Old 02-10-2015, 05:05 PM   #29
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I think there is a pretty costly solution to this...you might need a turbo and larger injectors and a different pump...but I'm not sure.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Koa (02-12-2015)
Old 02-11-2015, 08:10 AM   #30
wparsons
wparsons's Avatar
No one is making aftermarket HPFP's, just the in tank low pressure pumps. The HP pump is for the direct injection side, the in tank feeds both the port injectors and the base pressure for the DI.
flickr
Old 02-11-2015, 11:39 AM   #31
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Maybe they should...
Old 02-11-2015, 11:44 AM   #32
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Originally Posted by HunterGreene View Post
Each time its something new that they are trying. One of these times, it will work. Stories like yours, however, make me glad that I didn't jump on the "replace the pump" bandwagon years ago.
For real. I had mine replaced about a month ago. No noise yet ~ 2k miles later.
Jesse36m3 is offline   Reply With Quote
Old 02-11-2015, 12:38 PM   #33
wparsons
wparsons's Avatar
I don't see anyone being ready to pay that cost to possibly stop a slight noise...
This is for a different engine (VW/Audi 2.0T), but I would imagine the price would be comparable:
http://store.034motorsport.com/apr-2...fuel-pump.html
flickr
Old 02-11-2015, 01:32 PM   #34
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
That's around the price on parts that my work order showed back in October 2013. It was a little bit over $1000. Not exactly a cheap part.
2016 Camaro SS is offline   Reply With Quote
Old 02-11-2015, 02:32 PM   #35
btoast
I had my fuel pump replaced over 3k miles ago and have not had crickets since. I'm going to switch over to E85 soon and will report if I have any issues. But I've been on California grade 91 oct. from a myriad of different gas stations with no issues since replacement.
btoast is offline   Reply With Quote
Old 02-11-2015, 02:36 PM   #36
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I can't hear my crickets over my exhasut unless I'm standing there looking at the engine with the hood open.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
DGM33 (04-06-2015)
Old 02-11-2015, 02:42 PM   #37
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
so E85 helps, but for those who dont have it and only have access to race gas would it do the same, because of the octane or is it ethanol specific?
Old 02-11-2015, 03:01 PM   #38
Koa
Originally Posted by hmong337 View Post
I honestly think is is just an inherent design flaw. Even the 2015's still.chirp.
tell us what you honestly feel
I don't understand why people feel the need to say "truly.." or "honestly.." before a statement. We're going to assume you aren't lying
but on topic.. +1 the flaw is of the design, not an error in manufacturing process. Those with "new" HPFPs sans everything else are likely to not solve the problem. Some people swear their new pumps have solved the problem. Time will tell
The Following User Says Thank You to Koa For This Useful Post:
wparsons (02-12-2015)
Old 02-11-2015, 03:08 PM   #39
kch
Senior Misanthrope
kch's Avatar
E85 made my crickets much worse. Just sayin'.
Old 02-11-2015, 03:58 PM   #40
phrosty
I wonder if this is considered under the powertrain warranty. 3 year bumper-to-bumper is just about up!
phrosty is offline   Reply With Quote
Old 02-11-2015, 04:02 PM   #41
2016 Camaro SS
Drives: Fast
Won't matter. If they issue a TSB for it and your car falls within the VIN range, or you can prove to the dealer it makes the noise it should not be an issue.
Old 02-11-2015, 04:06 PM   #42
phrosty
TSBs apply even when you're out of warranty? Did not know!
The Cricket kh060 Issues | Warranty | Recalls / TSB 39 03-28-2015 12:30 AM
is that cricket noise?? impossible Engine, Exhaust, Transmission 17 11-16-2014 10:44 PM
CRICKET FIX! alex_86 Issues | Warranty | Recalls / TSB 142 12-04-2013 11:29 AM
Chirping/Cricket Fix Out? deeranged Issues | Warranty | Recalls / TSB 15 10-02-2013 05:43 PM
Cricket TSB [deleted] Southern California 25 06-05-2013 06:01 PM
