Old 02-07-2015, 12:15 AM   #6007
blown
Drives: ft86
- Inlet Pipe
- Idler pulley mount
- Evap Sol Relocation Bracket (dont need)
- Fuel rail support bracket (dont need)
- FT86 throttle body loom extension (cut and extend)
- FT86 MAP sensor loom extension (dont need)
blown is offline   Reply With Quote
The Following User Says Thank You to blown For This Useful Post:
TemeCal (02-07-2015)
Old 02-07-2015, 01:56 PM   #6008
TemeCal
Drives: 86
Originally Posted by blown View Post
- Inlet Pipe
Thanks @blown
You are correct, the MAP sensor loom extension isn't needed on LHD cars. I didn't use it on my car. Same with sol bracket and fuel rail support. Both of those were tiny pieces of aluminum that didn't do much.
For the throttle body extension, I'm trying to sell the kit and wouldn't want the buyer to have to splice wires. Do you know of any companies that would have the ends, so an extension could be made? I agree though, it's very easy to cut/splice.
So...looks like I just need the inlet pipe and idler pulley mount. Even the idler pulley mount isn't anything special.
Thanks for the reply.
TemeCal is offline   Reply With Quote
Old 02-07-2015, 02:11 PM   #6009
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by Chad86 View Post
Looking to purchase the Sprintex 335 through Moto East group buy, running on non built motor with ME custom tune. How is the low end torque on the twin screw compared to running a turbo? How difficult is the install? I understand the kit uses the stock air box.
Bump. Input needed from community Sprinters, thanks!
Chad86 is offline   Reply With Quote
Old 02-07-2015, 04:01 PM   #6010
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
Call Mike at Moto-East. He has all the info you'd ever need.
R3NIK is offline   Reply With Quote
Old 02-08-2015, 04:35 AM   #6011
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Anyone know the total weight of the supercharger kit??
Both iterations btw
stevo_12v is offline   Reply With Quote
Old 02-08-2015, 10:10 AM   #6012
Scubaru
Scubaru's Avatar
Drives: '13 FR-S, '14 RAM 1500, '01 BMW330i
Both iterations btw
The supercharger itself only weighs about 20lbs. As far as the I/C kit, I have no clue
Pulled from this source: http://www.sprintex.com.au/wp-conten...chureSpecs.pdf
Scubaru is offline   Reply With Quote
The Following User Says Thank You to Scubaru For This Useful Post:
stevo_12v (02-08-2015)
Old 02-08-2015, 06:39 PM   #6013
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Found this clip; not sure if it has already been posted here. I feel it does the Innovate Supercharger justice.
[ame="https://www.youtube.com/watch?v=xFo9NOKmcrY"]BRZ Supercharged w/UEL Night Run - YouTube[/ame]
The Following 3 Users Say Thank You to Chad86 For This Useful Post:
10Stars (02-09-2015), Boofneenee (02-08-2015), mokinbird87 (02-09-2015)
Old 02-08-2015, 11:38 PM   #6014
TemeCal
Drives: 86
Not sure this is accurate. I recently shipped my supercharger, and it came in at 65lbs (with padding, box, etc...). So, I'd guess it'd be closer to 50lbs.
I actually had two boxes. One box was the supercharger (aprox 65lbs), and the second box contained the intercooler kit (around 25lbs).
Old 02-09-2015, 12:36 AM   #6015
86fun
Drives: 2013 FRS
Is anyone running WMI with this kit? What kind of results? Similar to E85? I'm also curious where it would get injected in the intake.
86fun is offline   Reply With Quote
Old 02-09-2015, 10:18 AM   #6016
Scubaru
Scubaru's Avatar
You're not including the weight of the attached manifold, are you? The S/C kit comes with a little more than just the unit itself.
Old 02-09-2015, 10:38 AM   #6017
TemeCal
Drives: 86
I am including the weight of the manifold. He asked for the weight of the "supercharger kit", which should include the manifold. You're probably right though...the supercharger is around 20-25lbs...the manifold and other components make up the rest.
Old 02-09-2015, 12:16 PM   #6018
86fun
Drives: 2013 FRS
Never mind, Bill has an excellent answer in post 5452. Bottom line, not recommended for power tuning. Bummer.
Old 02-10-2015, 11:44 AM   #6019
Scubaru
Scubaru's Avatar
Yep, I can definitely say I read over that part haha.
TemeCal (02-10-2015)
Old 02-12-2015, 02:06 PM   #6020
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Anyone have a resource to acquire replacement parts for the 210 kit? Contacted Sprintex and nothing. Specifically this part.
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
