Old 02-07-2015, 10:44 PM   #1163
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Holy sidewall Batman!
I don't know the answer to your question, but perhaps this website will help:
http://www.frsproject.com/tire_size.php
Haha yea, i figured I would be a little different, instead of going with an 18" I would just run some more sidewall, hopefully Ill wont spin through 3rd on the street haha.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 02-08-2015, 12:02 PM   #1164
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I would guess you need to stick with +45 offset 17x9 RFP1 comes with on tires 275 wide, even then you will have a bit of poke. The tire will be 1 full inch taller so lowering 1.5 inches may cause problems even with neg camber. Also the diameter difference between front and back tires may cause the sensors to mess up.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
#maverick# (02-08-2015)
Old 02-08-2015, 12:31 PM   #1165
ft86me
ft86me's Avatar
Drives: 2013 FRS
For those of you that have gone 265 or 275 on 18's , can you please provide me with what further modifications I will need in regards to camber?
currently, 18x10 +44 245 40 18 on kw v3 cusco rear lca and whiteline camber bolts up front. -1.3 front now and -1.8 rear now and have no issues.
thanks.
ft86me is offline   Reply With Quote
Old 02-08-2015, 01:59 PM   #1166
#maverick#
#maverick#'s Avatar
Thanks! I may probably have to roll the fenders. Which is fine with me. A local guy we have here is running a 265 in back on a 17×8.5 and 245 on the same size wheel in front. I think his offset is +48 with -2 camber in back
Old 02-08-2015, 08:23 PM   #1167
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Originally Posted by sactownbwoy View Post
As soon as the wheels get in. The shipment isn't due in until the end of the month. I can't wait
That's one reason I picked my Enkei's up from Evasive. Cause they had them in stock and on sale!!
texasbound972 is offline   Reply With Quote
Old 02-08-2015, 08:34 PM   #1168
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
I ordered mine from evasive too. The site said they were in stock. Guess they weren't, haha
sactownbwoy is offline   Reply With Quote
Old 02-08-2015, 08:36 PM   #1169
texasbound972
USMC
Here is my 275/35/18 squared setup. Need LCA's so the rear can stop scraping!
The Following User Says Thank You to texasbound972 For This Useful Post:
shifter907 (02-08-2015)
Old 02-08-2015, 08:50 PM   #1170
ft86me
ft86me's Avatar
Drives: 2013 FRS
How did you make these fit? Roll pull? Lca are needed? Camber bolts up front ?
Old 02-08-2015, 10:56 PM   #1171
texasbound972
USMC
Camber bolts up front, rear fenders rolled and LCA'S are needed. It scrapes the tire on the rear driver side occasionally even on the stiffest setting. Wheel size is 18x9.5 +40
ft86me (02-08-2015)
Old 02-08-2015, 11:10 PM   #1172
ft86me
ft86me's Avatar
Drives: 2013 FRS
Thanks a bunch dude. Have 18x10 +44 now on 245 40 18 and lca w camber bolts and I'm fine except when full clock turned. I'll run on the driver side of the chassis lol.
The Following User Says Thank You to ft86me For This Useful Post:
texasbound972 (02-08-2015)
Old 02-09-2015, 08:46 PM   #1173
Basket Case
Drives: 2013 Raven fr-s
Can anyone make a suggestion for 17x8.25 et35 wheels? I have hotchkis lowering springs and camber bolts for up front. Whats the biggest tire i can reasonably fit on those wheels to fill up the wheel well?
Thanks
Basket Case is offline   Reply With Quote
Old 02-09-2015, 09:04 PM   #1174
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Thanks
It can fit bigger I'd guess but I would run 245/40/17s.
Old 02-09-2015, 09:05 PM   #1175
swarb
Thanks
255/40-17, recommend 8.5 width minimum but it is up to you to decide. Otherwise 245/40-17
Old 02-22-2015, 02:23 PM   #1176
#maverick#
#maverick#'s Avatar
Is anyone running a 265 or 275 tire on a 17x9 wheel?
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
