Old 01-29-2015, 10:49 AM   #15
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Originally Posted by 2016 Camaro SS View Post
The DW's are rated with more tread life than the PSS I thought? I've had mine on for 20k miles and they still have tons of tread left from street driving.
You might not want to compare the tread rate of two different brands.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 02-01-2015, 01:31 PM   #16
CatDaddysBBQ
Drives: '13 FR-S
I have a set of MPSS in my basement waiting for spring to get here (currently in a 15" blizzard today), and can't wait. Considered the DW, but ended up in a situation where it didn't make sense...
My finalists in that class were the V12 EVO and the MPSS. Main reason was that if I didn't want to spend the money for the michelins, I may as well save the most and get the hankooks. No point in the DW since they aren't clearly better than the hankooks in the way the MPSS is. So my thought is go with the best in class or go with the cheapest one that is still decent.
CatDaddysBBQ is offline   Reply With Quote
Old 02-01-2015, 02:49 PM   #17
Lurkasaurus Rex
Drives: 2014 BRZ Limited
I chose the DW as a step up tire from the Primacy. Bought new wheels (17x8) and went with a 225/45. I actually didn't want to go as sticky as possible, I wanted to gradually increase stick while I roast a set of less expensive tires. Ill go stickier after i do the suspension. Plus, my new tire and wheel combo came in at barely over 37 pounds - the DWs are pretty light. The noise in corners will just be a little warning for me.
I heard turn in can be slightly sloppy on DWs. I thought I may correct a tiny bit of that with a slightly aggressive fitment. Hope the 8" wheel and 225 tire works in that regard, if not I'll be tossing another set of brand new tires.
I want my '86 Brat back, then I'd have two 86's. Man, I miss my Brat.
Lurkasaurus Rex is offline   Reply With Quote
Old 02-01-2015, 03:03 PM   #18
Akari
Drives: 2013 DGM BRZ
The PSS is a better tire all-around. This is how the DW sounds when you're making em scream.
Wow, that is a hell of a scream. One of my friends was having problems with his DWs chunking at the track, have the DWs you've seen held up to track abuse?
Akari is offline   Reply With Quote
Old 02-01-2015, 04:26 PM   #19
CSG Mike
CSG Mike's Avatar
That's a setup issue more than a tire issue. All tires will chunk with enough heat, but if the setup is right, then it'll chunk EVERYWHERE, not just the outer edges.
Old 02-01-2015, 06:03 PM   #20
Akari
That's what I figured, although he's had no issues on the same setup and track with PSS.
Old 02-01-2015, 06:24 PM   #21
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
That is moderate tire noise. A friend of mine once ran his Jaguar XJ12 at the track shod with new Dunlop D40 M2's which were the newest, hottest tire of that era. The car made so much noise around the corners that you could just listen and hear him go through every corner on the 3+ mile track from the grandstand. That was a fairly large car though, with 12 cylinders and two gas tanks (or maybe it was just two tank fill locations).
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 02-03-2015, 06:47 PM   #22
Agent 86
Drives: 2017 Cayman S
I don't have any experience with the MPSS, but I have had the DW's for about a month now. I went from stock wheels/tires to 245/35 front and 265/35 rear DWs.
I'm very satisfied with this tire. I don't race, but I do occasionally push my car within reasonable limits on back roads.
On one particular road surface near my house, I find the DW's to be louder than stock tires, but everywhere else, I don't notice any difference.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 02-03-2015, 06:56 PM   #23
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by JohnAyySays View Post
Thanks alot! I'm very new to purchasing tires so I don't know much. Yea I will definitely probably go stock size. Is Tirerack usually the cheapest place to purchase MPSS or can I get them cheaper if I buy local?
TireRack usually has best price, but you also have to deal with shipping them to an installer and then schedule/pay for mounting/balancing on top of that. Just a few extra steps.
I don't believe Costco keeps MPSS in stock, so you'd have to special order them. Same with America's Tire. Their prices should be pretty good though.
I got mine from Seever & Son's in Pleasanton. Small shop but a huge customer base, so you'll need to make an appointment. They stock MPSS in most sizes, and will usually price match. They also include free rotation and repair, should you run over a nail (happened to me twice already) for the life of the tires. I trust their work in particular because it's the same experienced techs working there every time I go in, rather than seeing a new fresh face out of high school each visit.
Another plus for MPSS is the warranty... in most cases you can get a brand new tire for free if it gets damaged or wears out prematurely, or at least get credit for your old ones.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 02-11-2015, 01:27 PM   #24
N_A
Drives: 2013 Raven
How's the tread life on the DW's? Anyone with some miles on these?
I'm leaning towards them because of the price difference and similar performance rating.
N_A is offline   Reply With Quote
Old 02-11-2015, 01:51 PM   #25
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Watch out for Costco. They have great prices, but if they cannot easily get your car on the lift for install, they will not even try.
Edit: Every Costco is different so make sure they will before purchase.
ApolloSki is offline   Reply With Quote
Old 02-11-2015, 01:57 PM   #26
Akari
That must be specific to your Costco, they'll pull out low profile jacks here if need be.
On a side note Costco currently has $70 off a set of 4 Michelins plus an additional $60 off the install(Which covers the entire mount, balance, warranty) for Exec members.
Old 02-11-2015, 04:47 PM   #27
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
2 track events and 20k miles on the MPSS here, and barely any sign of wear! I haven't even rotated them yet, and yet they stick like glue. takes a bit to warm them up to proper temperature though. Kind of understand why expensive sports cars use them as OE tires now.
mokinbird87 is offline   Reply With Quote
Old 03-15-2015, 07:06 PM   #28
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Not to hijack this thread, but like a lot of others I am finally going to upgrade from the stock Primacy HPs when the snows come off in a few weeks. I'll be using a reasonably lightweight set of 17x8 rims, probably GTF1s @ 15.5 lbs a piece. There has been a lot of discussion about whether MPSS are better than Continental DW. Since my otherwise stock BRZ is my DD and won't be tracked, and since the roads around here are crap, ride comfort is nearly as important to me as ultimate grip. The DWs are lighter than anything else I have seen and have a softish sidewall, both of which should be good for ride comfort and traction on rough roads. So rather than worry about MPSS being "better" than the Contis, I'd like a comparison of the DWs in 225/45 versus the Primacy HPs. Would anyone with direct experience of the Contis care to comment about their grip, balance, limit handling, steering feel, noise, etc.? Any better info than just what is in the Tire Rack reports?
TIA!
Talus1 is offline   Reply With Quote
Michelin Pilot Super Sports TimR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 06-10-2017 03:35 PM
FS: TWO Michelin Pilot Super Sports 245/35/18 (AKA BEST Tire Ever) Sportsguy83 Wheels and Tires 24 11-22-2013 07:30 PM
FS: Work XD9 with Michelin Pilot Super Sports truenosan Wheels and Tires 1 08-02-2013 11:22 AM
FS: Work XD9 with Michelin Pilot Super Sports truenosan Canada Classifieds 0 07-31-2013 11:27 AM
Michelin Pilot Super Sports Warrenty? FLASCH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-11-2013 10:39 PM
