but functional. )
Moto Miwa
#36 |
I would even consider going to 5kg/mm F and 4kg/mm R just to give it more compliance and get it back near stock, as RSR Super-i seems to have plenty of piston travel at 30mm down, and I am fond of supple compliant suspension even on the track, and prefer to use modest grip tires, rather than higher grip $$ tires for cars like this (unless I am racing for trophies and time)
Moto Miwa
#37 | |
Site Moderator
Totally agree, this car is nice w modest grip tires... unless going for the gold lol |
#38 | |
![]() Ideally though, for race track use, I like to use probably something like 18x8.0 or 8.5, with TRD N1/Taikyu- specified tire size of 225/40ZR18 +45~48 on all four to keep the inherent balance and alignment data. For street, just about anything goes as I am of the 80's tuner mentality, and I like them low, flush, and functional... The last word 'functional' being the key word though. not mad camber and not hellaflush widebody ride on sidewall craziness...no.. LOL! So perhaps a 18x9? 19x9? slightly pulled tire and agressive offset of about +30 on deep rim 3 piece? I dunno. I'm curious what HRE will pull out of the bag (though they are not casually affordable by any means), as well as new line from Volk, Work, SRR, and Enkei as well for this car rumored. Pro-Drive in white would be nice and racy too though!
Moto Miwa
#39 | |
1. Single adjustable, but they do custom design each application to the cars, so the balance of how they change in relation to the requirements are pretty spot-on in my previous 4 sets I used on each car. 2. RS-R manufactures and designs the case, piston, valves and all hardware components in-house, and I've visited the manufacturing facilities near Osaka, Japan, so I trust them that much. 3. These are aircraft grade aluminum shell cases and ends, (I forgot that the actual T rating of the alloy). For the FRS set, the suspension coil and shock assembly with mounts, weighed 3lbs less than OEM parts removed to replace (total of all four ends). While the OEM's weight is mainly in the large coil springs, the majority of weight on the RSR Sports-i is in the case shell and valve/piston which seems much more strong than OE internals and shell case. 4. Due to the very long lower arms and steering rack pivots as well as toe-locator rods, the FRS needed minimal correction of 0.4 mm at both ends of the rack-ends, to bring the toe back to where it was originally with OE height, this, at 32mm drop. I'd need to re-check after a few dozen miles to see if any settling of bushings or springs caused any changes, but that's what I see at this time, 1 day after installation. Yes, I am in Los Angeles/South Bay area and hope to meet you soon for a cup of coffee or snacks~!
Moto Miwa
#40 | |
Kuruma Otaku
Because titanium. |
#41 | |
Isn't that amazing? Porsche, BMW, and recent MB also does this, because they have firms like AMG, and M Sport consulting in the same way the FRS teams were influenced by inputs from many aftermarket and in-house, as well as the more sophisticated tuner industry and amateur and pro private racing operations.
Moto Miwa
#42 |
Sure, I'll be visiting RSR often just as in the past, and I will try to get a damper data for standard RSR application for the FRS/BRZ units. I'll have a pic of AFTER shots, when I have time, on stock wheels, so there is a good visual reference.
Moto Miwa
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 02:53 PM |
| US Subaru BRZ Port Installed Accessories and Packages List and Prices | eikond | BRZ First-Gen (2012+) — General Topics | 42 | 04-28-2015 07:45 PM |
| Live Pics of Subaru Boxer Sports Car Architecture (BRZ) from Geneva! + Press Release | Hachiroku | BRZ First-Gen (2012+) — General Topics | 103 | 09-14-2011 04:05 PM |
| Dealer Installed Badges | ToyotaObsession | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 05-14-2011 12:16 AM |
| Turbo FT-86 G-Sports pics from 2010 Australian International Motor Show | Calais | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 49 | 11-04-2010 05:40 PM |
