Old 02-13-2015, 12:45 PM   #15
Hotrodheart
Hotrodheart's Avatar
Originally Posted by RockySDS View Post
OK maybe it's not stock, but the latter part is true.
Hit the dyno on Tuesday in Denver with our friend William Knose of Delicious Tuning for him to work a little bit of his magic on #RevvProjectBRZ!
The results:
There's also a good bit left in her as well. Ran out of fuel flow up top thanks to the stock fuel lines. Still had a couple pounds of boost as well as about 7 degrees of timing left to really push her. Once we get the lines resolved we'll get back on that dyno for the big numbers.
Huge props to Bill @ Delicious for killing it with the tune. I have to say that without his traction control, the 600hp is pretty damn hard to put down. He threw the book at this build with his full flex fuel kit, dynamic barometric compensation & boost control, flat-foot shifting, downshift throttle blipping (this is a badass cheat lol), and that traction control. I'm putting together a full vid walking through everything he/we did so let me know if there's anything you want me to address in terms of drivability or tech.
All I have to say is it's amazing how drivable this car is right now. Ridiculously "linear" power band makes it super fun to drive, an absolute asshole when you lay down the throttle (even 20% it gets ridiculous) and feels stock when just putting around (ok, aside from my twin-disc clutch).
If you guys haven't been following along with the build, check out our build log on here:
http://www.ft86club.com/forums/showthread.php?t=58407
or our blog where we document the entire build process:
http://www.revvolution.com/blog/Plat...-BRZ-Scion-FRS
and here's a shot of her incase you haven't seen:
My FR-S has 600 h.p. and is stock as well. It has three engines, one in the rear, and one where the back seat used to be. Totally stock.
Hotrodheart is offline   Reply With Quote
Old 02-13-2015, 12:46 PM   #16
Koa
This blew us away with how big of a difference it made. It was literally the first "mod" we did, and while we only drove it around on the streets, it was more than noticeable. But I wish we could've tested it out on the track after seamwelding and before all the other suspension mods to really understand how much of a difference it made. It was a ton of work
Would you recommend seam welding for weekend warriors/hardcore enthusiasts that do light track duty? Or is the cost versus benefit ratio outside of what most should do? @MAPerformance , @DeliciousTuning , et all feel free to chime in.
Old 02-13-2015, 12:48 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
Way more work than what it is worth unless you're doing an over-the-top build.
The Following User Says Thank You to Pat For This Useful Post:
Koa (02-13-2015)
Old 02-13-2015, 01:17 PM   #18
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Sometimes when it comes to cars, logic need not apply.
That's how you create memories.
The Following User Says Thank You to dem00n For This Useful Post:
Koa (02-13-2015)
Old 02-13-2015, 01:18 PM   #19
RockySDS
Almost ******
Drives: 2014 Subaru BRZ
Unless it's a full-blown race car seamwelding shouldn't be considered (cost-benefit). It requires basically stripping the entire car down to the chassis
RockySDS is offline   Reply With Quote
The Following User Says Thank You to RockySDS For This Useful Post:
Koa (02-13-2015)
Old 02-13-2015, 01:27 PM   #20
Porcupint
Drives: 13 GBS BRZ
Three engines and you only got 600 horsepower out of it?
Porcupint is offline   Reply With Quote
Old 02-13-2015, 01:36 PM   #21
Koa
That may be true, but our time on this Earth is extremely limited and for some, yes, the build is all that matters. For others, me included, I have moved away from doing illogical upgrades and spending more time in seat, so to speak. I'm a little jaded and tired of having projects that spend more time on jackstands than pounding tar
The Following 2 Users Say Thank You to Koa For This Useful Post:
strat61caster (02-13-2015), Tcoat (02-16-2015)
Old 02-13-2015, 02:07 PM   #22
Teseo
Drives: frs
Top notch build. Wich ecu have? Im very curious about the auto blip.
Congrats
Old 02-13-2015, 02:29 PM   #23
dem00n
dem00n's Avatar
Drives: Scion FRS
As someone who wouldn't of existed if logic were present, i agree to disagree.
Gotta love mistakes.
Koa (02-13-2015)
Old 02-13-2015, 03:13 PM   #24
RockySDS
Almost ******
Congrats
Stock ECU, tuned on ECUTEK by Delicious Tuning. Just got done talking with somebody else about this feature and it's impressive, once you learn to use it. To activate it you need to have your foot on the brake. If you're use to blipping before punching the clutch, it's a difficult transition lol
Teseo (02-13-2015)
Old 02-13-2015, 03:18 PM   #25
Koa
you aren't a mistake bro bro.
and I don't disagree with you, just letting you know how I feel about it. There's no right or wrong
Old 02-13-2015, 03:42 PM   #26
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'm glad people are pushing the envelope, the guys who blow up the engines doing 600 horses are going to learn stuff that helps the rest of us get reliable horsepower gains. Getting 200+ horsepower to the wheels on this car makes it quite formidable in the right hands (and it's already pretty quick stock), if the aftermarket can get us up to 300 at the wheels reliably (with the $$$ of course) we have a giant killer.
inb4 LSX swap
Teseo (02-13-2015)
Old 02-13-2015, 05:52 PM   #27
RockySDS
Almost ******
Congrats
inb4 LSX swap
I like to think that our team has developed a platform where we're not just going to "blow it up". Didn't over engineer, just built it to handle a specific target.
Old 02-13-2015, 06:58 PM   #28
strat61caster
Apologies, didn't mean to imply as such.
Only meant to emphasize that the guys pushing the limits deserve praise, the rest of us reap the rewards of the research you guys are doing.
Broke the stock overpipe bolt :/ Sniper2606 Engine, Exhaust, Transmission 44 04-26-2015 01:19 AM
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 09:04 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
