Old 02-07-2015, 09:11 AM   #1
Stewie
Stewie's Avatar
Drives: '15 - WRB Brz Limited
225/45/17 Michelin Primacy tires
Anybody tried these? More grip from the increased contact patch due to the additional width, maintain the fuel efficiency, and some of the fun tail sliding factor?
What kind of tires come on the series blue? Those are 17x7.5 wheels right?
2015 WRB Brz Limited 6MT
2001 BMW 540i 6MT M-Sport (sold)
2001 BMW 325ci 5MT (sold)
1988 Volvo 740 Turbo 4MT w/ electric OD/5th gear (sold)
Stewie is offline   Reply With Quote
Old 02-07-2015, 11:59 AM   #2
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
The USDM Sti wheels on the series blue are 17x7 like the regular wheels. The JDM Sti 17's are 17x7.5. You can still run a 225 tire though, and many do. The sidewall will likely flex a little more making it a little less responsive. Most people won't buy primacies though once they see that Pilot Sport A/S 3's and Pilot Super Sports are both cheaper, and a far better tires.
TheVoiceOfReason is offline   Reply With Quote
The Following 2 Users Say Thank You to TheVoiceOfReason For This Useful Post:
Stewie (02-07-2015), Teseo (02-08-2015)
Old 02-07-2015, 12:12 PM   #3
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Hear, hear! Listen to TheVoiceOfReason
Mad1723 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mad1723 For This Useful Post:
meWant (02-10-2015), MGPAX (02-24-2016)
Old 02-07-2015, 02:06 PM   #4
Stewie
Stewie's Avatar
I'm listening! I'm listening!!!
The pilot super sports have been the plan from before I bought the car. I was just considering an option that would give a bit more grip but not require a monumental effort to break traction or 'over tire' the car with stock power levels as I have no plans on modifying the power train.
Old 02-07-2015, 02:10 PM   #5
Stewie
Stewie's Avatar
Thanks for the info. I tried to but I couldn't find the exact specs. What I found was on a forester forum.
http://www.subaruforester.org/vbulle...-black-256970/
Let me know if that link works. I'm still figuring out how to post links and photos on here.
Old 02-07-2015, 02:21 PM   #6
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
It's really not hard to break pilot super sports free with stock everything else.
Tgionet is offline   Reply With Quote
The Following User Says Thank You to Tgionet For This Useful Post:
Stewie (02-08-2015)
Old 02-07-2015, 07:54 PM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
If I could recall, the primacys actually cost more than the PSS (go figure)
183 on Tire track - Primacy
139 on Tirerack - PSS
http://www.tirerack.com/tires/tires....SSXL&tab=Sizes
Why spend the extra money and just get PSS
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Stewie (02-08-2015)
Old 02-08-2015, 02:13 AM   #8
Stewie
Stewie's Avatar
Yeah. I saw that a while back. I think it worked out to ~$740 for replacement stockers vs ~$570 for a set of mpss. It had me scratching my head to a bit but then i realized that the tech and purpose of each tire is different which is why the cost difference is so great.
Personally, I love bridgestones. But on this car they would weigh too much. If/when I change anything on the car, it's going to be for performance reasons and thus everything must be lighter if possible.
Old 02-08-2015, 10:30 AM   #9
extrashaky
Drives: 2014 BRZ Limited
That's because of expected life. The Primacy is a 45,000 mile tire. The PSS is a 30,000 mile tire. The low rolling resistance of the Primacy means you're not leaving as much of it behind. Since the Primacy is expected to last 1.5 times as long, it costs more.
You'll notice that it doesn't cost 1.5 times as much as the PSS. The PSS is actually more expensive per mile than the Primacy. If you were shopping based on price rather than performance, the Primacy would be a better deal.
Old 02-08-2015, 10:53 AM   #10
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
True, but this assumes the Primacy tires will make it to 45,000 miles as the warranty states. It would be interesting to note how many BRZ/FRS owners are actually getting 45K miles out of the Primacy tires. 30K on the PSS I believe is possible though, but of course mileage depends on multiple factors such as use, ambient temperature, surface conditions, proper inflation, etc.
n8dog11914 is offline   Reply With Quote
Old 02-08-2015, 12:31 PM   #11
TheVoiceOfReason
Drives: BRZ Limited
Pilot sport A/S 3's are also are a 45k mile tire and are cheaper ($151). They have less grip than the PSS of course unless its really cold being an all season, but still have better specs in every other category than the Primacy exept maybe rolling resistance. I would still go PSS over them in a warm climate though, but my point is I think the Primacy tires get a premium because they are used as an OEM tire. 225/45/17 is listed for Audi and Mercedes on Tire Rack. Then there are our cars, the Prius, and likely more.
Old 02-08-2015, 01:47 PM   #12
M12Power
M12Power's Avatar
Drives: 2015 Firestorm Scion FR-S 6MT
So you want to have a wider width for grip, but at the same time, your sidewall will be slightly higher, which may present an adverse effect on the responsiveness/sharpness of the steering as well as acceleration. You also increase the likelihood of the tires rubbing/striking against the edge of wheel fender if the car bottoms out (especially when turning). Another unwanted side effect is that it will make your speedometer readings even more inaccurate.
Not saying you can’t do it or if any of the above negative aspects have any real impact, but you may want to do a bit more research to see if there are other wheel/suspension mods you need to do to accommodate the wider tire.
M12Power is offline   Reply With Quote
The Following User Says Thank You to M12Power For This Useful Post:
Stewie (02-08-2015)
Old 02-08-2015, 06:14 PM   #13
Stewie
Stewie's Avatar
Thanks for the reply. I know that once you go to greater than an 8inch rim width you have to be very careful about the offset you choose. But for a 7.5 inch width there should be enough clearance with no rubbing as long as you don't go for an extreme drop. At least that is what I've read on here. Please correct me if I'm wrong.
Old 02-09-2015, 12:58 AM   #14
extrashaky
I have 30K on mine right now, and they still have plenty of tread left. Under normal driving conditions, I see no reason why these tires wouldn't get at least 45,000 miles.
Has anyone actually reported premature wear in normal use?
FS: 4 Michelin Primacy HP (215/45/17) Tires Laloosh Wheels and Tires 7 12-28-2014 07:00 PM
FS: 215/45/17 Michelin Primacy HP Tires (SOLD) adamg Wheels and Tires 5 12-24-2014 05:58 PM
FS: 3 OEM tires Michelin Primacy HP 215/45/17 dj petey Canada Classifieds 0 09-28-2014 07:31 PM
FS (NJ): OEM Michelin Primacy Tires wawawoowee NY / NJ / CT / PA 3 05-22-2014 05:26 PM
OEM Tires Michelin Primacy HP ganz954 Wheels and Tires 4 09-04-2013 11:29 AM
