Old 02-12-2015, 09:35 PM   #2969
ExquisiteStance
ExquisiteStance's Avatar
Drives: Brz Series Blue
Originally Posted by Kosmos View Post
Anyone on air lift? Question: do your wheels rub on your ba
I'm running 18x9.5 on the fronts with no camber and no rubbing yet. Can't really Add camber from the plates cus they'll rub.
ExquisiteStance is offline   Reply With Quote
Old 02-15-2015, 11:56 PM   #2970
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
What's your offset? If you don't mind me asking. I got new wheels 18x9.5, 0 offset so I'm trying to get an idea
Kosmos is offline   Reply With Quote
Old 02-16-2015, 03:08 AM   #2971
NickGTI32
The Silver Shnerfer
NickGTI32's Avatar
Drives: 2013 SWP BRZ 6MT
Originally Posted by swarb View Post
^not spam. Nice car. It would be spam if you posted too many pics too often. Couple different locations and good lighting make for great pics! good camera setup? or just clean car?
Just a clean car I suppose hehe thanks this was taken with the iPhone6.
NickGTI32 is offline   Reply With Quote
Old 02-18-2015, 09:21 AM   #2972
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Originally Posted by Toxicmilk45 View Post
17 x 9 ET 35
And this one is with 20mm spacers all around but I feel like its a little hard to notice in the picture
17 x 9 ET 15 Effective
How much camber were you running with the adapters? I have to order 25mm spacers making my wheels +10 since my 20mm adapters are being a pain.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 02-18-2015, 02:49 PM   #2973
Toxicmilk45
Toxicmilk45's Avatar
Drives: White out FRS
I'm actually running ARP extended studs so I have 20mm slip on spacers. Are the ones you're trying to get bolt on or slip ons?
Front is -5 and rears are around -3
The tires I'm running are 225/45/17.
Toxicmilk45 is offline   Reply With Quote
Old 02-18-2015, 04:35 PM   #2974
WolfsFang
Scrape Master
WolfsFang's Avatar
They are bolt on adapters but since this morning I called a shop and they are drilling it out so everything sits flush so I can keep my +15 offset
Sent from my XT1060 using Tapatalk
Old 02-19-2015, 12:12 AM   #2975
FRSEVO
Drives: Ultramarine FRS
Haven't posted in a while
From Works
To reps and a new lip
18x8.5 +8 front 18x9.5 +13 rear
Instagram @nmgrizzlybear
Buschur built Evo VIII - SOLD
Ultramarine FRS
FRSEVO is offline   Reply With Quote
Old 02-19-2015, 02:36 AM   #2976
theGonz
theGonz's Avatar
Originally Posted by grostoine View Post
He is running racer-x front LCA to fit these wheels. You cannot put more camber on the airlift topplates. They should not put this on their kit. It is stupid to have adjustable top plate when you cannot touch them ... I'm on air too and had the same problem. I ordered some custom wheels but with less agreesive spec so i dont need camber...
He did not keep those wheels for a long time... Wayyyyyy to much camber in front needed. It was dangerous.
Bad quality wheels too. No bullshit.
This isn't completely true. I'm running Airlift with -3.7 degrees of camber in front with no bag issues and the car gets driven quite hard.
IG: theGonz
theGonz is offline   Reply With Quote
Old 02-19-2015, 04:57 PM   #2977
adamg
Drives: brz
Originally Posted by Dake View Post
Bought a set of Avid 02 18x8 with good tires 225/40/18. Nothing too dramatic, but I like 'em. Also, only five pounds heavier than the factory wheels and tires.
again not aggressive but whatever. lets just ruin this thread with a bunch of stock height cars with wheels half an inch wider than stock
adamg is offline   Reply With Quote
Old 02-19-2015, 05:03 PM   #2978
Dake
Dake's Avatar
My bad - I'll go enjoy clearing speed bumps. Peace brosef.
Dake is offline   Reply With Quote
Old 02-20-2015, 02:14 AM   #2979
Brndn704
Brndn704's Avatar
I haven't really seen any good pictures in this thread in a while...
Brndn704 is offline   Reply With Quote
Old 02-20-2015, 09:38 AM   #2980
theGonz
theGonz's Avatar
^ Really?
IG: theGonz
Old 02-20-2015, 10:34 PM   #2981
ExquisiteStance
Originally Posted by theGonz View Post
^ Really?
Hey man what are your front wheel specs? And how are you managing to run the camber in the front?
Old 02-20-2015, 10:41 PM   #2982
ExquisiteStance
It's actually a 18x9 and around 28 offset I think with lower offset you should be ok adding camber.
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
