Old 02-13-2015, 11:55 AM   #1
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Skunk2 ultra radiator
Does anyone have any info on this radiator with liquid2liquid oil cooler buildt into the end tank?
This looks similar to what robispec made before.
Found some info here: http://www.ft86speedfactory.com/skun...oler-1965.html
Cant find anything about it on http://eu.skunk2.com/
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
DAEMANO (02-13-2015)
Old 02-13-2015, 12:01 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
can't see any pics and link doesn't work, but aren't some AT radiators like this for AT fluid cooling?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-13-2015, 12:12 PM   #3
Andreas83
Andreas83's Avatar
Try the links now.
AT radiators have a AT oil cooler some times.
But I think this is for motor oil.
Old 02-13-2015, 01:08 PM   #4
aznatama
aznatama's Avatar
Transmission oil, motor oil, same thing.
Seems like a good option instead of a separate oil cooler, especially if you just need a slight boot in cooling capacity. What's your purpose for it?
'14 BRZ LTD MT DGM
Old 02-13-2015, 01:25 PM   #5
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Defenitely interested.. not sure if Skunk is as good as koyo but the integration of the oil cooler is a nice plus. It doesn't come with fittings or anything right, not specific to frs/brz?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-13-2015, 01:29 PM   #6
DAEMANO
Time Traveller
@KraftWerks any additional info, installed/ation pics, specifications (weight, dimensions), hardware requirements, fittings etc would be greatly appreciated.
Old 02-13-2015, 01:31 PM   #7
kbye
kbye's Avatar
Drives: 2014 FR-S
Interestingly enough, FT86SF lists it as manufactured by koyo. Not sure if it's a typo.
I would wager that the oil lines, fittings, sandwich plate, etc are bought separately. It would be nice if it was all packaged together, though.
Looks like a good alternative to robispec which had some production and clearance issues.
kbye is offline   Reply With Quote
The Following 2 Users Say Thank You to kbye For This Useful Post:
DAEMANO (02-13-2015), yomny (02-13-2015)
Old 02-13-2015, 01:31 PM   #8
yomny
yomny's Avatar
Seems Speedfactory has them but still no fittings or anything made to work as a direct fit with our cars.. im sure its not hard at all to get some fittings and lines sorted out.
The Following User Says Thank You to yomny For This Useful Post:
Old 02-13-2015, 01:34 PM   #9
yomny
yomny's Avatar
Shouldn't be hard to source the parts for the install knowing the fitting size coming off the radiator. I just recently had all the parts needed karted in the autoraceparts webiste for my own diy oil cooler. I did see the koyo manufacturer on their site, does provide more peace of mind and sure beats the $1K+ price tag on the robispec. Also seems that just the ultra model is made by Koyo, i'm confirming this with them.
Old 02-13-2015, 02:13 PM   #10
Andreas83
Andreas83's Avatar
Here is a pic of the robispec radiator.
I am installing a kraftwerks C38 kit, the ultra radiator combined with this adapter would make the install alot easier.
Then I would not have to worry about fitting a oil cooler in the front as well.
This sandwich adapter does not have a thermostat.
So its perfect for a liquid/liquid cooler. And it clears the C38 kit.
DAEMANO (02-14-2015)
Old 02-14-2015, 12:22 AM   #11
AlexBinJackson
Drives: 2015 Brz Blue Series Pearl White
A word of warning when thinking about dealing with robispec
I would suggest to find a different route
AlexBinJackson is offline   Reply With Quote
Old 02-14-2015, 02:20 AM   #12
SPCorBUST
SPCorBUST's Avatar
this would be nice. i was actually hoping to go the robispec route, but this might work. cheers to someone else as the guinea pig though
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 02-14-2015, 02:35 AM   #13
AlexBinJackson
I have a koyo rad and perrin oil cooler work great so far for now but do plan on supercharging soon and will figure a way for oil cooler to fit, I was a guinea pig for Robi and that didn't work out too well.
Old 02-14-2015, 02:51 AM   #14
SPCorBUST
SPCorBUST's Avatar
i think you might be fine with those - several KW and JR kit folks are using similar setups with success. you can pop into the owners threads in the forced induction section and ask, i think both threads are pretty helpful in that regard.
just be careful of the kool-aid. seems like you "have" to be one camp or the other in those threads, consumer due diligence seems to be frowned upon.
The Following 3 Users Say Thank You to SPCorBUST For This Useful Post:
AlexBinJackson (02-14-2015), Calum (02-15-2015), Jmonty (06-02-2015)
Skunk2 Header? FirestormFRS Engine, Exhaust, Transmission 69 10-11-2019 10:42 AM
Skunk2 Review. FirestormFRS Engine, Exhaust, Transmission 1 12-31-2014 09:55 PM
Skunk2 BRZ Intake Results! Xero-Limit Engine, Exhaust, Transmission 21 10-20-2014 02:43 PM
New skunk2 frs brz cold air intake 831GT86 Engine, Exhaust, Transmission 17 09-09-2014 05:09 PM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 01:18 PM
