Old 02-11-2015, 08:55 PM   #1
gonzo
Drives: frs
Oft Tune E85 Showing Codes P1170 P117B
EDIT: Thread title is wrong. I believe the codes were 0171 too lean and 117B direct injection. NOT 1170 port injection.
I have had oft headers and e85 for almost a year now. Today car threw check engine codes P0171 P117B. I reset the codes, and I did a wot pull from 3k to 4.5k and the afr was good, mid 12s, and LT trim was around 7%, but then adv mult dropped to 0.0. Ignition adv is in the 40s. I recorded it and will post the log soon.
I'm going to make another log on the way home. Which parameters should I be logging? Should I try another wot pull? Any ideas? The car sounds and idles fine.
Thanks a lot for any help. @Shiv@Openflash @steve99 @mad_sb
gonzo is offline   Reply With Quote
Old 02-11-2015, 09:15 PM   #2
gonzo
Drives: frs
Don't tell me direct injection failed. The codes are for too lean and Direct Injector Fuel Performance.
Old 02-11-2015, 09:20 PM   #3
steve99
Drives: FT86
Originally Posted by gonzo View Post
I have had oft headers and e85 for almost a year now. Today car threw check engine codes P1170 P117B. I reset the codes, and I did a wot pull from 3k to 4.5k and the afr was good, mid 12s, and LT trim was around 7%, but then adv mult dropped to 0.0. Ignition adv is in the 40s. I recorded it and will post the log soon.
I would not be doing WOT high rpm runs till you find out what wrong.
Check for intake air leaks, maf sensor dirty especially if you have aftermarket intake or an oiled filter.
Check for exhaust leaks, and 02 sensor plugs or maf sensor plugs all good.
do a log and look for high ltft, the IAM being at zero indicates significant knock occurring, check if commanded afr and afr are following each other under load.
Old 02-11-2015, 09:24 PM   #4
steve99
Drives: FT86
probably look at direct injector pulse width and port injector pulse width.
http://www.ft86speedfactory.com/ecutek/DTCList.pdf
Old 02-11-2015, 09:25 PM   #5
gonzo
Drives: frs
Command afr and afr are following each otherr partial and wot. LTFT are high 30s when partial throttle but 5% wot. Stock intake and toyota drop in filter.
What's the easiest way to check for intake leaks and the sensor plugs? My tools/garage are 150 miles away at another house. Should I hit up a local mechanic? Dealer is out of the question.
Can I do wot lower than 5k logs?
Thanks again, Steve.
Old 02-11-2015, 09:36 PM   #6
steve99
Drives: FT86
LTFT high 30 is no good something is wrong.
try logging the direct and port injection pulse widths see if one stays zero all the time at medium rpm and load it runs some port and some direct injection
Old 02-11-2015, 09:49 PM   #7
steve99
Drives: FT86
P1170
Port Injector Fuel Performance Does not come on DTC
P117B
Direct Injector Fuel Performance Does not come on DTC
P0171
System Too Lean (Bank 1)
Seems unlikely both injection systems would fail at same time
likely its going to be something common to both
fuel tank low empty
fuel pressure low fuel pump failing.
maf sensor issue
air leak ect
this guy got same codes after installing k&n intake ,
http://www.ft86club.com/forums/showthread.php?p=1618213
pull out filter and maf sensor check maf sensor clean and no debris or anything in it. One guy had a mouse eat through his air filter and the bits of filter clogged maf sensor.
Old 02-11-2015, 11:38 PM   #8
gonzo
Drives: frs
http://www.datazap.me/u/gonzo/di-and...s?log=0&data=1
Only went WOT for about two seconds. Does anything look off? I'll check the filter tomorrow and make another log.
Old 02-13-2015, 12:30 AM   #9
Koa
STOP whatever you're doing and go back to a stock or trusted ROM. Your fuel trims are so out of whack. If you're under warranty get that car in asap. Otherwise, you will have to test the injectors and fueling system for integrity. Something is very wrong
Old 02-13-2015, 03:34 PM   #10
gonzo
Drives: frs
Thanks. Already back to a 91 map. I was thinking that maybe the e85 pump gave me 91 gas instead of e85. I'll log the 91 and see what happens.
Old 02-13-2015, 03:44 PM   #11
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
If you're running 91 on an E85 tune your fuel trims will be super high 20+ as shown in your log. That would be the most logical conclusion.
However I wouldn't understand how you mistaken E85 for 91.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 02-14-2015, 01:25 AM   #12
gonzo
Drives: frs
I don't. The island is on the opposite side of the station. I was thinking the gas station fucked up.
Went back to 91 and haven't thrown any codes. After 20 miles, my LTFT during partial throttle is 10-17% below 4500 rpm and then 3% above 4500 rpm (partial throttle). I didn't do any WOT pulls. I'll do some tomorrow and log it.
The good news: no codes, IAM stays at 1
Bad news: LTFT is 10-20% in the lower rpms, but drops below 5% in higher rpms.
Old 02-14-2015, 01:45 AM   #13
steve99
Drives: FT86
sounds like its back to intake\ exhaust leak crook\ dirty maf sensor or 02 sensor.
Old 03-25-2015, 04:36 PM   #14
gonzo
Drives: frs
Turns out it was a dying battery o_o
Car wouldn't start a week after these codes started. Replaced it and no more codes & LTFT is back to normal.
Profile/Avatar pic not showing up JS + BRZ Site Announcements / Questions / Issues 3 01-07-2014 05:22 PM
showing off some new parts Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 27 09-24-2013 10:53 AM
GPS showing incorrect start & end time Xx-Ness-xX Electronics | Audio | NAV | Infotainment 3 09-03-2013 09:38 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 04:23 PM
Used FR-S showing up on Cars.com xrs Scion FR-S / Toyota 86 GT86 General Forum 19 07-13-2012 10:46 PM
