Old 02-11-2015, 11:52 PM   #197
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
thx for the reply mate.
As we have more or less the same environmental conditions here (except proper fuel), it would be most advantageous to get a tune from you I recon
GeeTee86 is offline   Reply With Quote
Old 02-12-2015, 09:14 AM   #198
Dammod
Dammod's Avatar
Drives: .
Originally Posted by GeeTee86 View Post
Needs some help here.
If you look at the attached file, is it possible to have neg fine correction (this is retard from knock right), and still have a 1 IAM?
@ steve99
full file:
ProECU-SubaruBRZ-EU BRZ Manual High FD (ZA1JA01G)-07-02-2015 16-28-10_review.csv
Overall the datalog looks ok, however, I find it extremely difficult to believe the developed map is well suited for our 95 pump fuel at low altitude / coastal conditions. The map will however be more well suited for higher altitude, but even so, not under all driving and ambient conditions. Lessons learnt from the development we have done, and what I have heard with my own ears via electronic detcans, its best the vehicle running this map be on higher octane / octane boosted fuel.
I few "constructive" observations to point out:
  • Long-term fuel trims are seen during WOT, which possibly indicates that the MAF sensor scaling calibration is off and being carried over to OL from CL.
  • There are signs of the ecu retarding timing low down and at WOT, which needs to be investigated.
  • The AFR's the motor is seeing are too lean.
  • Ignition timing is overadvanced.
  • Fueling, Engine load, MAF g/s and voltage show fluctuation, which could be due to incorrect Injector Timing; Direct/Port Injection Split; AVCS overlap; and/or MAF Scaling.
Regards,
Marco
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 02-13-2015, 12:17 AM   #199
GeeTee86
86 Nut
GeeTee86's Avatar
Damian upload last nights log into datazap so we can all review it.
I believe it was on E50?
Old 02-13-2015, 02:10 PM   #200
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
@ steve99
full file:
Well from what we are seeing, this looks very good. I would suggest that you investigate what a stock tune does on a stock vehicle in South Africa; you will find this is vastly improved over the factory tune.
The timing values are what we expect and what you should see. Having a Fine - Ignition Correction of -1 is to be expected within the powerband, especially down low. Stock cars exhibit much harsher corrections in this area. Even renowned tuning facilities such as Cobb Tuning state in their tuning guides a value of -2.1 or lower is to be expected out of a Subaru engine.
The AFR is also right in line with what we would expect for a NA car. In fact, you could even say it's a little on the rich side and you could safely see a little more power by leaning it out a bit more.
The AVCS and Direct Injection values we use have been extensively tested on a MAHA "manufacturer" spec dyno. Here is a video of the testing procedures we go through with our tunes.
[ame="https://www.youtube.com/watch?v=IYBeD3drCK8"]Delicious Stage 1 Endurance Dyno Testing - YouTube[/ame]
All this and we still have the most powerful remote tune in South Africa, with values that clearly display a much happier engine than what you get from the factory.
Feel free to contact us directly if you have any questions about your tune in the future, we're always more than happy to help out.
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
GeeTee86 (02-14-2015), Ryan86 (02-14-2015), sav (02-14-2015)
Old 02-13-2015, 03:24 PM   #201
GeeTee86
86 Nut
GeeTee86's Avatar
Thx for the reply William. Funny how phoenix says its not good
Old 02-13-2015, 04:14 PM   #202
Phoenix*
Drives: Mitsubishi Evo VIII
@DeliciousTuning
Your views have some validity, but also holds inaccurate statements inline with our pump fuel properties. Do yourself a favour and fly to South Africa and listen to the motor with electronic detcans. The knock frequency of our pump fuel differs and is not always detected by the ecus knock calibration settings, unless recalibrated.
The motor therefore knocks without ignition retard correction occuring.
Becareful to not misinform your South African customers based on your USA developments, in turn creating a false analogy.
@GeeTee86
My views on the datalog are honest and true.
I have been tuning Subarus for 10+ years, and I understand the temperament of these motors and our pump fuel exceptionally well.
I replied for your best interests...not mine.
