Old 03-24-2014, 12:04 AM   #1
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Front End link question
I've been searching everywhere to find the answer to this question, so hopefully someone here may know the answer. My car was originally lowered on Hotchkis springs with OEM endlinks and a Hotchkis swaybar. I now switched to coilovers and the endlinks are too long and actually come into contact with the control arm.
I was thinking of getting either the Hotchkis or Whiteline adjustable front end links, but I wasn't able to find specs on their website on how long they are. The Hotchkis look like they have more adjustment built in, but they also look OEM length. The Whiteline look shorter than OEM but that may just be the photograph.
Any suggestions on which would be better for my application? OEM looks to be a couple of inches too long
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 03-24-2014, 12:05 PM   #2
Wepeel
Drives: '13 BRZ Ltd
The BRZ-specific Whiteline ones that come with their front bar are KLC-179. These are spec'd to range from 200-250mm in length. At their shortest setting, I still had contact issues with the WL front adjustable bar and the control arm on coilovers when running the bar on full stiff (a lot of coils bring the control arm closer to the swaybar). Whiteline has another generic endlink, KLC180-195, that is similar but can go shorter, 190-215mm is the spec, and these work perfectly.
Odi at Feal suspension also includes a shortened, OEM-style endlink with his 441 coilovers. It is non adjustable, and is 190mm in length. Odi does sell these without the coilover kit if you email him.
The Whiteline KLC180-195 or the Feal one would probably work well in your situation.
Wepeel is offline   Reply With Quote
The Following 5 Users Say Thank You to Wepeel For This Useful Post:
Baldoak (12-16-2015), bhmax (08-16-2018), protpibe (03-24-2014), renfield90 (02-20-2017), smg1138 (04-11-2016)
Old 03-24-2014, 12:21 PM   #3
protpibe
protpibe's Avatar
Thanks for the info! That's exactly what I was looking for
Old 03-29-2014, 12:53 AM   #4
protpibe
protpibe's Avatar
Just installed the KLC180-195 end links from whiteline and they're perfect. Thanks again for the advice
Old 09-02-2014, 12:14 PM   #5
illmattic
illmattic's Avatar
How are these endlinks (KLC180-195)? My car is pretty slammed and I was looking to get these to replace me my cut oem links. Are these noisy and do they "pop" a lot?
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
Old 02-04-2015, 11:15 PM   #6
SPCorBUST
SPCorBUST's Avatar
@protpibe and @Wepeel where did you guys purchase the KLC180-195 end links from? I keep seeing the vehicle-specific ones.
SPCorBUST is offline   Reply With Quote
Old 02-04-2015, 11:16 PM   #7
protpibe
protpibe's Avatar
I'm selling mine if you're interested
Old 02-04-2015, 11:19 PM   #8
SPCorBUST
SPCorBUST's Avatar
these are for the fronts, correct? how about the rears?
Old 02-04-2015, 11:28 PM   #9
protpibe
protpibe's Avatar
Yes fronts
Old 02-04-2015, 11:29 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
Aaron @Hotchkis should be able to tell you the length range they adjust too.
The Following User Says Thank You to Gunman For This Useful Post:
SPCorBUST (02-05-2015)
Old 02-05-2015, 01:04 AM   #11
SPCorBUST
SPCorBUST's Avatar
Yes fronts
pics and price?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
Old 02-08-2015, 11:45 AM   #12
Wepeel
Drives: '13 BRZ Ltd
I contacted Whiteline directly.
Front lip question... brz_guy Cosmetic Modification (Interior/Exterior/Lighting) 13 05-17-2013 02:51 PM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 10:39 PM
Frs/brz front piece question lavisxice Scion FR-S / Toyota 86 GT86 General Forum 22 01-10-2013 07:42 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-02-2012 12:45 AM
Front Seat Question livelyjay Scion FR-S / Toyota 86 GT86 General Forum 18 06-17-2012 05:51 PM
