Old 02-05-2015, 11:00 PM   #1093
s13Henry
s13Henry's Avatar
Drives: Black BRZ/Black S13 Silvia
Got a call from the dealer saying they have multiple parts to fix "cricket noise", lets see what happens. I put in a claim for this problem a couple months ago and they told me by late january they should have a soultion and sure enough they did. Lets hope this works.
s13Henry is offline   Reply With Quote
Old 02-06-2015, 10:15 AM   #1094
HunterGreene
Hail Magnet
HunterGreene's Avatar
Let me be sarcastic and say "don't hold your breath."
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Tcoat (02-06-2015)
Old 02-06-2015, 11:11 AM   #1095
HunterGreene (02-06-2015)
Old 02-06-2015, 12:27 PM   #1096
When mine was done I saw the parts list (warranty cost $1,600 P&L). The TSB requires multiple parts to be replaced, I don't think they are doing anything that hasn't already been done to fix the noise.
Old 02-06-2015, 01:08 PM   #1097
s13Henry
s13Henry's Avatar
I dropped off the car and I was told there was three parts that were getting replaced and it is the first time that it'll be done. I'm not sure to what extent by ima say in the South Bay area in ca. I'll keep you guys updated and give the part number to what was replaced. I am aware this is an experiment in a way but won't hurt to try.
The Following User Says Thank You to s13Henry For This Useful Post:
Dadhawk (02-06-2015)
Old 02-06-2015, 01:23 PM   #1098
Goodmanner
10 Series TRD
Goodmanner's Avatar
Drives: 2013 FRS 10 Series, 2013 IS250
I recently got my car serviced (two days ago to be exact) for the cricket noise contributed by the fuel pump. The Toyota dealership I went to were reluctant to authorize the service at first because "it doesn't fix the issue; eventually the noise will come back over time."
Apparently it costs Toyota $1800 to swap out the fuel pump with the parts so they had to get "authorization" first. By the end of the day, they replaced it and so far I don't hear it when idling or cruising. Whether it's a temporary or permanent fix, it feels great not having to hear that chirp for the time being.
Goodmanner is offline   Reply With Quote
The Following User Says Thank You to Goodmanner For This Useful Post:
s13Henry (02-06-2015)
Old 02-06-2015, 08:22 PM   #1099
s13Henry
s13Henry's Avatar
That's inviting news. I just got a call saying they're gonna take more then one day, also that they were replacing the valve springs and cover. So looks like more then a fuel pump issue like the other members mentioned.
Old 02-07-2015, 02:39 AM   #1100
Kostamojen
I'm contemplating headers so I don't have to listen to it anymore...
That or strapping some sound deadening material to the pump.
Old 02-07-2015, 02:58 AM   #1101
You know what!?
Of all the crap I have read about crickets on here (adding oil to the gas, changing pumps, using XXX gas only, voodoo witch doctor, alien technology, etc, etc) I don't recall anybody trying a simple sound deadening technique! Not saying it isn't here someplace I just don't think I have read it and since I have probably read 70% of the threads that means something to me. Now I am sure there will shortly be 20 links to the subject but I would be interested in knowing if that could work.
Old 02-07-2015, 03:47 AM   #1102
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You know what!?
http://www.ft86club.com/forums/showp...postcount=4208
Tcoat (02-07-2015)
Old 02-07-2015, 03:55 AM   #1103
Thanks Strat but that is only one! Not enough to set a good trend curve.
Old 02-07-2015, 04:30 AM   #1104
strat61caster
Well I mean, it was Toyota doing the insulation, not a rogue dealership/owner and they quickly abandoned it...
http://www.ft86club.com/forums/showp...postcount=3489
http://www.ft86club.com/forums/showp...2&postcount=67
Tcoat (02-07-2015)
Old 02-11-2015, 05:43 PM   #1105
s13Henry
s13Henry's Avatar
Got the car back last night. Took longer then I expec to get it fixed. Apparently they had to order more parts besides what was already ordered on Friday. So ima up load the work order with exact parts that were changed. It's a big list from fuel lines to valves and of course the pump. So far so good and no noise in the engine bay. Drove it home and to work about an hour commute both ways. I use 91 ocante and live in Southern California.
Here's the list:
Old 02-11-2015, 06:02 PM   #1106
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
why is this thread still alive...there is no fix yet for the crickets. lucas fuel injector cleaner and or a replaced HPFP at the dealer both cause the noise to go away for 100-300 miles at a time then the noise just comes right back.
"Listen, smile, agree and then do whatever the fuck you were going to do anyway." -Robert Downey Jr.
Eski is offline   Reply With Quote
Hood & Bumper Gap on BRZ mact Issues | Warranty | Recalls / TSB 17 02-25-2015 12:22 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Dry carbon fiber hood ChrisOkc8 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-26-2012 10:58 AM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 09:57 PM
