Old 12-20-2014, 12:40 AM   #113
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
ran into the same problem for THREE days...
Originally Posted by slicktop View Post
I was supposed to get the crash bar today but the UPS guy said he didn't have it. I have a tracking number that now says "Exception", so... I don't know where my crash bar is anymore.
Woohoo!
The tracking for UPS on my cat back exhaust kept saying on truck for delivery.
Then it would say rescheduled.
What it was, was that because of Christmas, they would remove the larger boxes from the trucks when they ran out of room and put them in containers.
I finally got tired of expecting it to come and see the tracking info change and called them three times to get them to pull it out of the containers and I just picked it up at the distribution center.
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
Jrryjms07 (12-20-2014)
Old 12-21-2014, 12:34 AM   #114
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
Woohoo!
I have never heard of that... Exception???
I found these on googles...
believe the term "exception" in their lingo just means that the shipment is not running on schedule. "Something happened." Could be the package is damaged or lost; could be the truck flipped over and rolled down an embankment off of I-95; could be the truck had a flat and didn't get to the airport in time to make the scheduled flight. I'm pulling for the flat tire
and
If you receive a message that your shipment has experienced an exception, then check the Shipment or Package Progress section in Tracking or Quantum View® Manage for details about changes in delivery schedule. An exception occurs when a package or shipment encounters an unforeseen event, which could result in a change to the expected delivery day. Examples of exception include: address unknown, damage to shipment, or signature not received.
good luck! text me if you need anything or anything else powder coated... We have two powder coating machines now!
Maverick22 is offline   Reply With Quote
Old 01-10-2015, 11:14 PM   #115
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
So the hood closes with only the front engine hook hitting the under hood panel. Not an issue.
slicktop is offline   Reply With Quote
The Following 3 Users Say Thank You to slicktop For This Useful Post:
hmong337 (01-26-2015), PrimeMotoring (01-11-2015), Ryaquinn (01-11-2015)
Old 01-24-2015, 04:23 PM   #116
2jz
Drives: gt86
great work
2jz is offline   Reply With Quote
Old 01-24-2015, 09:02 PM   #117
Ginzhos
Drives: 93 civic si
Will the factory radiator still fit with the jz pucking out? Please post pics of clearance between the fans and the harmonic balancer thanks.
Ginzhos is offline   Reply With Quote
Old 01-24-2015, 10:21 PM   #118
slicktop
http://www.ft86club.com/forums/showp...3&postcount=64
You most likely need a push-type fan setup unless you mod the firewall.
Old 01-25-2015, 02:46 AM   #119
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Im running push fans
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 01-26-2015, 01:01 PM   #120
slicktop
Old 02-03-2015, 11:58 PM   #121
schlitzed
schlitzed's Avatar
Drives: 2013 Firestorm FR-S
Wow man this is insane. Awesome work!
My Build and Journal
How I made MY 86 IG @frscargo
schlitzed is offline   Reply With Quote
Old 02-04-2015, 03:26 PM   #122
TWMPerformance
Drives: Manual Transmission, All the Way!
Fits like a glove! Congrats on all the hard work, it certainly has paid off
TWMPerformance is offline   Reply With Quote
Old 02-04-2015, 05:34 PM   #123
slicktop
Huge update:
Transmission is in. Some gusset plates will brace the top to the sides, but overall it's done.
The shifter linkage was welded together in this shot but it will be replaced with a new piece since it sits perfect.
Pic showing ground clearance.
Shifter lines up great.
They're still working on placement for the beefcake radiator, but it's gigantic.
Clearance with fans installed.
The Following 6 Users Say Thank You to slicktop For This Useful Post:
Creole (02-05-2015), Junkwipe (02-05-2015), LucidMomentum (02-05-2015), M-17 (02-05-2015), SnapOv3st3r (07-02-2015), SomeoneWhoIsntMe (02-04-2015)
Old 02-05-2015, 09:52 AM   #124
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
awesome progress buddy!
great job on the trans tunnel mounts, and that rad is incredible. I got a used griffin rad of a similar size, so I'm glad to see it can fit in there somehow.
excited to see what you do about the intercooler.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 02-05-2015, 10:54 AM   #125
slicktop
Send the praise to a buddy of mine @Ross , he's finishing up everything and is doing a fantastic job. I'm wheel/tire hunting right now so we'll see how things go.
Thinking 17x9 +45 RPF1 daily. 275 ET Streets for the back should work.
Old 02-05-2015, 11:50 AM   #126
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Looks good man, can't wait to see more updates
BlueSky is offline   Reply With Quote
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 10:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 09:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