Regards,
Marco
Phoenix* is offline   Reply With Quote
Old 02-13-2015, 05:44 PM   #203
DeliciousTuning
Originally Posted by Phoenix* View Post
@DeliciousTuning
@GeeTee86
Regards,
Marco
Well I hate to say it but time to freshen up your knowledge of knock sensors and how they work. Might be worth looking into a Motec SKM course. This course is really informative about how knock detection systems work on vehicle and how the internal knock noise frequencies are created from the engine harmonics, not fuel properties.
[ame="https://www.youtube.com/watch?v=Hpc27LV8CPc"]M1 ECU Training: Setting up knock control - YouTube[/ame]
Quick video on how to setup knock control with MoTeC.
So no matter what blend of fuel you put in your vehicle, knock is knock and it is interpreted the same way in every BRZ/FRS/86 around the world.
I have no idea why you are using det cans, they were around before knock sensors even existed. Knock sensors are far more sophisticated, and can detect knock at a far smaller level than your ears with det cans could ever hope of hearing.
By the way we have been at this for 15+ years.
Cheers,
William Knose
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
Alang (02-14-2015), GeeTee86 (02-14-2015), Ryan86 (02-14-2015), sav (02-14-2015)
Old 02-14-2015, 02:50 AM   #204
Phoenix*
@ William
I have "extensive" MoTeC training and have been tuning MoTeC platforms for years. Are you perhaps a "qualified" Mechanical Engineer with a Masters specialization in Internal Combustion engines..?
For a tuner like yourself that has supposedly been tuning Subarus for 15+ years, I am dumb founded by you saying that knock cannot occur without OEM ecu detection.
Please quote this statement on NASIOC and see how it will be challenged and ripped to pieces!
Your reply has once again confirmed your true lack of knowledge in understanding conditions within the combustion chamber. Unfortunately you are not speaking to an average Joe here, but I see your angle now...you are using your self-proclaimed reputation to come across to novice masses as if you have all the technical answers.
Please go educate yourself on laminar and turbulent fuel flame propagation rates, auto-ignition properties, detonation frequencies, and especially deflagration to detonation transitions (DDT).
Regards.
The Following 2 Users Say Thank You to Phoenix* For This Useful Post:
Dammod (02-14-2015), FT_86_SM_GP (02-14-2015)
Old 02-14-2015, 03:00 AM   #205
GeeTee86
86 Nut
GeeTee86's Avatar
Ohhh dictionary came out now. Where's my popcorn
The Following User Says Thank You to GeeTee86 For This Useful Post:
sav (02-14-2015)
Old 02-16-2015, 11:09 AM   #206
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
is the knock just a bad tank of E85?
http://datazap.me/u/itsjustdavep/215...a=0-1-2-3-4-13
I've been running the same 2.063 E85+EL tune for a month now and that's never popped up
itsjustdavep is offline   Reply With Quote
Old 02-16-2015, 08:28 PM   #207
itsjustdavep
guize, dis is bothering me
http://datazap.me/u/itsjustdavep/216...0&data=1-2-3-4
Old 02-18-2015, 11:23 AM   #208
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Whats your concern? If its your KC learned value take a look here...
http://www.ft86club.com/forums/showthread.php?t=71913
The only thing that looks a bit off is you're running very rich on your WOT pull 11.25.
Other than that you have pretty minimal knock.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 02-18-2015, 12:11 PM   #209
itsjustdavep
It's rich because I'm all stock running a e85 tune. But thanks for that thread. I can sleep easy now
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
Old 02-22-2015, 06:55 PM   #210
JB86'd
JB86'd's Avatar
Drives: JAWS
flashed the stage 2 uel 91 oct tune with my OFH earlier today, this is after about 40 miles of learning. I'm seeing some higher fuel trims on low rpm light throttle (~ +10-12%), under heavier acceleration I think it's looking okay. Hopefully the higher fuel trims go away after more learning. If I had an exhaust leak near the 02 sensor wouldn't fuel trims be off during heavy load as well?
How's it look?
http://datazap.me/u/joshbustos86/206...=1-4-7-9-12-14
JB86'd is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
